Red colors have turned green - Televison & Video
  • tim92499 Dec 25, 2008
    what i need is to find where i can get the control to swap out the old one. the green pot for the gun has lost control, i just need to get the part
    Champion:
  • 225 Answers
You most likely have lost red lamp function. This can be caused by a number of issues. None are going to be an easy fix. You can isolate the problem quickly if you are a tech, by doing a red/green gun driver board swap. Pretty much the only thing you can try to do yourself, is take the front panel off the TV, then adjust the color bias knobs usually located somewhere behind the panel. One will control the red, one for blue, and one for green. Mark them before you play with them, so you can return them to the factory settings if needed.
Posted on Nov 13, 2008
The grey in my relaxed brown hair occasionally turns a greenish color I use adore semi permanent, dark chocolate any idea how to avoid this?
Your hair is turning green because your missing red when you color your hair. Gray is uncolored hair and to get to a dark chocolate brown you need to add a little red to the color to make up for this. You don't need to strip it out.
Have you heard of people using purple shampoo to neutralize the yellow tones of their blonde? Red will neutralize the green tones, so adding a little red to your color will do this for you.
Mar 09, 2014 | Adore LVT Semi Permanent Hair Color 112...
Why do i have a green screen after i turn the screen adjustment screw?
since every display color monitors are only work with 3 primary color which are red, blue and yellow. You could also search it that by mixing these colors, you could get any color your want. Thats how color monitors work. Now in case of green color, it creates by mixing blue and yellow. When you are turning the screen adjustment screw, the red color plug will become lose, makes it appear green.
I hope your got the reason.
Jul 10, 2012 | Sony FD Trinitron WEGA KV-34HS420 34" TV
I have a 55" led the only colors is red and green
IS LIKE YOU DIDN'T GET THE SETTING, CHECK YOUR CABLE CONNECTION VERY WELL
Sep 27, 2011 | Televison & Video
How do you switch the illumination color from Red to Green on the pioneer deh-2200ub
Actually you can change the color. Turn the Unit off. Press and Hold MC. The menu will pop up, turn to Ilumi turn it to desired color. It only comes in Red or Green.
Aug 15, 2010 | Pioneer DEH2200UB with iPod Direct Control...
Replacing front turn signal socket on 1990 dodge shadow
Okay. Hook black to black.
Green to green with white stripe.
Yellow to red with white stripe.
That should work. Nothing is going to blow up if it's wrong. It just won't work.
May 15, 2009 | 1990 Dodge Shadow
TV picture is red.
Normal color picture is composed with 3 colors R-G-B (Red-Green-Blue). Picture turns Red means: Missing Green and Blue colors (many reasons: bad contacts, projector tubes dead, and other...). Try to give some "tabs" to diagnose ... I don't know what is the type of your Projection TV, how long you owned it, to have more idea.
May 15, 2009 | Toshiba 57H81 57" Rear Projection...
After a few minutes the color goes to intense red and green
My tv didn't turn green, but the red separated significantly. It started off happening after a few minutes of being on (I suppose the defective part was "warming up"), then it got to where it was like that immediately upon turning the tv on. In my case, I had to pay a tv repair man $350 for a new part. There are 2 microcircuits that control the color alignment--one that controls the red only, and the other controlls the other 2 colors, blue and green I believe. Maybe your part is the blue/green controller, mine was red. The repair man said these parts fail so rarely they don't stock the part. The cost of repair may be different for a different part, but either way you have to choose if it's worth that cost to you. If you get rid of it, I'll buy your tv stand ;-), I bought mine from a friend and didn't get the stand in the deal.
Dec 14, 2008 | Mitsubishi WT-42315 42" TV
Picture calibration settings for 42lg70
Picture Menu
Picture Mode: Expert1
*Backlight: 16
*Contrast: 83
*Brightness: 53
Sharpness: 50
*Color: 55
*Tint: 0
Expert Control
  • Fresh Contrast: Off
  • Noise Reduction: Medium
  • Gamma: Medium
  • Black Level: Low
  • Real Cinema: On
  • TruMotion: Low
  • Color Standard: HD (N/A w/HDMI)
  • White Balance: Warm
  • **Method: 10-Point IRE
    • 10 IRE
      • **Red: 1
      • **Green: 2
      • **Blue: -16
    • 20 IRE
      • **Red: -6
      • **Green: 0
      • **Blue: -7
    • 30 IRE
      • **Red: -5
      • **Green: 0
      • **Blue: -4
    • 40 IRE
      • **Red: -8
      • **Green: 0
      • **Blue: -4
    • 50 IRE
      • **Red: -4
      • **Green: 4
      • **Blue: -4
    • 60 IRE
      • **Red: -6
      • **Green: 6
      • **Blue: -5
    • 70 IRE
      • **Red: -8
      • **Green: 3
      • **Blue: -10
    • 80 IRE
      • **Red: -8
      • **Green: 7
      • **Blue: -16
    • 90 IRE
      • **Red: -9
      • **Green: 5
      • **Blue: -18
    • 100 IRE
      • **Red: -10
      • **Green: 4
      • **Blue: -9
Color Management System
  • Red Color: 0
  • Red Tint: 0
  • Green Color: 0
  • Green Tint: -15
  • Blue Color: 0
  • Blue Tint: 11
  • Yellow Color: 15
  • Yellow Tint: 2
  • Cyan Color: -15
  • Cyan Tint: 0
  • Magenta Color: 0
  • Magenta Tint: -1
lg70 nice tv excellent processor just to bad there is no intensity control on color management oh well still better than what the three s are pushing block out the hype lg will be number 1 in a few years haters are starting to come around and well leds coming,
p.s. i dont work for lg just tired of losers bashing stuff because they dont own it.
im isf certified those settings are right on the money straighter than a ruler
Oct 05, 2008 | Televison & Video
My webcam shows only red
basically we use RGB color system so it contains color like red green and blue....in ur web cam settings u only increased the content of red color and u decrease the content of green and blue...so pls take ur settings and put all three colors to a same number...it means u have number from 1 to 100 and u can give the red green and blue colors up to this limit....so put green in 32 and red in 30 and blue in 32......then it will b corrected
Sep 20, 2008 | Logitech Webcam
Color
Have you looked in back of set to see if the red and green crt's are lit? Also you can turn up the screen control for the red and green to see if there is a problem. If you find problem turn back down. Then problem will be somewhere else. Could be crt board or main.
Oct 06, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Televison & Video Logo
139 people viewed this question
Top Televison & Video Experts
