50 SERVICE error on my HP laserjet 4MV
I stored this machine away about a year ago it was working fine. I pulled it out the other day to begin using it again and this service error showed up. The printer was just sitting in a closet for a year unused. Toner cartridge fairly new. No previous problems with machine other then it running hot which it had been doing since it was originally purchased. Any help with fixing this problem would be greatly appreciated.
  • sheriann723 Nov 14, 2008
    Why softwear? I hadnt even hooked it up to the computer when this error showed up. This message shows up right after the self test stops.
    Problem Solver:
  • 3 Answers
Have you tried looking on the hp website for software updates ? maybe could try reinstalling the drivers for the machine . I don't know if ink dries up while being stored away for so long you might wanna check into that aswell . hope that helps later .
Posted on Nov 13, 2008
What is error message 79 service 01BF?
Restart the printer and try to print the same job, if it fails, try printing a different job, could be corrupt file. Can be bad memory or a bad network card if one is installed, remove memory one dimm at a time to see if the error goes away. Otherwise it is the formatter itself.
Aug 03, 2014 | HP LaserJet 4mv Printer
Will not print.
LaserJet 4V ***If it is intermittent or can be cleared by shutting it off to let it cool. The fuser is running too hot, order rebuilt.***
Notes to remember!!
  • The low voltage power supply is what the takes the 110v ac from the outlet and is for this reason often mistaken as the high voltage power supply. The high voltage power supply HVPS main purpose is to charge the toner cartridge with a much higher dc voltage.
  • Always Remove Power from the printer before working on it!
  • Lamps can break in shipping or if the fuser is dropped.
  • The fusers use floating connectors don't force them in.
Jun 25, 2008 | HP LaserJet 4mv Printer
Hp laserjet 4mv 67 error problem?
67 error is an "internal RAM, scan buffer, Dynamic RAM controller or miscellaneous interface hardware error. That's from the book.
If power cycling he printer doesn't fix it, have the formatter board replaced.
Aug 19, 2011 | HP Laserjet M2727nf Multifunction Printer
HP LaserJet 4MV '50 service' on an HP LaserJet 4MV printer Can it be cleared without resorting to repairs or replacement parts?
You could remove the fuser, turn the machine off, and wait an hour. It may reset the error. However, if the error still persists, it will be a parts replacement of the fuser, low voltage power supply, or the DC controller. 90% it is the fuser. Good luck.
Apr 21, 2010 | HP Office Equipment & Supplies
How can I refill HP4MV,
This is something best left to people trained to do so. There are many components that should be examined and tested, as they wear over time and may need replacing. If you are looking to buy new or remanufactured cartridges, or kits to help you refill it yourself, the cartridge model you are looking for is "HP C3900A". Remanufactured cartridges are available in most larger cities, and will save you a bundle compared to Staples or other big box stores.
May 07, 2009 | HP LaserJet 4mv Printer
HP 4MV Printr and ip address
Scroll through the menus until you get to the I/O section. I don't think vista supports the HP 4MV
Mar 12, 2009 | HP LaserJet 4mv Printer
Repair Kit for HP 4MV Printer - Pick Up Rollers
The ruber tyres on the pick rollers can harden with age, even if you are not using it. Try applying gum turpentine to rubber tyre with Q tip. This is used to keep a printer picking up untill replacemant rollers can be fitted.
Dec 15, 2008 | HP LaserJet 1020 Printer
I can only print by manually feeding in each page -HP 4MV Printer
Good old 4MV.
paper jam is just the way the printer i stelling you "something" wrong with paper feed".
you need to locate a "4MV repair kit" , they are not cheap. but, if you wan to keep the printer, it is worth it.
http://www.fixyourownprinter.com/kits/hp/K78 cost of the ket is $50
includes Instruction CD rollers, and other repairable parts.
Dec 15, 2008 | HP LaserJet 4mv Printer
Hewlett Packard LaserJet 4
Click on the link I provided.
Jul 11, 2008 | HP LaserJet 4 plus Printer
50.1 fuser error on HP 8150 LaserJet Printer
wow if you were an hp certified tech you would know instantly that 50.1 is LVPS also if you were or were not certified you could look at serv man and figure it out right quick
May 30, 2008 | HP LaserJet 8150n Printer
385 people viewed this question
jasbo
jasbo
