Question about Onkyo TX-DS696 Receiver
Remote sensor on Onkyo TX-DS696 receiver
I have an Onkyo tx-ds696 receiver. The remote controller no longer will control the receiver unit. The remote control will still operate the DVD player and the television and I have tried programming other universal remotes to operate the receiver and cannot get any to work with it so I believe the problem is with the remote sensor in the receiver unit. Any suggestions?
  • brutallicapr Dec 26, 2008
    Same problem here but with my Onkyo DVD player. I think the remote sensor is dead.
  • 298 Answers
SOURCE: Onkyo TX DS575x reciever remote problem
You might try this replacement
http://www.remotes.com/remotes/servlet/rs?a=gmi&uid=11953114154530&smodel=TXDS575&brand_pn=ONKYO_TXDS575
Posted on Nov 17, 2007
  • 6 Answers
SOURCE: how to program onkyo tx-sr606 receiver onto remote control
I think onkyo has not come up with codes for game console yet. Codes that are available are for DVR/VCR, CD, DVD, TV. and Setup Box. I need to get the manufacturer of those components that you have for me to be able to determine which code is appropriete for your components.
Posted on Nov 29, 2008
  • 6 Answers
SOURCE: cant find universal remote code for the onkyo tx-sr605
Your onkyo receiver and remote controller only decodes 4 digit codes so what you have to do is to call the manufacturer of the remote controller it self and ask for the hexa decimal codes for their remote. They should provide it to you coz they're the ones responsible on doing that.
SOURCE: Program Time Warner Remote RT-U62CP-1.17 to work ONKYO TX-SR575
time warner does not supply the codes. the equipment manufacturer supplies the code to the remote makers
Posted on Jun 04, 2009
pabloloco
  • 2335 Answers
SOURCE: How to program remote control?
Your Onkyo TX-SR304 receivers remote (RC-645S) is not capable of controlling devices by other manufacturers. It controls only Onkyo devices.
Other Onkyo remotes do have universal remote functionality and you can download Onkyo remote codes here.
I hope that helps.
________________________________________
Download Onkyo TX-SR304 users manual here.
Posted on Apr 20, 2010
Can you use an Onkyo RC-771M remote control to operate Onkyo receiver TX-SR502 ?
Unfortunately, the RC-771M remote doesn't control the TX-SR502. It will only work with these Onkyo models: TX-NR1008 and TX-NR808. The RC-567M is the one for the TX-SR502; replacement remotes that are exact replacements are still available from various places including Amazon.com .
Since the TX-SR502 was released in ~2004, that replacement remote probably won't control other devices that were released in 2004 or later. Onkyo changed its IR code programming before the TX-NR1008 was released in ~2010 and the RC-771M can't communicate with the older receiver. The manuals for the receivers listed above are still available from Onkyo on the product page under the Downloads tab.
I wish that I had better news for you.
Jan 31, 2016 | Onkyo TX-SR502 Receiver
Tip
Not responding to remotes
I've owned an Onkyo DS696 receiver for 5+years. Every once in a while (when it was on for a long time?) the receiver would not respond to the remote. At first it could be "fixed" by a simple power cycle. It got worse over the years, and finally the unit would not respond to the remote at all. After reading a post here that made perfect sense, my husband and I opened the unit up, and (even thought the solder at the IR connection LOOKED fine, we resoldered it. (He knows how to do these things expertly). We screwed the unit back together and VOILA! it works perfectly now. Even if you don't know how to solder, if you brought it to a repair shop and told them exactly what the issue was and how to fix it - you can save your sanity and the unit. The solder joint I'm talking about is directly behind the IR on the front daughter board.
on Jun 28, 2007 | Onkyo TX-DS696 Receiver
My display wont work and my remote quit at the same time
for this problem please call to your manufacturer customer suppport for technician to rectify thre problem because it is the internal problem so i advise do not open the cabinet of your channel receiver
Oct 30, 2010 | Onkyo TX-DS696 Receiver
Onkyo TX-SV525 Receiver - remote channel not working
Could be failure of one or more of the controls you mention.
Dec 27, 2017 | Onkyo TX-SV525 Receiver
Onkyo TX-DS696. No right channel speaker sound
hello there 2 transistor 1 for the right channel and 1 for the left first thing 2 do is a visual check in good light check for any burn't part or any bulging capacitors if everythink looks ok then check underneath the board for dry joints if then you will need a mulitmeter to start testing components
regards
shasun
May 15, 2010 | Onkyo TX-DS696 Receiver
I hope that helps.
Mar 26, 2010 | Onkyo TX-SR304 Receiver
No sound when dvd input is selected on onkio tx-ds696
Make sure your DVD setting is looking at the right audio inputs. Usually there is a menu option or a button to toggle from analog or digital input. Usually when no-sound but video ok, you have the wrong input-type selected. If you are using 2 RCS's (red/white) then you want ANALOG input mode. If you are usung a single RCA (orange) or a fiber optic input for audio, you want DIGITAL input selected. If digital os selected, make sure you plug into the correct digital input to hear. If it does not work at first, mofe the jack/fiber around into the different inputs untill you hear sound, then you will know which port is associated with the DVD setting. Unless it is self evident feom the menu.
Jun 12, 2009 | Onkyo TX-DS696 Receiver
The remote control dosn't work!
I had to remove the batteries of the remote control.
Having done that, the remote control has been reinitialized and worked again perfectly.
Aug 18, 2007 | Onkyo TX-DS696 Receiver
Onkyo TX-DS696 Receiver Logo
308 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
