Question about GE JVM1650 1000 Watts Microwave Oven
Pop in the vent area followed by no heating
When cooking, I heard a "pop" in the vent area when I first turned the microwave on, and now the microwave won't heat food. I did not hear the pop in subsequent tries, although I still can't heat. Could this be a door switch problem? Thanks
  • Anonymous Nov 30, 2008
    no heat when turned on, just spins the turn table.
  • Anonymous Mar 29, 2014
    By turning the vent on and hitting start will only heat the food but if you don't turn the vent on will not heat the food
  • GE Master
  • 9,125 Answers
This is not likely a door switch problem. That pop was probably a part blowing, most likely the high voltage rectifier diode. If you or a friend want to check into and repair this, here is a good link for safety info & do-it-yourself info: http://www.gallawa.com/microtech/diode.html Find & buy GE repair parts here: http://www.geappliances.com/shop/prts/ If that isn't it, please repost with new details. Good luck and be safe. Your rating of this answer is appreciated.
Posted on Nov 18, 2006
Sharp R-1510 1000 watts microwave, not heating
Sounds like the inverter (power supply for cooking) or the magnatron which does the work----neither are cheap parts.
Oct 16, 2012 | Sharp R-1510 Microwave Oven
Own Whirlpool microwave model MH7100XY, everything works on it, however it does not heat anything, heard a small pop and after that it does not warm or cook anything?????
The pop sound is an indicator the magnetron is gone that heats the food. It is cheaper to replace the microwave oven than have it repaired.
Mar 19, 2011 | Whirlpool MH7140XF Microwave Oven
MMV5207AAS stainless_steel 1100 Watts Microwave Oven: I heard a pop and now the micro is not heating but...
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
gdhj
May 18, 2010 | Maytag MMV5207AAS Microwave Oven
Went pop 20 seconds into cooking clock still works turntable stills moves won't heat
Remove the cover and look for a blown fuse. If found, replace the high voltage diode and the 'stirrer' (a fan like device that is inside the sheet metal wave guide near the area where the microwave energy enters the cooking cavity).
Oct 12, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Loud pop and microwave doesn't heat anymore
I have a GE Profile Spacemaker model JVM3670WF001, purchased I think in 2003. Pop sound, no Heat. Light goes on, carousel goes around,
Repair or new microwave
Jun 03, 2009 | GE Profile Spacemaker Over-the-Range...
Will not heat
The loud pop was almost certainly the high voltage diode going bad. To find parts, I suggest you call the number on your owner's manual or check with the store where you bought it. Sunbeam may not make this part available, so be prepared. Maybe they have authorized servicers in your area. Ask them about that. Good luck.
Sep 21, 2007 | Sunbeam SMW777 Microwave Oven
Runs but makes a super load pop sound with flame
It sounds like you're saying a flame and pop came out of the area where the internal electronics are? If that's the case, then I would suspect a failed high-voltage transformer, bad magnetron or that another high-voltage component is arcing, like maybe damaged wiring, but that's rare unless... ... I hate to suggest it, but maybe a "critter" has made his way into the high-voltage section! That can cause some really "interesting" effects! If the flame and pop are coming out of the cooking cavity, then it could be food debris or grease underneath the waveguide cover or in the waveguide. I would say the likliest cause is a failed HV transformer. If it's still under warranty, I'd call Sears right away to verify that. If it's not under warranty, you may want to pull it from the wall yourself and take it in to Sears or another shop yourself. You'll probably save about $50 as opposed to letting them come out to the home to service it.
Oct 04, 2006 | Kenmore 62642 / 62644 / 62649 Microwave...
GE JVM1650 1000 Watts Microwave Oven Logo
109 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
vince
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
