Question about Measuring Tools & Sensors
N0 spark new coil and distributor and still wont start
New coil and distributor spark plugs good and still no spark
  • 3 Answers
Check if you have any voltage going into your coil. If not you have to work you way back from there to battery. If so, the wire coming from your coil might be bad. This happened to me before. Changed the wire for a few dollars and I was set to go.
Posted on Jan 18, 2009
Engine cranks has spark at distributor but wont start.
standing for a while could be stale fuel
efi or carby
is it a points or electronic module distributor
could be coil, or plug, leads points
Jul 16, 2016 | Cars & Trucks
How do i get a spark on a 1987 cutlass salonI it crank but no keeps crankin but it wont start...wat could be da problem???
if the coil is known to be good check in the distributor cap whether power is getting there. if it is there must be something wrong with the spark leads.
Essentially you must work backwards from the spark plug tips towards the battery until you find where the transmission of power breaks down. So check for a spark at the plug tips.
if no power check the centre of the distributor cap, and if no power check the coil. at some point you will find power, the problem then, must be between the place you find power and the next step that should go but does not
Good Luck
Jun 01, 2015 | 1987 Oldsmobile Cutlass Salon
After replacing my distributor on my 89 toyota corolla it wont start
It is possible that if you replaced the distributor, you simply have the plugs in the wrong firing order. Another possibility is that you need new spark plugs, wires, plugs, distributor rotor and possibly a distributor cap. A long shot problem is the ignition coil, but since you have spark in one plug, it is unlikely.
Mar 22, 2014 | Toyota Corolla Cars & Trucks
It turns but it wont start,it has gas and power
Pull off the coil ignition cable at the distributor and check for spark coming out of coil when cranking engine over. Use a heavy rag or glove to hold the wire 1/4 inch from a metal ground. Should see a strong blue spark when cranking to verify ignition is good. If no spark, check for battery voltage to coil on the coil primary. If you have current to the coil, suspect a bad coil, ignition module, crank position sensor, or cam position sensor, or pcm. The coil, ignition module, and sensors can be tested before replacing.
Jan 29, 2013 | Cars & Trucks
Opel ignition problem car wont start
does the igniton switch turn or if dont your gonna have to replace it if the switch turns and it trys to start most likely the distributor is bad somewhere could be the pickup coil could be the ignition module get a new distributor and hope that your ignitio coil is still good if not then get a new coil and you may as well buy spark plug wires and spark plugs
Nov 25, 2012 | Cars & Trucks
Pu t in new coil and distrubtor cap and rotor put in new electronic module not firing wont start
No spark at the spark plug? It may be the pick-up coil inside the distributor. This is the sensor that tells the computer the engine's crank position.
If the ignition switch is good, you should have power at the coil's + terminal when key is on. You might check for that.
May 08, 2012 | 1989 Chevrolet Camaro
1998 Dodge Durango, when starting everything seems to be coming on but it wont fire, (turn over) just replaced battery 4 days ago. Have checked the battery and it appears to be hooked up tight. It does...
If it smells like it is getting gas and then floods check spark plugs see if soaked in gas clean and dry reinstall see if it will start if so you have a weak spark either the coil or the pickup coil in the distributor or both are going bad start with coil then if problem is still there replace distributor and put a new cap and rotor on new distributor good luck
Jan 31, 2010 | 1998 Dodge Durango
Im getting spark from coil...but not from distributor??
Is the rotor burnt through to the distributor shaft, or a bad cap
Feb 28, 2009 | 1986 Toyota Pickup 4WD
Measuring Tools & Sensors Logo
212 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
