Question about Whirlpool Duet GHW9150P Front Load Washer
WATER WILL NOT RUN IN WASHER. ERROR CODE hf showing up
  • 3,230 Answers
F/H No water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
If there is no water in the unit:
1. Make sure that both valves at the water source(s) are turned on all the way.
2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
3. Verify inlet valve operation
If there is water in the unit:
1. Verify Drain pump operation
2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
Verify there is not a siphon problem
Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
Check all hoses for possible leaks
Verify pressure switch operation
Verify flow meter operation
Verify CCU operation.
Posted on Mar 28, 2009
  • 5,911 Answers
The following link explains the "FH" error what steps to take to diagnose and repair:
http://www.fixya.com/support/r615354-fh_error_code_whirlpool_duet_kenmore
There's a lot of information, here, so read through everything thoroughly. This is one of those tricky problems that may have several causes. I hope this helps you. If you require addtional assistance, please let me know.
Posted on Nov 14, 2008
Fh error code wirpool duet washer
Display shows F20 or FH - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...fh-front-load-...
Whirlpool Home AppliancesQuestion: Display shows F20 or FH - Front-load washer. Answer. Image. or. Image. or. Image. This error code indicates a water supply problem. Are both the hot ...
whirlpool duet error code FH - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Jan 5, 2009 - 10 posts - ‎1 author
... Repair Help > Washer Repair » whirlpool duet error code FH .... FH No water detected entering machine or Pressure switch trip not detected. Whirlpool Duet diagnostic code C:03 error code FH
1 post
Dec 5, 2014
Whirlpool Duet Washer HF Error Code
Jun 10, 2013
FH Error Code on Whirlpool Duet Washer
Mar 11, 2013
FH error code
Sep 13, 2008
More results from forum.appliancepartspros.com
Stumped on error code FH for Whirlpool Duet front load washer .
Jan 08, 2016 | Washing Machines
My kenmore elite washer model #110450894 is coding HF please help me thank you
F/H:
Condition
Or
Check/Repair:
  • If there is no water in the unit:
  • 1. Make sure that both valves at the water source(s) are turned on all the way.
  • If there is water in the unit:
  • Verify there is not a siphon problem
  • Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
  • Check all hoses for possible leaks
  • Verify pressure switch operation
  • Verify flow meter operation
  • Verify CCU operation
If this is intermittent, it would be very hard to determine the cause.
I myself have rarely run into this issue, and when I did, it was mainly caused by low water pressure into the water from the customers water supply, or clogged inlet water valve screens.
Nov 21, 2012 | Washing Machines
Whirlpool duet washer fills with water washes for about 12 min then code hf
The FH error code means that the washer has not detected any water entering it. This tip i wrote relating to the FH code covers what to checkto fix it.
http://www1.fixya.com/support/r10423905-fh_code_means_duet_epic_front_load
GENE
Oct 04, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Washer starts and runs for about 10 minutes. Then stops and gives error message HF
Hello & Welcome to FixYa
FH error code is displayed when the control detects no water entering the machine. To clear this error press and hold the PAUSE/CANCEL button twice. You can then check if the water inlet valve is fine and not clogged with foreign particles, try to clean it. If the water inlet valve appears to be fine then check if the pressure switch hose is properly connected to the pressure switch & tub. Please get back to me if you have any questions.
Kevin
Mar 07, 2011 | Kenmore HE3T Washer
Possible causes for HF error. It is in the cold
Hi
Thanks for using FixYa. You are right, FH error indicates an issue with the water supply; this error occurs when after 30 seconds the control does not detect the water entering the machine and the valves turn off & error code is displayed. Check the cold water inlet valve for any clogs and try to clean it, also clean the screens in the inlet valve. If still it’s not resolved then the only option is to replace the valve. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 11, 2010 | Whirlpool Duet GHW9150P Front Load Washer
It has an HF error code. What does this mean?
If after 30 seconds the control does not detect water entering machine, the valves will be turned off and the error code will be displayed.
OR
If the control has turned the water valves on, and after 8 minutes, the flow sensor has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off, and the error code will flash.
Possible Causes / Procedure
- Make sure that both valves at the water source(s) are turned on all the way.
- Check for plugged or kinked inlet hoses or plugged screens in the inlet valves.
- Verify inlet valve operation.
- Verify drain pump operation.
- Verify that the pressure switch hose is in good condition and properly connected to tub
and pressure switch.(make sure the pressure switch hose is not filled with water as well. If so, replace the pressure switch asap).
1. Verify there is not a siphon problem.
2. Unplug washer or disconnect power.
3. Verify wire harness connections to inlet valves, pressure switch, drain pump, flow meter,
and Central Control Unit (CCU).
4. Check all hoses for possible leaks.
5. Plug in washer or reconnect power.
6. Verify pressure switch operation.
7. Verify flow meter operation by blowing air through the part and measuring the resistance.
8. Verify CCU operation by running a Diagnostic test or any cycle.
Replace failed component.
Oct 14, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE3t
Here's a link that explains the "FH" error code:
Read through these steps and let me know if you require further assistance. HINT: I'm assuming you have water entering the wash tub since you mentioned the washer will begin a wash cycle. Check for a siphoning issue or Drain Pump problem first. These are the simplest items to check. I hope this helps you.
PS There should be a tech sheet located inside you washer behind the lower panel under the door, or along the interior cabinet wall that explains all the error codes and how to troubleshoot. This may also assist you further.
Jul 24, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite washing machine
This code means its not getting a sufficient water supply. I was doing a cold wash and noticed it was sucking down some hot water, so shut off the hot. MISTAKE, after a little bit the HF code came up. Apprently it likes to decide for itself just how cold is cold. Darned Computers.
To make a short story long, when I shut off the hot, it apparently shredded the washer and sent the remnants down to the little filter thingy at the washer itself, whereupon they reassembled themselves into a clog, once again giving me the HF code.
(Check your user manual Troubleshooting section. I think it says to press Pause/Cancel twice)
Mar 30, 2008 | Kenmore Elite 45986 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
177 people viewed this question
Dan Webster
Dan Webster
Sal De
