Question about Garmin GPS
Battery does hold charge and blows out the fuse in the outlet in our car
  • 2 more comments
  • tuffylynn Nov 13, 2008
    this is a streetpilot c340
    i do not know where the battery is located
    where is the battery located?
    thank you very much
    President:
  • 624 Answers
You have a problem with the GPS unit that is going to require service by a professional. It has at least one bad component in the power supply of it that is causing the unit to blow the fuse in the car. It is unlikely that the battery is causing that. It could be in the charging circuit, but without a multimeter and then opening it up and checking some components, there is no way to figure out exactly what is causing it. If you have a multimeter and are familiar with electronics it may be able to be fixed by you. If you are not able to do this you should just take it to a service center. If it is under warranty you should not even open it up, it will void your warranty, just take it to a service center.
Posted on Nov 13, 2008
  • Garmin Master
  • 13,433 Answers
How is your warranty on the garmin? I would suggest if its under warranty to remove it from your car and send it over to garmin, contact them first for free warranty repairs, also check your cables, if your cables are cut or if there a short circuit.. incase the cable is cut it might blow out the fuse.. thats one possible reason for blowing out the fuse.
    President:
  • 2,712 Answers
I think you will have to replace the battery.
  • Swilin Sampson
    Swilin Sampson Nov 13, 2008
    It is located within the unit. However, I wouldn't recommend opening it up yourself. Its best to take it to service center for repairs, as there is very complicated circuitry within.
Lead acid Car battery was charged with polarity reversed. Can it be re-charged correctly? It blows the charger fuses??
a lead acid will not charge with the polarity reversed
What happens is that in dead shorts and can destroy the battery
it can blow up the battery , blow the charger fuses and destroy the charger
Depending on the damage to the battery cell plates it may be recoverable
Mar 30, 2018 | Cars & Trucks
Every time I plug my phone charger in power outlet the fuse blows. hyundai sonata 2013 why
I would just run two new wires from battery , and fit an after market cigarette lighter socket to you car . or just run the wires to the existing charging socket , and remove the factory ones . then you could use a heavier gauge wire and fuse . this is just an idea .
Mar 28, 2014 | Vehicle Parts & Accessories
My Everstart Maxx Jump Starter 500 amp will not charge and it beeps every 5 seconds unless I pull out the fuse? What is the problem?
I don't think they read the problem right. His charger will not hold a charge, not the car. I'm having the same problem. My charge will not charge when I plug it up to a outlet.
Dec 02, 2012 | Cars & Trucks
I have a '97 Subaru Outback Legacy that has a problem with cigarette lighter/dc outlet. The outlet works fine when using the lighter. The lighter heats up and turns red. However, when using a char
You can purchase a specific charging socket extension at most car accessory outlets. It can be wired to the car's battery, or as an extension of another heavy load circuit such as the cigarette lighter and this is a very inexpensive item and is reasonably easy to instal.
Nov 01, 2012 | 1997 Subaru Outback
Battery not charging,cooling blowing fuse
Disconnect the fan motor and see if the fuse still blows, if it doesn't you may have found the problem and the fan needs to be rep[laced a 30 minute job just a few bolts..
Oct 31, 2012 | 1992 Chevrolet Camaro
How to fix the alternator belt back in place?
First unhook the negative battery cable so you do not blow the $20 alternator fuse. Loosen the bolt holding the adjust BLOCK in place on top of the alternator. Loosen the bolt holding the bottom of the alternator to the motor. Now you can use the adjuster bolt to slide the alternator over and out the belt back on . This is what you have to do to adjust your belt also. If you short the back of the alternator while tightening or loosening the lower bolt it blows an expensive fuse on the positive terminal of the battery(dealer only part)and your battery will not charge , no warning light, and your battery will go dead stranding you. When this happens a jump start will not help. A fully charged battery might get you home before it goes dead. Be Careful.
Sep 29, 2010 | 2006 Mitsubishi Galant
Mazda tribute 2001 Battery goes flat occasionally with lights left on for about ten Minute. Battery has been checked all ok. Also Cruise control engages but nil op. A fuse will also blow about every 2...
Yes a short somewhere But where?
A battery should hold lights on for a while and not go flat but then what size battery have you got and how much dose it charge when driving as it should hold 12 volts and when running it should charge at 13.5 volts no more ,,,But a short in the lights weather Head/or/Parking lights would burn out the wire ,blow fuse every time you turn on lights.....
Sep 30, 2009 | 2001 Mazda Tribute
RAV4 Charging Cell Phone Causes Fuse to Blow
have never heard of a vehicle that can't be used to charge a cell phone but if that's what the dealer said, they usually know something about the vehicles they sell. i can suggest a work around but it might be you won't like it. you can buy a 12v jumper pack, it's really just a battery in a plastic case that can be used to jump your regular 12v car battery in the event that you can't get the car started from the regular battery under the hood. they are available in a few different sizes, they have them at car parts stores and dept. stores, you plug it in at home and it charges up overnight, then take it in the car with you just in case. every one of these that i have ever seen has a 12v outlet on them. some of these are quite heavy but you don't need a big one and you probably won't need to charge it more than once or twice a week just running a cell phone charger off it. i will admit that it is not as convenient as plugging it into your car but it won't blow a fuse and i'm pretty sure it would work. hope that helps
Jun 10, 2009 | 2001 Toyota RAV4
Blowing Fuses
your starter is going bad have it check out,
Dec 18, 2008 | 2003 Ford Focus
GPS Logo
20 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
