Low ink light will not go off after refining HP94 ink cartages
    Scholar:
  • 181 Answers
The message of low ink cartrige always appears after refilling the cartridge or installing the recycled cartridge.only if u install orignal cartridge it will go.but let it show low ink you will get proper printouts till the end of the cartridge as this message does not effect on copy quality or number of printouts.the printer will work.just cancel that message or ignore.it will not effect your printer.
thanks.
Posted on Nov 13, 2008
Just installed CISS unit in NX125 as per makers instructions but it will not reconise cartridge unit and ink light burns continuous.
I beleive that you will need to remove it and install it again. WHat has happened is that your printer dose not recognize the cartage. I had the same problem with my Epson printer. But once I re-intalled the CISS, it works fine. When the ink is low I run my Cleaning Program in the Epson, this will re-fill the empty cartage.
Apr 06, 2011 | Office Equipment & Supplies
How to I change ink on epson printer NX127 I cannot get the cartage out Can you show me the picture of the cartage ink holder with the lid up
First make sure the printer is on, then open the printer cover and the cartridge cover. Then press the Stop button. Assuming the printer has identified a cartridge with low ink, that cartridge will be moved to the replacement position; then the power light will flash. Squeeze the tabs on the ends of the cartridge together and lift it up. Unpack the new cartridge and remove the tape carefully. Then press the new cartridge into place until it clicks.
If more than one cartridge has low ink, the leftmost one will be in the replacement position when the cartridge carrier stops moving. Press Stop again to advance the carrier to put the next low cartridge into the replacement position. Then press Stop again to have the printer move the cartridges to the home position and charge the print head. When the lights go out or stop flashing, close the cartridge cover and the printer cover.
If the cartridges aren't low on ink, then use the Epson printer utility (under the Maintenance tab) to start the process.
For pictures of the Epson printer during ink replacement see: http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_SessionID=@@@@1558177770.1297529968@@@@&BV_EngineID=ccdcademkhmjkgicfngcfkmdhjidfmh.0&cookies=no&infoType=FAQ&oid=150187&prodoid=63088089&foid=157388 . Alternataively, see http://files.support.epson.com/htmldocs/nx125_/nx125_00ug/wwhelp/wwhimpl/common/html/wwhelp.htm?context=Epson&file=Ink.7.1.html .
I hope this helps.
Feb 12, 2011 | Epson Office Equipment & Supplies
I had low ink and changed the ink cartage but i still can not print. also a light is flashing it looks like a tear drop. this is on a HP Deskjet D2545
Go in to your HP solutions center and click maintenance. Click on clean printer nozzles. If the printer was low for a while the nozzles may be clogged with dried up ink.
Jan 01, 2011 | HP Deskjet D2545 InkJet Printer
Low ink indicator light after installing new cartridge
go to the control panel, open printer, select your printer, then options, then maintance, somewhere you should see, Did you change the printer cartage? click yes.... close it up your done
Apr 03, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Red paper and ink lights blinking
red paper light is blinked as it is indication that plz insert paper in your printer, and ink light blinks because your printer is low on ink, kindly get your printer cartage refilled.
Mar 19, 2010 | Epson Stylus 1400 InkJet Photo Printer
My scanner won't work because no ink
I highly recommend then that you get a new ink cartage.
Jan 22, 2010 | Kodak EASYSHARE 5100 All-In-One Printer
Epson nx105 has new black cartridge but cyan out. we just want to print black ink but it will not print at all b/c one is low. any suggestions?
you can change the setting in the printer prefaces or do what i did keep an empty color cartage in the color slot and a good black cartage in its slot.
Dec 29, 2009 | Epson Stylus NX105 All-In-One Printer
Compatibles wont work
Try this:
The HP all-in-one product will print black copies using both the color and black cartridges to create composite black in Normal and Best modes. This is necessary to create the correct grayscale shades.
  1. The color cartridge may be out of one color of ink. Perform the steps in the 'Colors are not correct' section above to verify that the ink cartridges are not low on ink.
  2. Verify that the correct paper type is selected in the Paper Type setting.
  3. Some photo paper has different chemical characteristics than Hewlett-Packard paper. The HP all-in-one is designed for use with HP Premium and Premium Plus Photo Paper. The photo paper, paper-type setting should be used with HP Photo Paper. For other paper brands, it may be necessary to use the plain paper or premium Inkjet paper, paper-type settings.
OR: The ink cartage you have may be defective if is a refilled or recharged cartage.
Jun 17, 2009 | HP DeskJet F380 All-In-One Printer
Ink Cartage CYAN for Brother Printer Model MFG 440 CN replaced
IssueAn 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution
Press the On button to turn the printer off.
Unplug the power cord from the back of the printer.
Remove all the ink cartridges.
Wait two minutes.
Plug the power cord into the back of the printer.
Press the On button to turn the printer on.
Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved.
If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
Dec 07, 2008 | Brother MultiFunction Center MFC-440CN...
Ink cartage replacement
could you please give us the brand name and model no.?
Nov 13, 2007 | Office Equipment & Supplies
203 people viewed this question
jasbo
jasbo
