Program won't print
I have an Epson Stylus C88 printer installed at the default printer on my Vista 64-bit system. PrintMaster Platinum 18 does not recognize my printer and won't install it for use with the program. It keeps telling me over and over to install it. I've attempted sevedral times and even printed a ''Test'' page, but when I go back tso print, it's the same thing all over again.
All my other programs have no printing problems.
Any ideas?
Broderbund is no help at all on their website forthat product.
  • 3 more comments
  • willfrost Nov 14, 2008
    I've already installed the Vista drivers for my printer. The printer works with all my other ptograms but does NOT work with PrintMaster Premium 18.
    Did everything up to the "Graphics or Color" tab. Neither of those exist. I have a "Color Management" tab, but none of the things you suggested were available.
    Again: program is PrintMaster Platinum 18
    OS: Vista Home Premium 64-bit
    Printer: Epson Stylus C88
    Problem: PrintMaster program does not install the printer and does not print. I've followed the on-screen prompts to no avail.
    The printer works fine with all my other programs and is set as thnedefault printer.
    All required drivers are up-to-date.
    TheBroderbund website is of no practical use.
    That number for Broderbund . . . I've called it several times - they offer NO software support.
    I've even emailed them but hav received no response.
  • willfrost Nov 16, 2008
    I have uninstalled the program and reinstalled it several times.
    The printer works just fine with all my other programs.
    Despite what Microsoft Vista 64-bit compatibility site says . . . PrintMaster Platinum does NOT work with Vista 64-bit.
    In addition to the printer not working . . the Help files don't work and the PDF converter doesn't work either.
    I finally contacted Broderbund, but they couldn't really help either.
  • 4,806 Answers
The main problem is the X64 drivers, they don't seem to work properly even if you visit the maufacturers website for the official drives.
i have had nothing but problems with drivers for both XP X64 and Vista X64
you can try always check to see if the printer supports X64 at all
Posted on Nov 16, 2008
    Sergeant:
    Champion:
  • 347 Answers
It seem it is just a problem between PrintMaster Premium 18 and your printer.
Try to uninstall PrintMaster Premium 18 and your printer driver.
Then install your printer, and then install PrintMaster Premium 18
Good luck,
Dahaka
    President:
  • 1,952 Answers
In-Box = Drivers are included with Windows Vista. Just connect your Epson product to your computer and follow the on-screen instructions that Windows Vista displays to guide you through driver installation. Windows Update = Drivers are available using the automatic software update service built into Windows Vista. Just connect your Epson product to your computer and select Locate and install driver software (recommended) in the window that appears. Your Epson product drivers install automatically. (You may need to select this option more than once during installation). Download = Drivers are available for download from the Epson support site. Click the product name to go to the Download page for that product. Be sure to select the correct driver type for your version of Windows Vista: either 32-bit or 64-bit. To see which version of Windows Vista you have, click the Start button, Computer, and System Properties, then check the operating system version listed under the System heading.
Posted on Nov 14, 2008
  • mohammed marika thambi
    mohammed marika thambi Nov 17, 2008
    check whether ur printer port is enable in device manager
  • 1,879 Answers
Here's the reason:
Your VISTA printer driver is provided by MICROSOFT and is somewhat like a Generic driver (see www.epson.com/vista).
PrintMaster Platinum 18 looks for manufacturer provided printer driver that have settings and features that photo editing suites requires to produce superb printouts. One example as you can see noted at the bottom part of the PrintMaster Platinum 18 website (see http://www.broderbund.com/jump.jsp?itemType=PRODUCT&itemID=1978) * Borderless printing with compatible printers only.
For now, hoping that one of the companies involved (Epson, Microsoft, Broderbund) would release a patch to make it work.
  • 734 Answers
Ok
u should download the latest vista 64 bit driver for ur printer from given web link
http://down3.driversdown.com/Printer/epson11889.exe
first uninstall ur printer driver and install again from downloaded file..
second uninstall PrintMaster Platinum 18 and install it again
now ur problem will be solved..
    Scholar:
  • 126 Answers
Try uninstalling Printmaster program and reinstalling it. I know it sounds generic but sometimes after trying all the other options and not having them work makes us forget about just uninstalling and reinstalling. Something may have gotten corrupted with the the fix attempts. Let me know how it turns out for you.
    Sergeant:
    Champion:
  • 331 Answers
There seems to be no problem with your printer as you have said
so either the Printmaster software is not supporting the Printer or maybe there is some fault in the installation
If it is not a big problem to you could you please try to reinstall the software and see what happens?
please do post back the results.
  • 88 Answers
Step 1:
- Click on Start and Go to the Control Panel then click on Printers.
- Right-click on your Printer and choose Properties.
- Under Printer Properties, select the ADVANCED tab
- Click on the PRINT PROCESSOR
button towards the bottom of the window
- Change "Default Data Type" to RAW (it may already be on this setting). Click OK.
- Click on Print directly to the printer located in the center of the window. Then click on OK.
- Now Select the GRAPHICS or COLOR tab. If there is an option for RASTER MODE, select this mode.
- Then lower the DPI setting and click on OK.
- Also, make sure that the Print Mode is set to Normal and not Best.
- Close the Printer Properties window by clicking on OK.
- Set the printer as default Printer. Right-click on the Printer icon in the Printers Window and select "Set as Default" to place a check mark by this option.
and restart your system and whole printer unit also
thanks for trying fixya.com
  • 1.Change "Default Data Type" to RAW (it may already be on this setting). Click OK.
    2.Click on Print directly to the printer located in the center of the window. Then click on OK.
    3.Now Select the GRAPHICS or COLOR tab. If there is an option for RASTER MODE, select this mode.
    4.Then lower the DPI setting and click on OK.
    5.Also, make sure that the Print Mode is set to Normal and not Best.
    6. Close the Printer Properties window by clicking on OK.
    7.Set the printer as default Printer. Right-click on the Printer icon in the Printers Window and select and check for A Right Mark .
    follow the instruction by clicking on the below link
    still you didnt solve the problem you go to the link.
    and follow.
    http://www.epson.com/cgi-bin/Store/suppo...
    .Select your model no. so that you can update to windows vista drivers:
    and
    For further help .
    THIS is the contact no. 319-247-3325.inform me about your feed back
    thanks for tying FIXYA.COM
  • AND FINALY YOU CONNECT The printer in to another machine .and try it if not ok you assume your printer inside haveing any fault.
  • 94 Answers
Step 1:
- Click on the PRINT PROCESSOR... button towards the bottom of the window
- Try to print from the program.
    Genius:
  • 3,422 Answers
You will have to install the vista drivers for your printer to work.
I will give you the link to download it.
  • 2 more comments
  • Priya darshan Nov 14, 2008
    You will have to follow the instruction by clicking on the below link.Select your model no. so that you can update to windows vista drivers:
    ok.You will have to contact the customer support of Printmaster to know if your printer is compatible with their software.If it is compatible they will give you a patch to download and install it.
    I will let you know the contact info.
    Here is the contact no. 319-247-3325
    If you need anymore help let me know.
I have an wireless Epson NX 230 printer 32 bit printer with Win 7 operating sys Emachine 64 bit desktop. Printer driver process says operating system does not support the driver. Test page does not...
Officially MS says it's not support, and Epson does not have an updated driver. Sorry.
If I'm running a 64-bit version of Windows, do I need 64-bit drivers for my devices?
Yes, all hardware devices need 64-bit drivers to work on a 64-bit version of Windows. Drivers designed for 32-bit versions of Windows won't work on computers running 64-bit versions of Windows.
Description: This file contains the Epson Stylus NX230 Printer Driver v6.91. The Epson Status Monitor 3 is incorporated into this driver.
Compatible Systems: Windows 7 32-bit, Windows Vista 32-bit, Windows XP 32-bit
Aug 30, 2012 | E-Machines Computers & Internet
I have windows vista. epson stylus cx4200 will print but does not scan. installed windows 7 64 bit drivers but not successful. need help. thanks
Download & install the "Epson Stylus CX4200 All-in-One Printer" @ Drivers and Utilities Combo Package
Windows 7 64-bit compatible, Windows Vista 64-bit
epson13071.exe - 20.9MB
- posted on 07/07/09
This file contains everything you need to use your Epson Stylus CX4200 with Windows Vista 64-bit.
This package consists of the following items:
•Printer Driver v6.5
•Scanner Driver v3.04
•Epson Status Monitor 3
•Epson EasyPrint v3.10
Uninstall your previously installed AIO drivers before installing the downloaded installer.
Hope it helps.
Jun 02, 2011 | Epson Stylus CX4200 All-In-One InkJet...
I have Print Master Platinum 10 and my Windows operating system is Windows 7 are they compatiable? I tried installing the program but it doesn't install. Is this program too old for this operating...
I don't think Printer Master Platinum 10 will run on Windows 7. However, solution #3 on this page (http://www.fixya.com/support/t2129564-printmaster_platinum_10_version_will_not) references how to make it run on Windows Vista. The same is true for Windows 7. You can run almost any software in compatibility mode. Since they're up to version 18, I doubt it will work with Windows 7.
Hope this helps.
May 29, 2011 | Broderbund PrintMaster Platinum
WE WANT WINDOWS 7 EPSON PRINTER R230X
Epson Stylus Photo R230 6 Colour Inkjet Printer files Driver Printer Driver 6.52E
Windows 2000, Windows 7, Window Vista, Windows XP Posted: 24/11/2009
Click here Utilities Epson Easy Photo Print 2.23.01
Windows 2000, Windows 7, Windows 7 64-bit Edition, Window Vista, Windows Vista 64-bit Edition, Windows XP, Windows XP 64-bit Edition EPP_22301_EHKT.exe
Posted: 19/1/2011 Download
Feb 05, 2011 | Epson STYLUS R230 InkJet Photo Printer
I have chnged my computer system form XP to Window, now I cannot install PrintMaster Platinum Version 17? Is there any way that I can istall this program disc?
Thank you for your question.
In this instance it is easier to direct you to a video on the "Microsoft" website regarding installing older programmes. This is much clearer than trying to explain in writing.
http://windows.microsoft.com/en-us/windows7/Make-older-programs-run-in-this-version-of-Windows
All the best with your install.
Kind regards
Jul 20, 2010 | Broderbund PrintMaster Platinum Version 18
Why don't they make a CreataCard ''Gold'' that works using VISTA?? I missing this great program
Create a Card is a discontinued product.
Encore has new PrintMaster® Gold Version 18 ($19.99) and PrintMaster® Platinum Version 18 ($39.99) programs, both with Vista support :
http://www.encoreusa.com/products.aspx?SearchTerm=create+a+card
Aug 16, 2009 | Computers & Internet
My Epson RX 620 will not print anything from the computer with Vista
Have you tried running a print test page? Have you gone to epson.com website to see if they have printer driver available for your printer...
www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=44341&infoType=Downloads -
Jun 16, 2009 | Epson Stylus Photo RX620 All-In-One InkJet...
I have the Printmaster Platinum Version17 , I cannot save to pdf files?
As a work around untill we can figure this issue out. http://www.acrosoftware.com/Products/CutePDF/writer.asp
This is a FREE PDF Print to file program.
At the top left of the page the are links to the PDF Creator and the Required GPL Ghostscript 8. The program will not function without it. Both programs work with x64 Vista. Read the website for the other benifits or the program.
Apr 01, 2009 | Broderbund PrintMaster Platinum Version 18
Printer printing more then what is needed
while uninstalling the epson driver it will ask you for delete the setting or do you want to keep it. if you select keep it, it will happen how many times you install the driver. Check the printer settings in printers and faxes window, select printer go to printing preferences, page layout and check whether you give no. of copies to 2 there.
May 06, 2008 | Epson RX595 Photo All-In-One Printer
41 people viewed this question
jasbo
jasbo
