A second LAN icon appeared in the system tray; when i try to connect to internet everything freezes; in 'network connections' there is an additional 'internet gateway' and if I try to disable it, it says unable to disable as this connection trying to connect, or something to that effect.
  • 4,806 Answers
If you have installed bluetooth you will get a second icon, you'll have to go to the network settings in control panel to see which one is which
Posted on Nov 13, 2008
Not connect to the wifi
Locate the Wireless LAN switch located on the front of your Acer Notebook. This could be located on the upper row on a laptop it will have the radiation look ((())) Make sure its pressed on. Move the switch to the right to turn on Wireless connections. Right-click the network icon located on the system tray next to the clock. You should see a list of available wireless networks. Select the network you want to connect to and click "Connect."
or
Power on the Acer Aspire laptop. Right-click the wireless Internet icon in the lower right corner of the desktop. Select "Enable" from the pull-down menu. Right-click the wireless icon again. Select to view all available wireless networks in the area. Momentarily a window appears with all of the available Wi-Fi networks. Select the Wi-Fi network you want to connect to, then type in the password (if required). Click "Connect," and your Acer Aspire computer connects to the Internet. Hope this helps.
Jan 16, 2013 | Acer Aspire 3690 Notebook
Turn on WIFI on Aspire 3620
or
hope this helps
Oct 11, 2012 | Acer Aspire 3620 5560 TravelMate 2400 2420...
Wireless lan not working on my acer aspire 4520
The wireless feature (Wireless LAN) on an Acer notebook allows you to connect to available networks. This convenience allows you to use the Internet with network cables, modems or network installation. Acer laptops come with a wireless switch to turn the wireless feature on or off. Once you enable the wireless feature, your Acer notebook can connect to wireless networks within range.
Instructions:
1.Locate the Wireless LAN switch located on the front of your Acer Notebook. Move the switch to the right to turn on Wireless connections.
2.Right-click the network icon located on the system tray next to the clock. You should see a list of available wireless networks.
3.Select the network you want to connect to and click "Connect."
Sep 07, 2011 | Acer Aspire 4520-5582 Notebook
Internet connection setting for Belkin N wirelss modem router
If you can connect to the internet without the connection icon in the system tray, I think its fine. But if you really want to see the blinking icon, go to start>control panel>netweok and internet connection>network connection. There you can see the local area network icon. Right click on it and then properties. A new window will appear, make sure the "show icon in notification area when connected" is checked. Thank you and good day.
Apr 25, 2010 | Belkin (F5D8231-4) Wireless Router...
No internet connection
if you are worried about the icons that are sown in the tray system ( lower right in the task bar ) those are showing the other connections that are not working at the time ...for example the LAN cable conection ...and the blue tooth ..those will appear not connected if you have no cable on the Lan card or blue tooth device connection ...even if you are connected via wireless those will appear unless you choose to unchecked the show in tray ...
if you are asking about the connection you have made wireless and it doesnt work ...you probably have a driver problem ..just reinstall the driver for the wireless card if you know that the connection should work ...if you have acces on the net wireless those icons that are x-ed on the right on the task bar are for the other connection methods ..so do not worry ..
Jan 06, 2010 | Sony VAIO VGN-CR320ER Notebook
I have just bought idea pad y530,3gb ram. I am unable to make LAN connection (both wired and wireless), so i am unable to use internet service. But i am successfully using the internet service for other...
make sure the LAN port is enabled in the idea pad and use a known good cord and port. Go unplug a working station and see if the new unit attaches. If not the problem is in the idea pad. If it does then go back and look at the Lan connect.
Jan 06, 2009 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Have just bought a computer second hand and have just got internet running with 100% signal but cannot connect because we cannot find local area connection to access files
As dragoness1 says, you don't need a LAN to connect. Right click wireless icon in system tray (bottom right of screen), select "show available Wireless networks". Select one and click connect. If they're not from your own Internet service, they may be protected by a password.
Dec 22, 2008 | WiFlyer - Portable, shareable WiFi base...
PPPoE over Edimax BR-6104K without a modem
I am not sure if I understand you well.
You say:
My Internet is a PPPoE broadband connection but I don't have a modem installed.
What do you mean ?
You have a Broadband/ADSL modem, but you didn't install any software for it ?
(It is probably not necessary.)
So, I assume you do have a modem. You connect your modem to the wall outlet with a telephone cable.
Then then modem is connected with LAN cable to one of your PC with two NICs, you make Internet Connection Sharing, and ten from the second NIC of that PC, you connect (again) with LAN cable, your second PC.
If it is an ADSL or Cable modem connected with LAN cable, please follow this steps.
First RESET your Edimax router and disconnect all LAN cables if connected.
Connect your PC (the one with one NIC) to one of the 4 LAN ports of your Router wit a LAN cable.
Open My Network Places and then View network connections, or go to Control Panel and open Network Connections.
Right-Click on your LAN adapter and choose Properties, then double-click on Internet Protocol (TCP/IP)
Set to 'Obtain IP address automatically' and 'Obtain DNS server addres automatically' (click OK). Now you are back to the previous window. Click and check (if it is not) 'Show icon notification when connected' and once again click OK.
After a fiew seconds you should get (near to the clock in the the right bottom of your desktop), a Network icon and a baloon message that your NIC is connected.
Right-click on the network icon and click STATUS, a window will open
and then click on SUPPORT tab.
You should see:
IP Addres: 192.168.2.100
Subnet Mask: 255.255.255.0
Default Gateway: 192.168.2.1
Open your browser and type http://192.168.2.1
Now login as:
admin (default)
and password is: 1234 (default)
Click on GENERAL SETUP on Top-Left, and then on WAN (on the right side) and choose
PPPoE.
Click on 'More configuration'
Type your User Name and Password you have from your ISP.
Now Click on APLY, and again APLY !
The Router will restart in 30 Sec, and your NIC will reconnect.
Now connect your Modem to a WAN port of your Router with LAN cable. (***)
Now:
if you've typed your User Name and Password correctly in PPPoE fields,
and
if everything is OK with the service from your provider,
you should now be on Internet.
If not, then please check your User Name and Password with your Internet Service Provider, and ask them if they can see your router.
Now, get to the PC with two NICs.
Go to Control Pannel, and go to Network Connections.
Right-click on one of your NICs and click 'Disable'.
Check the other NIC if 'Internet Protocol (TCP/IP)' settings are set to Obtain IP addres and DNS - Automatically, and 'Show icon notification when connected' and once again click OK.
Connect the (enabled) NIC with LAN cable to another port of your router.
The second PC should be on Internet, too.
If you (somehow) realy don't have a modem, but you have a cable only, follow the above instructions to the point (***) and connect the cable to the WAN port of your router.
That's it!
Regards
Aug 28, 2008 | Edimax BR-6104K Router (br6104k)
Router
The setup page for a LinkSys Router is normally accessed using a browser addressed to 192.168.1.1. If for some reason "Page can not be displayed or Connection has timed out" shows up, perhaps the reason is that the PC is not on the same network as that of the router.
A couple of things you can try:
1. Run the PC to the router using LAN cable and not WiFi;
2. In your Network Connections (Control Panel), right click on your Local Area Connection, click on Properties, highlight Internet Protocol (TCP/IP) and click on the Properties button.
3. In the next pop-up window, tick "Use the following IP address". IP address - 192.168.1.2, Subnet mask - 255.255.255.0 and Default gateway - 192.168.1.1, OK, OK.
4. Make sure to check "Show icon notification..."
5. In the Networking icon in the System Tray, right click and click on Repair.
6. Try your browser now on 192.168.1.1.
If your concern has not been corrected after completion of the above procedures, possibilities are:
i. your PC's LAN card is at fault (hardware or drivers);
ii. the LAN cable would require replacement;
iii. the LinkSys router is at fault.
A sure way to verify network connectivity between router and LAN card/PC is when properly connected, the router's led display for that particular Ethernet port will light up and/or blink.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 24, 2008 | Computers & Internet
Can't connect to internet
The issue could be with the wifi connection that your wifi adapter is connected to. If your running a windows based system, go to the system tray and right click on your wifi connection symbol (SSID) and see which network your connected to. Every LAN has its own unique name of their Local area network (LAN), if its not displaying your LAN SSID name but a different SSID name then thats the problem. If thats the case, then once again right click on the wifi connection symbol in the system tray and change the wifi connection to your SSID for "view available connection". Your wifi adapter could be picking up a wifi connection in your area and you do not have access to their LAN.
Sep 05, 2007 | Edimax (ew-7128g) 802.11g/b Wireless...
Open Questions:
NY-LA1877/778/89-69Norton Antivirus Tech Support Phone Number? 1-877-778-89-69 Nortan Antivirus service phone number is solve the matter of virus's. 1-877-778-89-69 is loosely used in USA. It offer the ability of 24*7 services. Nortan Antivirus customer care service number's executive able to solve the any virus problem with the assistance of Nortan antivirus support phone number.It doesn't matter from wherever you and at what time you need help. For know about us:-1877+778+89+69 If you want to the best solution for your Antivirus problem you must call our technical phone number 1-877-778-89-69. Our technical experts suggest you to fast and easy way to protect your device. Just Dial Our TollFree Number 1-877-778-89-69 and get full protection for your device.In case of any Antivirus problem must dial our Nortan Antivirus Support phone Number:1-877-778-89-69. Norton Antivirus Support Phone Number, Norton Antivirus Customer Service Phone Number, Norton Antivirus Tech Support Phone Number, Nortan Antivirus support Helpline Number, Nortan Customer support Telephone Number.Nortan Helpdesk number,Nortan Tech support Telephone number,Nortan Antivirus Tech Support Number,Nortan Internet Security Customer Number,Nortan Customer Service Technical Support Number. Norton Antivirus Support Phone Number Norton Antivirus Customer Service Phone Number Norton Antivirus Tech Support Phone Number Nortan Antivirus support Helpline Number Nortan Customer support Telephone Number Nortan Helpdesk number Nortan Tech support Telephone number Norton Antivirus Tech Support Number Nortan Internet Security Customer Support Number Nortan Customer Service Technical Support Number. Norton Antivirus Support Phone Number Norton Antivirus Customer Service Phone Number Norton Antivirus Tech Support Phone Number Nortan Antivirus support Helpline Number Nortan Customer support Telephone Number Nortan Helpdesk number Nortan Tech support Telephone number Norton Antivirus Tech Support Number Nortan Internet Security Customer Support Number Nortan Customer Service Technical Support Number. Norton Antivirus Support Phone Number Norton Antivirus Customer Service Phone Number Norton Antivirus Tech Support Phone Number Nortan Antivirus support Helpline Number Nortan Customer support Telephone Number Nortan Helpdesk number Nortan Tech support Telephone number Norton Antivirus Tech Support Number Nortan Internet Security Customer Support Number Nortan Customer Service Technical Support Number. Norton Antivirus Support Phone Number Norton Antivirus Customer Service Phone Number Norton Antivirus Tech Support Phone Number Nortan Antivirus support Helpline Number Nortan Customer support Telephone Number Nortan Helpdesk number Nortan Tech support Telephone number Norton Antivirus Tech Support Number Nortan Internet Security Customer Support Number Nortan Customer Service Technical Support Number. Norton Antivirus Support Phone Number Norton Antivirus Customer Service Phone Number Norton Antivirus Tech Support Phone Number Nortan Antivirus support Helpline Number Nortan Customer support Telephone Number Nortan Helpdesk number Nortan Tech support Telephone number Norton Antivirus Tech Support Number Nortan Internet Security Customer Support Number Nortan Customer Service Technical Support Number. Norton Antivirus Support Phone Number Norton Antivirus Customer Service Phone Number Norton Antivirus Tech Support Phone Number Nortan Antivirus support Helpline Number Nortan Customer support Telephone Number Nortan Helpdesk number Nortan Tech support Telephone number Norton Antivirus Tech Support Number Nortan Internet Security Customer Support Number Nortan Customer Service Technical Support Number. Norton Antivirus Support Phone Number Norton Antivirus Customer Service Phone Number Norton Antivirus Tech Support Phone Number Nortan Antivirus support Helpline Number Nortan Customer support Telephone Number Nortan Helpdesk number Nortan Tech support Telephone number Norton Antivirus Tech Support Number Nortan Internet Security Customer Support Number Nortan Customer Service Technical Support Number.
May 24, 2017 | Norton Computers & Internet
Computers & Internet Logo
32 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
