Question about Samsung PCL5415RB 54" Rear Projection Television
Samsung pcl5415rb convergence problems
I replaced both convergence ic's as suggested. didn't fix anything, same problems bowed screen, triple image. Tried perfect focus before changing the ic's and it says no sensor data and does the same afterwards. Should I just break down and buy the whole convergence amp module or push it to the curb? Could it be the pico fuse? Any help would be greatly appreciated. Thank you.
  • ladywinn
    ladywinn May 11, 2010
    Do you still need help with tv,and did you ck 3.9 ohm resistors 2or3 of them?
  • Samsung Master
  • 3,459 Answers
If you bought a kit from sites such as TvRepairKits.com go back and ask for help. If you bought the parts over the internet without instructions you have two common problems...1) Bad/Fake chips... or 2) You did the repair wrong - because you lack proper instrucitons.
Pico fuses - yes - they can be one of many secondary reasons convergence is not fixed on Samsung models.
Posted on Jun 06, 2010
Our tv is showing shadows behind images and a curved red line at the top, what could this be?
This tv have a problems known as a convergence problems,it dead.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts must replaced to solved the convergence problems.The shop will cost u $300-350 for parts and labors.
Jul 13, 2010 | Samsung PCL5415RB 54" Rear Projection...
The colors are distorted and there is triple images
triple images show failure of convergence out ICs in TV, these are two big black ICs mounted with aluminum heat sink on D board, replace these ICs with same number STK392-560 and problem in your Sony KP-46WT510 will be solved.
Required ICs are available in Part Store.
Let me know any further question, if any.
Thanks.
Nov 15, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Convergence problem I fixed AND made worse
Count the # of flashes...call Samsung tech support
Nov 10, 2009 | Samsung PCL5415RB 54" Rear Projection...
Color seems off possible bowing of the image at top and bottom
that's right my friend, you have a convergence problem, you need to replace the stk's and it is possible that you have some burned resistors. if can't do it yourself  you are looking $250.00 repair
good luck
Jun 07, 2009 | Samsung PCL5415RB 54" Rear Projection...
Samsung HCM653W Convergence problem
CK low ohm resistors and pico fuses some are green,some are yellow .they will be around ics some may be under heat sinks that hold STKs.
Nov 29, 2008 | Samsung HCM653W 65" Rear Projection...
Red and green shadows
replace convergence IC'S and check values of convergence resistors.
Aug 07, 2008 | Samsung PCL5415RB 54" Rear Projection...
Red bow on top and bottom of 61dx01b
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
May 21, 2008 | Samsung PCL5415RB 54" Rear Projection...
Samsung PCL5415RB 54 Problem
Replace both convergence ICs number STK392-040 You can get replacements at the following link and they will provide free instalation instructions with pics and also give free tech support on line so you can do the repair yourself. Heres the link.
http://servicemanuals.vstore.ca/
May 06, 2008 | Samsung PCL5415RB 54" Rear Projection...
SAMSUNG PCL5415R
Probable bad convergence IC's---STK units on large heat sink.
Also,possible blown fuse (soldered-in) hidden under heat sink.
Samsung is known for making the fuse devices hard to find.
Let me know if you need more help....T.
Oct 19, 2007 | Samsung PCL5415RB 54" Rear Projection...
Bowing image top and bottom of screem
No im sorry there is nothing to do but replaceing the convergence IC
Oct 30, 2006 | Toshiba 55H70 55" Rear Projection...
Samsung PCL5415RB 54" Rear Projection Television Logo
82 people viewed this question
Henry  Thomas
Henry Thomas
