Volume is coming in broken up - Televison & Video
    Champion:
  • 225 Answers
You have 2 options. Try using different audio ports on the TV set, or do not use the TV speakers. Use a surround sound setup instead to play your audio. Fixing anything inside the TV is not really a probable solution for a non technician.
Posted on Nov 13, 2008
Broken volume button, in-call volume won't go up
Hit volume down then use on screen slider to move it up it will appear at top of screen to the right is volume up.
Feb 09, 2014 | Motorola Mobility MILESTONE XT720 Cell...
Stuck in recovery mode
Your device might have broken Volume buttons, due to this, once you turned on your device it will automatically go to recovery mode. Note that recovery mode can only be accessed when the device is powered off, and turning on the device while pressing the power button and volume down will directly go to recovery mode.
Try checking your device volume if it is pressing or pushed down, or better send it to a technician for diagnosis.
There are also several reasons why your device directly go to Recovery mode, either your phone software is crashed or your phone hardware is broken.
Apr 18, 2017 | HTC Inspire 4G
Nokia 6230 low volume
Hi if you have turned the volume to it's full level,then the problem is relating to speaker so to fix this you can change the speaker by yourself or contact mobile repairing shop.Sometimes this trouble comes when the diaphragm is damage or broken.Good luck.Thanks for visiting fixya
Jun 26, 2012 | Nokia 6230
Peavey Audition 110 Combo: When amp is switched on and any guitar played through it comes through extremely loudly compared to the volume it is set at. After a number of dunts with my fist on the top of...
The problem is LIKELY a broken solder joint right at where the leads of the volume pot come through the circuit board. The broken joint will ozidize overnight and then when vibration rattles it it will punch through the oxide. INSPECT all solder for the pot leads. Lood for a TINY grey line in the menicus of the solder where the lead comes through the board.
May 10, 2011 | Peavey Vypyr 30 30watt 1x12 Modeling...
When I use the Master volume the amp will suddenly bypass the master volume. And when I play on the top boost the volume fluctuates by itself. Thanks for your help Devon
I suspect you may have either a circuit board crack or the volume pot is bad or soldering of it is bad. Vibration will make things come and go. Look for broken solder around the pot leads first. Then look for a cracked circuit trace on the board near the ground end of the volume pot. If you put cleaner in the pots NEVER use Deoxit or Blue Shower. Use CRC226 which is available at Home Depot in the electrical dept.
Apr 29, 2011 | VOX AC30HWHD Amp Head
My sons ds lite has the green power light on but it does not come on, its just all black and no volume or picture
well then did he drop it hit it check to see if the screen is broken and the volume slider is broken it happend to my ds 2
Nov 28, 2009 | Nintendo Video Game Consoles & Games
Turning up volume if the key is broken
goto settings-->phone profiles-->edit
and set the çall alert volume'.
But if you want to change the volume during the call, there is no way other than putting the speaker on.
Nov 08, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
I'm going crazy. I have an I-Art 32", it's about six years old. We just bought it from a friend. The volume worked, then we were trying to program it and messed with buttons and no volume will come on! My...
check mute button on remote and on front of tv also check for speaker wires broken are chewed up are broken by animals are rodents are came loose
also go in to the menu ans make sure it is setup right
Feb 22, 2009 | JVC AV-27530 27" TV
Ive got a nwz-a818 walkman when I switch it on the volume control comes on and overrides all the other controls
it may be that your volume button has broken on the inside. If this has happened, then it may be that the momentary on switch has been forced down and is pinned down by the broken piece of plastic/metal. If the volume is stuck all the way up/down then I'm probably right. As long as you have a warranty that is still in effect, you can get the device fixed or replaced.
Aug 18, 2008 | Sony Audio Players & Recorders
Televison & Video Logo
Top Televison & Video Experts
