Question about Samsung SPP-2040 Thermal Photo Printer
Samsung SPP-2040 Photo Printer
Printer printing only half of the photo lengthwise (other halfis blank!). I changed the cartridge and paper but still the sameproblem!
  • 2 more comments
  • tombray Nov 18, 2008
    yep, this is happening to me as well. Any ideas?
  • Anonymous Dec 13, 2008
    ditto
  • Anonymous Jan 24, 2009
    same here and i have not had it too long
    same thing here and its not that old
For me, alysse's method worked. The part did not look particularly broken, but was not firmly gripping the shaft. I moved it to where it should have been, tightened it as described, and now the printer works great again.
Are you sure that that cam is not slipping on the shaft?
Posted on Apr 07, 2009
  • tombray Apr 07, 2009
    Are you sure that the cam is not slipping on the shaft? Mine did not look broken, but was not firmly gripping the shaft. Moving it back to where it should have been positioned and tightening as described worked. It now prints great photos again.
  • 5 Answers
I have posted a possible fix for this.
Look here: http://www.fixya.com/support/t467694-print_problem_spp_2040
Posted on Dec 21, 2008
Same problem, only print half picture, tried alysse fix - that part not broken, re-assembled and still same problem
  • dustevenson Apr 07, 2009
    next I called Samsung..... they said... spp 2040 has been discontinued for a long time, I described the problem - the printer tech said that most likely the main processing board is bad, no way to complete do it yourself repair ..... also no samsung service center within 50 miles of Seattle, basically no help from Samsung. Any body want a parts printer or a cartoon of ribbon and paper for their spp 2040???
Only printing 1/2 the image of the selected photo, I have tried changing the printer cartridge but still only prints 1/2 the selected image, any ideas why this is happening?
I am not familiar with that particular printer, but it could be as simple as making sure you have the entire picture selected..but it sounds more like the cartridge is either clogged or there is a setting that needs changed...try aligning the cartridge(s) and printing a test page. (that part is usually under a maintenance or troubleshooting type section) if that turns out fine, then there may be a setting thats off...look at your print settings...you may have a separate section just for printing photos...even if you don't, look at your page setup.. look specifically at the margin settings...that might be where the problem lies..you can always play with the margin settings- i would recommend saving them under a custom setting if you want to keep them, instead of default though...that way you have your regular settings for general printing... and do a "print preview"...that might be a good idea anyway, so you wont have to waste ink and paper trying to get your stuff to turn out how you want it (plus that will show you if margins are set right)...for that, there should be a checkmark box you can select to always do print previews...
also, look to see if you have a selection or checkmark box that says "fit to page" or where you can select how many copies you can print per page..this can be used for everyday printing, as well as for photos...
you may even see a spot where you can select the size of photo to print...usually you can pick to print "wallet size or 4x6, ete." and how many to print on a single page...maybe even multiple sizes per page...these are several options for you to look at...hope it helps :)
Jul 30, 2015 | Samsung SPP-2040 Digital Photo Printer...
Print cartridge
There is a green 'latch' just above the cartridge when it is installed. If you move this, the cartridge will release.
Best Wishes,
Karlos
Apr 12, 2009 | Samsung SPP-2020 Thermal Photo Printer
Samsung SPP-2020
You need to get the exact photo paper for this model.
The ones that comes with the flaps on each ends.
Without the flaps, the printer won't print.
Aug 05, 2008 | Samsung SPP-2020 Thermal Photo Printer
Rafique:- Samsung SPP 2040 paper problem.
If its new, You may contact nearest service center.
Mar 27, 2008 | Samsung SPP-2040 Thermal Photo Printer
Samsung spp2040 printer
The roller of the paper pick up is rotating or no. If rotating and not taking rollers need a cleaning try this else change the roller.
Mar 24, 2008 | Samsung SPP-2040 Thermal Photo Printer
Spp 2040 printer ribbon
  • Open the door on the right side of the printer.
  • Push "up" on the green lever above the ribbon cartridge. The ribbon should pop out slightly.
  • If it does not pop out, then try prying out the cartridge while pushing up on the grean lever.
  • Pull out the ribbon cartridge.
Feb 14, 2008 | Samsung SPP-2040 Photo Printer
Samsung photo printer spp2020
i had the same problem and replaced the ink cartridge and hey presto ! it worked
Apr 01, 2007 | Samsung SPP-2020 Thermal Photo Printer
Samsung SPP-2040 Thermal Photo Printer Logo
752 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
