Question about Samsung Televison & Video
Flat screen monitor LE20S51BUA
SIRS I HAVE A FLAT SCREEN MONITOR AND THE SHOP DID NOT HAVE A MANUAL TO GO WITH IT AND I CANT ALTER THE RESOLUTION A AND THE ICONS ARE TO LARGE AND I WANT A PROPER AVG CABLE
    Champion:
  • 225 Answers
I think all of those settings can be changed from the computer's display control panel. Any electronic store should be able to help you find a cable. Try bringing them a picture of the TV port.
Posted on Nov 14, 2008
My lcd monitor have red lines
Try altering your display resolution in all its variables.
If the monitor has a menu, try altering RGB settings, contrast and appearance settings. If this does not work, most likely a hardware screen failure.
Jul 26, 2011 | BenQ FP992 19" LCD Monitor
Having changed the os from xp to xp pro i am unable to alter the screen resolution. Any help appreciated.
Go into control panel, click display, settings on the top right, set the color quality at max and the screen resolution also at max, click okay to save settings and monitor should adjust accordingly, if not set monitor to auto setup.
Mar 31, 2011 | Hanns.G Corporation HW191D 19" LCD Monitor
Good Evening Sir/Madam,I have a problem on my LCD Monitor,if i open my cpu it appears on the screen of my monitor is"Out Of Range"....what kind of problem is this sir,can you give me...
You have set too high resolution for your monitor. Follow these steps to correct the problem.
1. Switch on the computer.
2. Before you see the Windows logo, press F8 button several times. You will get the boot menu.
3. Select the option 'Enable VGA mode' with arrow keys. Press enter.
4. Computer will boot normally, but with larger icons.
5. Open Control Panel --> Appearance and Themes --> Change the screen resolution.
6. Set the screen resolution to 1024 x 768 (or something close to it).
7. Apply the settings and restart the computer.
This will solve your problem. Wish you Good luck!
Nov 12, 2010 | ViewSonic VA912 19" Flat Panel LCD Monitor
Input not supported
The repair shop set the PC video resolution to higher resolution to use with their monitor and did not put it back to the same resolution for your monitor which cannot handle the higher resolution. You need to lower the PC video resolution to the native reslution of your monitor which is 1280 x 1024 @60 Hz.
http://www.fixya.com/support/r4873371-fixing_out_range_format_not_supported
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Jul 14, 2010 | Envision EN-7100e 17" Flat Panel LCD...
We are trying to adjust the screen resolution so that we can see more of the website on the page. can you assist?
Through your computer you can set numerous screen resolutions, but your monitor should also have one that is recommended as best for it.
To reset the resolution do the following.
Click on START, and on the menu that opens, find CONTROL PANEL and click on it. Then look for DISPLAY and double click on it.The Display Properties box will open. Click on the SETTINGS tab at the top right, and you will find the resolution adjustment is obvious.You can try different settings until you find one that suits. The higher the numbers, the more of the website you should see. If the text becomes too small for you, you can alter this separately. The zoom level control should be can be found at the bottom right of your screen, and 'nomal' is 100%
Olease note. When you alter screen resolution, you will be given a few seconds to confirm if it suits you. Instructions will be on the screen. If you do not confirm, your resolution will revert to what it was before you changed it.
Jun 18, 2010 | HP w1907 LCD Monitor
How do I alter the definiton of the monitor?Illyama 2209hd.
I am assuming you mean the screen resolution.
It depends on what operating system you are running, but I will assume it's Windows.
You need to go to Control Panel (Start>Control Panel) and double click Display.
Select the Settings tab and then you will see a slider bar under Screen Resolution. Move the slider to your Monitor's optimum resolution setting and click Apply
Apr 09, 2010 | iiyama PROLITE E2200WS WIDESCREEN LCD 22"...
HPW2338h goes black after about 3 seconds. Push power button on, it turns on and then black after 3 seconds. Power light on monitor stays on.
hi,
you can try to change the screen resolution with a spare monitor to a different setting, usually higher 1024X768, then unplug the old monitor and then plug in the flat screen. try different resolutions untill it submits. if you cant get it to run on your machine, take it to another computer and see if you can get it to run on that. if it wont run on either then you have a problem with the monitor. pawn shops usually have flatscreens for way cheaper than new..
jm
Dec 15, 2009 | HP w19 19" LCD Monitor
FPD1530 15in flat screen Config. issue
The native resolution of the monitor is 1024 x 768, so set your computer resolution to that value. If necessary, restart the computer with the monitor powered on.
Here's a link to the User manual:
Gateway FPD1530 User Manual Fpd 1730 Specifications
Nov 19, 2017 | Gateway FPD1530 15" Flat Panel LCD Monitor
My monitor goes black and does not come on to i turn the powe off
Dear Sir/Madam,
Reinstall the monitor drivers and right click the desktop go to Display properties->Settings->Check the Screen Resolution and select 32 bit color check the screen resolution is 1024X768 if it is not listed there will be the problem with driver software.
Nov 26, 2008 | LG Flatron L1951S-SN 19" LCD Flat Panel...
Televison & Video Logo
119 people viewed this question
Jerry Greenberg
Jerry Greenberg
