Question about Dell Latitude D600 Notebook
Always using battery power
My Latitude d600 always shows that I am using battery power even though I am connected though the charger to an electric outlet.
  • pgbob Nov 14, 2008
    Thanks Walterb, the solutions you offered confirmed my suspicion of the 2 items. I borrowed a charger from a friend and computer worked fine. Shut down the computer and started if up later using my charger and the same problem returned. I'm off to the store. Thanks again
  • Dell Master
  • 998 Answers
Try removing the battery and see if the laptop works with the AC adaptor. If not either the AC adaptor is bad or the motherboard is defective.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Posted on Nov 13, 2008
Why my lap top battery power goes off soon while starting?
These laptops are notorious for developing battery issues. We've got one at our house that would basically be a paperweight without a charger and external monitior. The best fix for this is to buy a new battery.
May 19, 2014 | Dell Latitude D600 Notebook
My Laptop (Dell Latitude D600) when I'm trying to turn it on, can not swicthing on and no effect can show me that power is entring. I thounght that is charger problem and I trayed to use the same charger...
Try this, Unplug the power and remove the battery, while the battery and power are unhooked hold the power button down for 30 seconds, Put the battery back in and make sure you slide the locking tap to lock the battery in, try to start the computer, If it doesn't start, plug the power cord in and wait 3 minutes and try to start it, If it still will not start it has an internal issue and needs to be repaired.
Dec 01, 2010 | Dell Latitude D600 Notebook
I have a Dell Latitude D600 power problem. When the AC charger is connected the unit will power down by itself within 10 secs the most. If no AC charger connected, the unit is fine.
Please try removing the battery then attached the ac adapter and see if the same thing happens. It is possible that the AC adapter is faulty already if it doesn't isolate the issue. Please let me know if the result. Thank you and regards.
Sep 25, 2010 | Dell Latitude D600 Notebook
My dell d600 been shorted after using defective charger
try connecting a known good ac adapter if fails then remove battery then try it again if still fails then replace the motherboard.
Oct 14, 2009 | Dell Latitude D600 Notebook
Battery help
yes and what did you drop ?
Sep 06, 2009 | Dell Latitude D600 Notebook
Dell latitude d600 will not turn on / power on
it means not charging the battery pack, did you check the dc jack connector, or the.
charger check it if working properly, if the same problem open the laptop then check the baord
thanks
Jul 12, 2009 | Dell Latitude D600 Notebook
Red light flashing on far right symbol/battery or charger going ?
this happiness when you've used the laptop off power for some time. it indicts your battery levels. when the battery level is low to a certain %ge then it warns you before its totally empty. always power up your laptop whenever it lights or save your work in order not to lose unsaved data.
May 26, 2009 | Dell Latitude D600 Notebook
Dell Latitude D600 Always Shows It Is On AC Power
Check your QuickSet utility for settings regarding always on configuration.
This is most likely the cause as Dell's QuickSet causes numerous persistant glitches
Apr 24, 2009 | Dell Latitude D600 Notebook
Dell latitude d600 blinking battery light
I would say its defective. Bring it back to where you bought it and show them. Bring your laptop charger also so you can show them it in action. Hope this helped.
Jan 04, 2009 | Dell Latitude D600 Notebook
Dell Latitude D600 Notebook Logo
76 people viewed this question
Alun Cox
