Cannot make a wireless connection between a sagem router and a ralink wireless mini card 802.11g
    Scholar:
  • 132 Answers
  1. Make sure that your wireless mini card is properly installed into your computer. You can check the status of your wireless adapter by going to Control Panel>System>Device Manager. Then go to Network adapters and look for ralink wireless mini card. Right click on it and click properties then look for device status. It should state there, Device is working properly. Otherwise, there is a problem in the installation of the adapter.
  2. Then, verify the wireless settings that are enabled in your router by accessing your router's setup page.
  3. Take note of the SSID or wireless network name and the security enabled in your router.
  4. Configure your computer that has the wireless adapter with the same wireless settings in your router.
Hope this helps!
Posted on Nov 14, 2008
  • 66 Answers
Check List
1 Start - control panel - network connection - right click wireless connection and click view available networks if says not found.
2 Check the wireless switch on the laptop its on or off.
3.Start - Run - services.msc and look for wireless zero configuration and start the service
hope this helps
On the HP ProBook 4720s laptop, there's a button with a wifi symbol on it and a small led on the up-right corner of the key. When I got the laptop it was light blue. Seems now it's always orange....
Try enabling windows zero configuration, and using the windows wireless connection manager.
There should be an option in the ralink program to enable the feature, after that push the button and click refresh wireless networks or the refresh button.
If nothing happens or no wireless network are found try it again.
If nothing happens the second time your wireless card needs to be replaced you can consult your service manual at the hp support site for more info
Jun 15, 2011 | Computers & Internet
Can 't connect to the internet with my ASUS wl-167g I have an ASUS wl-167g wireless usb adapter on my Win7 Home Premium PC, with the latest ralink drivers. I can perfectly detect the wireless network my...
You need to enter the wireless key from your router once before the adapter will connect. The key is either on the label on the router or in the wireless section of the router.
May 04, 2017 | ASUS (WL-167G) 802.11g/b (wl167g) Wireless...
İ have problem with my NİC i dont know what is happening but i am fluctuating with the connection. each seconds the wireles connection is searching and then afterwards it stops searching...
I would advice to change the channel on the wireless router to anything between channel 1 and 8 you can access your router setting by typing 192.168.1.0 or 192.168.1.1 try and find information about default user name and password corresponding to your router. Go to the settings change the channel. Good luck and post if that helped please
Apr 16, 2010 | Fujitsu Siemens AMILO Pro V2010 Notebook
I have just installed the driver for an Intellinet wireless G usb adapter from the disk it came with. In the instal guid it says once ive installed the driver and plug in the adapter, it should...
did you plug in the adapter before you installed the driver . best thing to do is uninstall and reinstall. as well as that ralink wireless lan card is not what you bought it should say intellinet when installed properly. reinstall thats my advice
Aug 31, 2009 | Intellinet Active Networking Intellinet...
No internet connection and Ralink Wireless Adapter Not Exist
try it to connect in other slot check if there is dust or rust ,clean it ,make sure your adpoter is conttected properly and check biose setting than expantion slot enabled (if there is a
Jul 22, 2009 | Computers & Internet
Sony UWA-NA1 - no available driver for Windows? what specs does it have? It seems that with a Giga Juke Hifi-stereo, it will only communicate with WEP encryption, but the Wireless Giga Juke player station...
I found it! Sony UWA-NA1 USB Wireless Adaptor is a OEM products of Quanta Microsystems Inc, it's using the same USB adaptor as Ralink RT73 USB Wireless LAN card with RT2571WF chipset. I did it work ok in window 7 64-bit. But in the link below, its support XP, Vista as well.
1. Download Drivers for XP/Vista/Win7 here: http://www.station-drivers.com/page/ralink.htmChoose Ralink RT257x/RT2671/RT520x (RT73 series USB Wireless LAN)
2. After download it, run it to install the Ralink Wireless App, check for the driver only. When it done, find the folder it has installed. 3. Open device manager in window managerment, choose the Wireless USB (have no driver with yellow !), right-click, update driver software..
3.a Click "Let me pick from a list of device drivers on my computer". Find the "Network adaptor" in the category devices list, click on it, OK.
3.b In a new window name "Select Network Adapter", choose "Have Disk..." then browse the path of folder Ralink has installed. Your will see a file "netr7364.inf" (may be in XP-32bit or Win7 32bit you will a difference *.inf file). Click on it, click open, then OK.
3.c In the left box, find Ralink Technology Corp. click on it, the find RT73 USB Wireless LAN card, then click NEXT, a "Update Driver Warning" pop-up will appears, just click yes. Then windows will install the driver for Sony UWA-NA1 as "RT73 USB Wireless Card". Good luck! (You may try another devices in the list at your own at risk)P/s: Sorry for my bad english! English is not my primary language.
Jul 08, 2009 | Sony Computers & Internet
Sagem Internet Radio cannot find VTuner
Check with your Sagem manual if it supports WPA encryption. If not. then enable WEP on your wireless router and then check if you are able to achieve a connection between sagem and wireless network.
Jun 22, 2009 | NetGear MP101 Super Service plus vTuner...
Computer say my wireless mini card not connect i
type this in your internet adresse bar 192.168.1.1
that will take u into your router
good luck
Mar 16, 2009 | Computers & Internet
Wmp54gv4 pci driver will not install.
Are you using the latest Ralink driver www.ralinktech.com , and, from the docs they provide, they indicate -
Ralink RT61 and RT2500 series miniport drivers require NDIS 5.0, NDIS 5.1 or NDIS 6.0 to operate in Microsoft Windows. NOTE: UNINSTALL OEM PROVIDED PACKAGE BEFORE RUNNING THIS RALINK PACKAGE.
Confrim these instructions have been followed.
You can also contact them.
Sorry I can't provide an exact solution, but this should get you on track, and it's the type of problem that likely only Ralink knows about, if at all.
Jan 26, 2009 | Linksys Wireless-G WMP54G 802.11g/b
I can not get my laptop and my ps2 to connect to internet at the same time
hi Lorraine! may i know what type of laptop brand do you have? mac or etc..?
Sep 30, 2008 | D-Link DES 1005D (DES-1005D) 5x10/100 Mbps...
Computers & Internet Logo
550 people viewed this question
David Payne
David Payne
