Question about Vivitar 285HV Flash
285 not 285HV
I have a broken hotfoot / hotshoe mount on my 285. Who can supply parts and or repair it in Sydney, Australia? Multiple options are good! Thanks for your suggestions.
    Champion:
    Scholar:
  • 216 Answers
You can make your own or repair the shoe.
Use Weld Bond, buy from auto store.
Buy plastic, then cut & stack & Weld Bond.
atdlee@netzero.com
Posted on Feb 12, 2008
Where can l find spare parts for my Yukon chainsaw,I'm at windsor nsw sydney Australia
depends on what parts you want and the cc of the engine
go to an accredited mower repair shop as many engine parts are generic and will fit across a range if cc sizes
as for the rest they may be able to help as well
go google and type in -- authorized repair agents for yukon chainsaws in australia --then find any close in your state
Nov 27, 2016 | Coffee Makers & Espresso Machines
Where are the pre polling booths located in Mt Annan 2567 for the local council elections
Hi, John. Welcome to Fixya©
Mount Annan is a suburb of Sydney, in the state of New South Wales, Australia. Mount Annan is located 60 kilometres south-west of the Sydney central business district.
Sep 08, 2016 | Cars & Trucks
BROKEN CLIP ON SIDE OF FOOT REST NEEDS REPLACEMENT ANYWHERE IN AUSTRALIA WHERE I CAN BUY NEW PART? 2008 Stokke.
Karlisles Pram Fix in Sydney supplies Stokke spare parts. There details are at www.karlisles.com.au
hope that helps
Jun 01, 2010 | Stokke Xplory Stroller
I have a mountain buggy that needs repairing
There is an official Mount Buggy Spare Parts supplier and service agent based in Sydney, Australia called Karlisles. I'm not sure which country you are in.
In case it helps their details are:
1300 308 435
Alternatively, a good bicycle shop in your local city can usually supply these parts and service jogging prams.
Hope this helps
May 27, 2010 | Mountain Buggy Urban Elite Double Stroller
Broken hotshoe repiar problem
It's a known weak point on that model and is typical of ANY similar large, heavy flashgun which mounts via a hotshoe mount which was never designed for such loads.
Unfortunately, the most common type of break cannot be glued or repaired in any neat fashion, but if the wiring is intact a very rough looking but functional repair can be adapted by fastening external metal repair plates using epoxy resin and very short screws. The unit looks dreadful afterwards, and has zero resale value but it usually works and if done correctly the repair lasts the lifetime of the unit.
If you want a neat repair, then the only option is via the factory (often they just dispose of your broken one and send out another new unit). In the camera club which I belong to some members have found it's more cost-effective to sell the broken unit as spares or repairs on an auction website and to then put the funds towards purchase of a more suitable model (either a smaller, lighter, less vulnerable unit, or a proper off-camera hammerhead type unit like all traditional Metz models). One other member found that his credit card gave him accidental damage cover on purchases for up to ninety days (yours is brand new, so worth checking) and another found that her flashgun (not a Metz, but a similar bad design) was covered by her household contents accidental damage policy, but she had to pay the first £90 of the claim.
In case you're wondering, the "bad design" is an intentional compromise. It's simply preferable for the flashgun to break rather than for it to rip the top of your camera off. That's a major disadvantage with the repair option which I mentioned: further knocks simply mean that something more vital gets broken.
Good luck with whatever you choose to do, please take a moment to rate my answer.
Apr 09, 2010 | Metz mecablitz 48 AF1 TTL Flash for Canon
Sony hvl-f32x
I managed it by buying a broken (non-working) F32X from an auction service for something like 5 bucks. I just made sure (by looking at the photos) that the hotshoe was intact.
Here's how to disassemble and replace foot (I got to this by trial and luckily no error ^^).
  1. Unscrew 2 small screws located under the battery flip cover.
  2. Put the lamp (moving part) in the upright position.
  3. Unscrew 1 small screw above the infared sensor (below the main lamp part which you moved to the upright position).
  4. Remove the cover of the infared sensor by gently pulling forward.
  5. On two sides of the infared sensor there are two small clips which hold the 2 casing pieces together. Then pull the pieces apart gently. Just behind the hotshoe casing you can see a small plastic inset -- place a screwdriver sideways between this inset and the hotshoe to help you separate the two casing parts. Be careful when doing that, don't use too much force, wiggle the casing instead to make this easier (this is the most tricky part).
  6. When the electronics is exposed, there is a single screw in the middle of the motherboard. Remove the screw and gently pull the motherboard away from the casing. You do not have to pull it all the way or disconnect any cables, you just need to make sure the bottom battery connectors are pulled out of the casing just a little, because then under the two middle battery connectors (looking from the top, as if you were putting the batteries in) you can see two screws!
  7. Unscrew those two screws, and the hotshoe will come apart. Pull it out gently and remove a single electrical connector that connects it to the flash.
  8. Do this in case of your working lamp (with a broken hotshoe) and your replacement lamp (with a good hotshoe), and just move the good hotshoe to your working lamp.
Took me about an hour to do this (most time was spent on trying to figure out how to disassemble the lamp), and the lamp works perfectly.
Warning: better test disassembly on the replacement lamp, since even if you break it, all you need it for is the hotshoe, so you can practice on it. Only after you learn how to disassemble the F32X do this on your working lamp.
Hope this helps!
-- Tomasz Andrzej Nidecki (tonid)
Feb 05, 2009 | Sony HVL-F32X TTL Flash
I have a whirlpool multiflow 380lt fridge i have broken some shelving i need the egg guard and crisper box where could i get these parts i live at st marys sydney nsw
Try contacting Stokes here:
Stokes (Australasia) Limited: Stokes Appliance Parts
24 Palmerston Rd West Ringwood, Victoria 3134 Australia
ACN: 24 004 554 929
Tel: +61-3-9845-8300
Fax: +61-3-9874-1077
E-mail: info@stokes-aus.com.au
Or contact Whirpool:
Whirlpool Service - Parts Price List
call Whirlpool Service on 1300 363344 (Australia) or 0800 442584 (NZ)
Sep 09, 2008 | Whirlpool Refrigerators
Vivitar 285HV Flash Logo
160 people viewed this question
Top Vivitar Cameras Experts
Damen Wong
Damen Wong
DMS-UK
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
