Question about JVC MX-K30 CD Shelf System
System keeps sayin protect
Recently while I was playing a CD, my system cut out and the word PROTECT was displayed on the digtal panel, the CD won't play and there is no sound coming out from the speakers. However, the tape deck plays but again there is no sound. I have tried most things suggested, but everytime I turn the system on the word PROTECT appears and won't allow any of the functions on the system to work. Can this be fixed?
  • binish Dec 24, 2007
    my system also showing "proteted" i unplugg my speakers from the system,but still showing in the display panel saying the system is proteted,please help me what to do now
  • Anonymous Dec 24, 2007
    my shit keep saying protect what do i do cause im really mad
    Problem Solver:
  • 8 Answers
The word PROTECT appears because there is a short. It can be in your speakers, try running it without the speakers plugged, or look if the wires arent shorting. If it stil ldoes that, its cause there is a short in it, from the output section. The system does that to prevent from damaging the electronic components inside.
Posted on Feb 21, 2007
Car stereo keeps displaying protect
There is a short making the radio protect itself by cutting out to prevent it blowing up..
Check all wiring for any touching and check all fuses for radio in fusebox under the hood.
Aug 12, 2010 | JVC AM FM CD DET FACE CAR STEREO
Cd player say's protect and will not play cd
If protect is coming up on the display, it means the system is detecting a short somewhere on one of the speakers and so is turning the amp off to avoid damage.
Check all the connections at the back of the amp to ensure they are not shorting, and at the back of each speaker, if nothing is found there, check each wire for damage (like squashed or rodent damage).
Jan 27, 2010 | Sharp XL-ES50 CD Shelf System
MY KENWOOD CAR CD PLAYER IS SAYING PROTECT??
Kenwood head units show "protect" when there's a problem with the speaker outputs. This might mean a shorted speaker wire, a blown speaker, or an internal defect in the head unit. Once the condition that's causing the "protect" mode is fixed, the CD player should be back in normal mode the next time you turn it on.
If it's staying in "protect", then you'll definitely have to remove the stereo and do some troubleshooting to fix it. Many car audio stores will do system troubleshooting, for a fee. If you want to do it yourself, here's what you need to do:
Pull the Kenwood unit from the dash and disconnect all the speaker wires. Turn it on and see if the "protect" message displays. If it does, the stereo has an internal defect and will need to be serviced. If it doesn't, then turn it off, and re-connect one speaker. Turn it on again and see if it displays "protect".
If it works with a single speaker connected, keep re-connecting the others until you identify the speaker that's causing the problem. There may be a wiring problem or defective speaker in that location.
If it displays "protect" with a single speaker connected, then disconnect that one and try a different one. If all the speakers cause a "protect" mode, then you're probably back to a defective head unit, unless your friend managed to blow all your speakers at once.
Thanks,
Dec 09, 2009 | Kenwood KDC-319 CD Player
What is "Press Power Protect"?
Hi Lois,
Stereo sytems have a protection circuit that alerts you by displaying "protect" when there is a electrical short circuit detected in the system, the most common short happens in a speaker, try disconnectig the speaker wires of both speakers(all speakers) at the back of the system, then play the CD or cassette player(although you will not hear anything with the speakers disconnected) and see if the unit goes into "protect" mode if the problem is still present then you have an internal short circuit and the system will need to be sent in for service or replaced(depending on age,repair costs). I would not recommend investing more than $80 into repairs. Now, if the unit does not go into "protect mode" then one of the speakers or speaker wires is shorted,be sure you check the conndition of the speaker wires before you replace the speakers, then you can replace the speakers(in a pair) and you should be back up and listening! Good luck and Merry Christmas !
Dec 03, 2009 | Sony MHC-NX1 Shelf System
Cuts off and displays "Protect"
The protect light comes on when the amp cuts off the speakers to protect them from damage if something's wrong in the amp, or to protect the amp from speaker or wiring problems. If the amp plays for a while before cutting off, it's probably a thermal problem in the output stages. One of the output devices may be acting up as it heats up, or it could be bad connections that open up because of the heat. The trouble might also be caused by components in the power supply as well. Without having the unit on the service bench to check it, it's not possible to suggest specific things to look at. The manual wouldn't help you other than to say check your speaker connections and then have it serviced. The best thing to do if you want to keep this is to find a servicer in your area and get an estimate for the repair. Or if you or a friend is technically inclined, look into purchasing a service manual and see if you can do-it-yourself.
Apr 23, 2009 | Harman Kardon AVR 230 Receiver
PROTECT message display on JVC HX-D7 DVD Stero Player and turn off
How do i fix that i get the message on my cd play (JVC HX-D7) and it says PROTECT and shuts off by its self what do i do to fix the problem ?
Sep 27, 2008 | JVC HX-C6 Shelf System
Protect!
Your audio amplifier IC is damaged you gotta change it.
Jun 08, 2008 | Kenwood KDC-135 CD Player
Protect?
Overload protection circuit kicked in. Check all your wires (speakers,input,output cables), There is a short somewhere and lets hope it's not In the receiver.
Jul 12, 2007 | Sony STR-DE197 Receiver
JVC MX-K30 CD Shelf System Logo
401 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
stynger007
Level 1 Expert
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
