Question about Whirlpool RF364 Electric Kitchen Range
Changeing both bake and broil elements
I just need to be change these -as I found a wire burnt into on the baking element and broil element is not working either. Can you give me step by step please. Don't want to burn my home down or get shocked when I am done. Thanks
  • 5,911 Answers
I would recommend you check BOTH elements for proper resistance prior to replacing them. If both of them are not working, the problem may actually be with the Electronic Oven Control (EOC) board. This is your clock assembly. On electric ranges, the EOC controls all the oven features. Check the resistance of the heating elements by performing the following:
- Perform a resistance check from terminal end to terminal end (where the wires connect to). You should get a high resistance reading in the Kohms range (this varies between models). If the reading is infinite, you have an open heating element. (Must be replaced).
- Second, perform a resistance reading from one terminal end to the outer shell of the heating element. You should get an infinite reading. If this reading is a low resistance or short, the element is shorted. (Must be relplaced).
NOTE: Take these readings with the wires disconnected.
You may be right, but please take the time to check both elements and let me know what you find. You may have started off with a bad element, but it could have damaged the EOC as well. I have seen this happen before. The result is an oven that still doesn't work after the homeowner replaces the defective element.
The following link explains how to replace a heating element:
http://www.fixya.com/support/r469407-replacing_bake_or_broil_element_in
I hope this information is helpful to you.
Posted on Nov 14, 2008
Maytag Oven. The bake do not heat, the broil is ok. what is the problem ?
Look at the wiring diagram... The manual reset Thermal Limiter Switch (part number 74008715), located on the lower rear insulation retainer can keep both elements from working, not one at a time... I would inspect the back of the bake relay for a burnt/failing solder joint. Swapping the BAKE and BROIL leads is an acceptable test, but if you put the bake leads on the broil and still get no heat: check the control relay. If the broil leads will not heat the bake element, you have a bad element or bad connection. Be sure to do all testing of the elements with at least one wire detached so as not to red a back circuit.
Jun 19, 2016 | Maytag Ovens
Oven won't heat up, display flashes bake
THINGS TO CHECK:
the broil element
is the heating element that is found at the top of the oven and produces a very high heat for broiling. If the broil element isn't working, you should first do a visual inspection for signs that the element has blistered or separated. If the element appears normal then you can check for continuity with a multi-meter. Remove power from the appliance before performing this test. Remove the back panel and locate the terminals for the broil element and inspect the terminals and wires for signs of overheating or damage.
If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control.
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. ( by placing the each of the meter prongs on each end of the heater element connectors) If the element is burned or no longer has continuity, it will need to be replaced.
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
Feb 12, 2014 | Frigidaire FEB27S5A Electric Single Oven
Frigidaire elements oven will not ignite
the broil element
The bake element
Feb 05, 2014 | Frigidaire Ovens
Frigidaire oven fefl68 broil element comes on on broil only will not come on on bake or clean
Hello - - If you are referring to the bake element, but the broil element works then you would need to just replace the bake element. If both your bake and broil element does not work, then there might be a problem with the wiring communication. However, if the oven does not bake and/or broil but the cook top works; contact a professional to diagnose the EOC (electronic oven control).
Nov 17, 2012 | Ovens
My 2003 Matag range model mer5770 will no heat in bake mode. The bottem or top element wont heat although the top element will heat on broil Hi mode. Also when bake mode is on the oven control shows both...
,first make sure you have 240 volts going to the stove,the broil runs on 120 volts,the bake on 240 volts,unplug it,remove the two screws and pull out the bake element,pull off at least one wire and read it out with a meter,if it's good remove the back panel,check for burnt wires,plug it back in and where the block is or where the cord connects to the machine make sure you have 240 volts,if you do you the computer board is bad or the clock assy. part number 5701M556-60 and it's around 225 dollars on the sears site,when you call your parts store give them the full number off the machine,the number that came up was mer577oaaa.hope this helps.also when the bake is on the broil element heats up too,that's why both elements show up,if the relay is bad in the clock assy,you can't get a new relay you have to change out the whole assy.
Feb 27, 2011 | Maytag MER5770 Electric Kitchen Range
The lower element burned in my oven. I replaced the element, but the oven will not work.
unplug range ..remove the back cover plate check all wires all connections ..their must be a burnt /broken /dissconnected wire ..check where the wires connect to the bake an broil element ..and the bake broil switch..if all looks good .then the bake broil switch burnt out when element blew out..plus is the breaker tripped in the box ..it prob. tripped when the element blew out..let me know..good luck
Aug 28, 2010 | Frigidaire FEF366 Electric Kitchen Range
When set to bake oven does not preheat and tempature does not increase. when set to broil oven heats
Since your oven has a separate element for bake and broil I would bet the bake element is burnt out or burnt electrical connection to the element. Make sure you disconnect all power to the range before checking.
Mar 21, 2010 | Amana AER5844VAD / AER5844VAB / AER5844VAW...
Broiler element comes on when "bake" is pressed
does the bake element come on at all?
if so, try the oven out. do a bake @ 350 allow it to pre-heat, and see if once the pre-heat is comlete, id the broil shuts off.
on many ovens at the beginning of the cycle during pre-heat both bake and broil elements are powered.
other than that it may be a control board, or a burnt and crossed wire in the harness.
May 28, 2009 | GE JTP15 Electric Single Oven
Bottom Baking element not working
dmiller58
If all your connections are solid then your controller is defective. Did you get any faults before changing the element? Does the broil (one at the top of the oven) work?
Post a response
Regards
Sep 10, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Broiling works but baking does not work
CHECK FOR 240VOLTS AT THE TERMINALS OF THE BAKE ELEMENT. GAIN ACCESS BY REMOVING THE BACK PANEL OF THE RANGE. SOMETIMES THE TERMINAL WILL BURN OFF OF THE WIRE GOING TO THE ELEMENT. THE WIRE WILL JUST BE HANGING THERE. BE SURE TO UNPLUG THE OVEN BEFORE REMOVING BACK PANEL. IF THE WIRE IS BURNT, REPLACE THE TERMINAL AND REATTACH TO THE ELEMENTS TERMINAL. IF THE TERMINAL IS DAMAGED, REPLACE BAKE ELEMENT.
IF THERE IS NO VOLTAGE TO THE ELEMENT, REPLACE CONTROL.
Apr 03, 2008 | Frigidaire PLEF398AC Electric Kitchen...
Whirlpool RF364 Electric Kitchen Range Logo
138 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
