Question about GE GSS25JEMWW Side by Side
Water Dispensor drips
I have a GWE PRofile side by side fridge. the water dispensor plastic hose drips water even when the button is not pressed for water. the fridge is about 9 years old
    Problem Solver:
  • 18 Answers
You probably need a new water valve in the back of the fridge the valve is not shutting off completely  replacing valve will correct this problem
Posted on Nov 15, 2008
No water from dispancer
Could be the water valve it should be a double soleniod, one for the icemaker the other for the water dispensor. Have someone push the dispensor button while you listen at the back of the fridge. It should be located at the bottom right corner, even if youcan hear it, it may not be opening. You can remove the plastic line that goes to that side of the valve and have someone press the button again to see if any water comes out. If it does you may not have pressed and held the button long enough to fill the resevoir that is located inside the freshfood compartment.
Feb 24, 2014 | GE (PSS26MSRSS) Side by Side Refrigerator
My ice maker works but not my water? Please help.
First check your hose and water source,going into the back of the fridge. Make sure they are bot clogged or kink in the hose.
Jan 30, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
When the water line is hooked up to the back of fridge and the line is turned on the refrigerator leaks water out the ice dispensor and does not shut off the flow of water to the fridge.Thus causing it to...
the water soliniod maybe clogged with calcium. if you get it loose you can take the plastic hose loos from the icemaker side of the water valve see if it is dripping or running out of there. if alot is coming out maybe getting voltage too long from the icemaker. it will be one or the other.
Aug 04, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water in carpartment under fridge.
thats the dispensor tank, is there a drip pan under neath the refrigerator?
Apr 24, 2010 | GE GSH25JFR Side by Side Refrigerator
Ice maker and the water dispensor is not working.the fridge is only 6 months old
does your plastic water line run from underneath your sink to fridge? if so maybe you put something under sink and crimped the little plastic water line. pull refride out some and then try water dispenser
Jul 11, 2009 | GE Profile PSW26P Stainless Steel Side by...
Water dispensor problem (zIss420dmass)
hmm, wonder if the flap is broken inside where the water comes out or the control board is not working properly
Jun 23, 2009 | GE Refrigerators
GE Profile Ice maker/ Water Dispensor not working
ok try this for me and let me know how it works there is a water tank in the fridge and on installation you have to hold down the water for about 5mins to fill it up now the ice disp will be a separate issue hold my rating and let me know if your water flowes first
Jun 13, 2008 | Refrigerators
Water dispensor does not dispense water. Ice maker works.
you have prime the system air out of the water lines this is easy to do
put a glass big enough to cover water dispensor outlet cause its going to project water out at you press and hold button till water starts to run smooth
these fridges will spit water at you when you prime the system at first cause theres air blockage in lines
May 20, 2008 | Frigidaire FRS3R5EMB Side by Side...
GE GSS25JEMWW Side by Side Logo
120 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
