Question about Dishwashers
Water will not go into my dishwasher
My dishwasher is 3 years old and has been in storage for 1 1/2 years. I just moved to my new home and my dishwasher hums very loudly and will not take in water. I don't think anything is plugged (we made sure it was all dried out before we put it in storage). The water is hooked up to the faucet correctly, what could be wrong with it?
  • sheril623 Apr 20, 2010
    The humming does start, no water in the fill valve.
    Sergeant:
    Champion:
  • 324 Answers
Check to make sure you have water at the fill valve.where the water goes into the valve take of the hose going to the faucet and see if you have water there when you turn the faucet on.does the humming start as soon as you push start?
Posted on Nov 13, 2008
Dishwasher lower spray arm will not move or turn by hand
Search Results
    Dishwasher Spray Arm Not Turning ' Home Guides ' SF Gate
    homeguides.sfgate.com > Foreclosures > Other Foreclosures
    Remove the lower tray of the dishwasher to freely access the spray arm. Turn it byhand, and if it doesn't move freely, you will need to unscrew or unbolt any ... How to Remove the Lower Wash Arm on a Maytag Dishwasher MDB7000AWW ...
    Maytag dishwasher bottom spray arm doesn't turn - Home Repair Forum
    www.homerepairforum.com > Forum > Indoor Home Repair > Appliances
    Jan 3, 2009 - 5 posts - ‎3 authors
    I'm now soaked, but I was able to determine that the lower arm isn't turning. There's a LOT of water coming out, but it doesn't move. Turning by hand I can turn it freely, it spins like a top. .... You may not post new threads; You may not post replies; You maynot post attachments; You may not edit your posts.
    How do i remove the lower spray arm of my Maytag .
Jan 18, 2016 | Maytag Dishwashers
NO HOT WATER
it has a hot water element that can burn out
have it checked by an electrician or technician
Sep 11, 2017 | LG LDF6810ST Stainless Steel Built-in...
Dishwasher leaves behind gritty residue i am not sure of what to try...
We have a Kitchen Aid dishwasher, 10 years old, never any problems until 2 weeks ago, then we started noticing a gritty subtance on the dishes and glassware. We're on well service, psi 40-60. water hardness is 6 grains. small trace of sulphur, and we have a Mermaid sulphur system, then a complete house carbon filter, and finally a Culligan water softner. Checked everything, Water temp. at kitchen was 120, all cycles on dishwasher were operating. Called in repair service, he says something is breaking down in the dishwasher, best to buy a new one. That'll be $150.00. Thank you very much. Tried the white vinegar, no change. Next bought 2 bottles of Dishwaser Magic. Slight improvement. Next bought 1 bottle of Finish Dishwasher Cleaner. Bingo. The thing is like brand new. even the trays slide in/out much easier. None of the dishsoaps contain phosphate, which is what helps disolve the minerals in the water. I'm not sure what the gritty stuff is, maybe the buildup over time, and it just keeps getting redistributed through the wash and rinse cycles, and finally baked on in the dry cycle. According to a tech with many years repairing appliances, the majority of their calls are for dishwasher poor performance, all because they removed the one compound that's been cleaning our dishes for years, Phosphate. We've always used Cascade gel soap. best on the market today, Finish Quantum. We tried it and dishes look terrific. It's a small tablet that fits in the soap dispenser. All Mfg's. today recommend that you run a dishwasher cleaner once a year, Experienced tech recommends every 3 months maybe more if you're on hard water. Good luck.
Mar 25, 2010 | Maytag Dishwashers
Dishwasher not cleaning/rinsing properly
try connect a water filter (carbon and particle), and connect the machine on output filter, mormaly resolve this problem. Some old houses has water supplie problems, as dirty water, and contamined problems, check for water purity.
Jan 14, 2010 | Dishwashers
Leak
your going to have to take apart the bottom panel of the dishwasher. If there isn't any screws it should slide off. After that, move the strip of insulation, now look at the power. There should be 3 wires, seperate those from other wires.(note-turn breaker off at box before doing this)now when you finish that, go in to the cabinet next to the dishwasher. The one under the kitchen sink. Find the drain line from the dishwasher and dissconnect that. while you are in that cabinit look for the water supply to the dishwasher and shut off and dissconnect. Now open the front door to the dishwasher and unscrew the sides and top off. Close door and pull gently to get full access to all the seals.
Apr 29, 2009 | Home
New installation - clicks on wash cycle but no wash
DEAR FRIEND,
ngfam1 here for you!
I am happy to be of assistance!
Call Frigidaire and explain that you never used it till today because it was in storage from day one. that you had to ship out to Iraq! now your home and it came out of the box dead!!!!!!
this way the supervisor will fix it for free!!!
For this problem you will need to use factory service!
Here is the service company I refer my appliance customers too!
A&E Factory Service
A Nation Wide Company. / Available 24 / 7 for arranging appointments! In the USA.
1(800) 905-9505
If this dryer is 10 years old or more do not spend any money on it!
The new ones are much more efficient! If you have to replace it buy a Speed Queen , it will do 8 loads a week for 25 years!
It's the last washer and dryer I will ever buy!!!! And less expensive than a top of the line unit!
You will be fine now!
Thank You
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF!
Aug 24, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
30 hotpoint dishwasher
#1. If you have to put downward pressure on the float in order to fill, then float switch is not OK.
#2. It would seem as though your pump impeller is missing some, or all vanes. (Not pumping water out).
#3. It will become even more difficult to find parts as time goes on.
#4. 30 years...It has done it's job. It has paid for the trip, It's time to move on, What else can I say.
Jan 27, 2008 | Dishwashers
Miele dishwasher
If your amp is less than 5 years old you maybe able to get it fixed for free at http://www.domgen.com check it out we have all our contents covered. This is better than your normal home insurance. Don't matter you could claim 100 times and never loose out. check it out! Also don't 4get to leave me feedback cheers raverbaby01
Aug 27, 2007 | Miele G880 Dishwasher
Dishwashers Logo
201 people viewed this question
Top Dishwashers Experts
