Question about Motorola Mobility MOTORAZR2 V9 Cellular Phone
My battery does not last too much
Is it because of the use that i give it to it?
or it just like that?
should i replace the battery?
  • Anonymous Dec 06, 2008
    with very little use my battery is the same
    Problem Solver:
  • 6 Answers
Ideally, you wouldn't recahrge the battery until it's completely flat. If you're charging it before then, you can mess with the battery, and it forgets how to retain charge.
Try letting it go completely dead, then cahrging it for around four hours completely. (don't disconnect it during this time). Let it run until it dies again, and repeat the process over a few times. You should find that after a couple times, it works fine, and you can get up to three days of battery life if you don't use it a lot.
Posted on Jan 01, 2009
Korg sp-250 randomly changes the voicing
When was the last time you changed the batteries? You may have gotten a pack of expired batteries the last time you replaced them. I suggest changing batteries.Jimmy
Apr 08, 2012 | Korg SP-250
Battery not holding charge on my 14.4v lithium iron drill giving short battery life during use, from new the battery would last approx 2 full days usage now 2 hours is the longest time is there any way to...
Sometimes rechargeable batteries loose charge with time. Replace the battery type on the drill and the duration will be back to normal :)
Apr 05, 2010 | Garden
My son's pathfinder watch's screen went blank. Just dead battery? Thought it was solar powered. Thanks.
They do have a battery to tide them over the times when there is no light shining on them.
Consult the maker about replacing the battery, it should last for years.
The instructions may give you an indication of how long they should last. Otherwise contact them.
Go to Casio.com to obtain a contact number or email address.
Mar 07, 2010 | Watches
Battery
seriously even the best of batteries only last 3-5 hours without sever deterioration for prolongued and sustained use--thats the battery game and plan for expensive replacement genuine or copy
Feb 21, 2010 | ASUS Eee PC 1000H Laptop
How long should a crv3 battery last?
I use crv3 batteries in my Pentax istD. Believe it or not, they last over a year! Keep in mind that the simple act of testing the voltage of a crv3 will shorten its life. Have you tried cleaning the battery contacts in the camera with a cotton swab lightly dampened with rubbing alcohol? Sometimes, an invisible film on the contacts forms and gives a false reading of battery life.
Dec 08, 2009 | Pentax Optio S60 Digital Camera
After charging d battery when we remove cabele
the battery sounds like it has bad battery memory and needs to be replaced. Before you replace it look for software to give you the battery's status (how much charge it holds out of how much it should hold by design. for exaple i am using ubuntu linux and my battery reads
Capacity: 29% (Poor)
Current charge: 14.3 Wh
Last full charge: 14.3 Wh
Design charge: 48.8 Wh
Charge rate: 10.0 W
now that is my bad battery for staying at home and leaving it plugged in all the time (that kills the battery) i have another battery that reads
Capacity: 97% (Good)
Current charge: 38.8 Wh
Last full charge: 47.5 Wh
Charge rate: 5.5 W
it is my battery for travel. the difference between the two is that the battery that reads Capacity: 29% (Poor) only lasts about 40 minutes but the battery that reads Capacity: 97% (Good) lasts 3 hours. you probably have a low Capacity.
Jul 29, 2009 | Adapters.com Computers & Internet
Battery last for about 1 day only
hi sir... dont change ur batteries or go for new one... Its becuase the battery pin available in ur mobile device has got damaged... so its unable to store charges for a longer duration...Better give ur mobile for service and they will replace u with new pins.. dont waste in getting new batteries..
thank u rate me!!!
Feb 07, 2009 | Sony Ericsson W910i Cellular Phone
Epson 3100 life battery
I have a 3100z and you are right that alkaline batteries do not last long. The thing to do is buy a couple of sets of NiMH rechargable batteries and they last much longer. I,ve just been on holiday and had no problems at all with the batteries. (Although the camera does not give much warning when they need replacing).
Sep 13, 2005 | Epson PhotoPC 3100Z Digital Camera
Battery
If you take a look on the back of your battery, it will give you a mAh value ie 1550mAh, the higher the number, the longer it will last.. most replacement batteries are 1550mAh, and very cheap, but you can get 3000mAh batteries, which should last twice the time, but they´re as much as 5 times as expensive... they obviously take longer to charge too..
Sep 08, 2005 | HP iPAQ H5550 Pocket PC
Motorola Mobility MOTORAZR2 V9 Cellular Phone Logo
74 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
