Question about Thomson Lyra PDP2335 (256 MB) MP3 Player
Failure to record to the SD card
Hello, hope someone can help... I regularly record radio shows but recently have found less internal m emory available. New battery doesn't make a difference? Where's my old internal memory gone? What really doesn't make sense to me is that my player recognises the SD card, and tells me how much memory is available on it - but tells me there's no space to record on when I try to record. How do I 'direct' my recording to the external memory? Thanks.
2 Suggested Answers
SOURCE: Will not play MP4 format
I use a converter and convert the file into DivX format and that works fine on the Lyra
Posted on Oct 20, 2008
I have an intova IC12 digital camera. It will snap a picture and show on the display but not save to card?
Please save any images to your desktop that you want to keep. Access format function in camera's setup menu and format both SD card and internal camera memory to clear all data. After formatting, perform a sys reset that is also found in the setup menu. If your camera still cannot save images to the SD card after performing format and sys reset, then the card reader/writer is probably broken. Please contact us directly at 808-837-0074 if you have a sales receipt showing date of purchase 1 year or less which would qualify for warranty exchange under our 1 year warranty coverage.
Thank you
Apr 25, 2015 | Intova Ic12 Digital Camera
My Kodak DX 6490 will not read my 2 Gb or less SD Cards. It keeps recording to the camera memory. I will not play videos onto my digital TV. What should I do?
Hello, Have you tried formatting the memory card with the camera?
If a card is formatted with another camera or if it is new you should format it with the DX6490.Hope this helps.
Russ
Mar 04, 2012 | Kodak EasyShare DX6490 Digital Camera
How do you save music to the sd card
The microSD card for the Stiletto2 can only hold your MP3s.
All Sirius content is recorded to the internal memory of the Stiletto2.
Hope this helps.
May 03, 2011 | Sirius Stiletto 2 Satellite Radio Receiver
When l take my SD card, it still says " DCF Full Error"
Hello and Welcome
The DCF error message with your Samsung camera nearly always occurs when you're using a memory card that was formatted with a different camera, and the file format structure is not compatible with your Samsung camera. You will have to format the card with the Samsung camera.However, make sure you download any photos to your computer first
Anymore help, I am here to help
Best of Luck
Concerned:
Uxair Shah
Mar 14, 2011 | Samsung ES30 Digital Camera
We have a client with the Sangean PR-D8, the problem are that its keeps corrupting the file on the SD card when recording using the Timer setting it show that its record but when complete the MP3 file...
I have similar problem with this set - recordings are corrupted. Every few seconds a fraction of a second is cut off. Probably it's a problem with SD card. Someone reported this problem in amazon.com customer review for Kingston 4 GB Class 4 SDHC Flash Memory Card SD4/4GBET
Feb 09, 2011 | Sangean PRD8 AMFM Radio
How many minutes does it's 64 mb internal memory hold? It says it has a 64 megabyte memory without an sd card.
The internal memory included in that device isn't going to be good for more than a minute or two of video recording. Because of the detail required in video capturing as well as the audio feed that it has to record, the file sizes can get quite large. I would recommend grabbing yourself at least a 2GB SD card, and actually probably even a 4GB if you were looking for some longer record times.
Thankfully, SD memory has gone down in price CONSIDERABLY over the years, many retailers often have 4GB SDHC cards for $20 or less.
Hope this helps!
Dec 09, 2009 | Polaroid DVF130 Camcorder
Camera won't record on SD card
SD cards have become the industry standard....but beware...there are SD cards NOT backward compatible...i.e.,some cams won't take 2GB or larger; then there is SDHC; SDHC(HD); RUNS FROM 512G thru 32GB HC/HD; ECT...check your cams manual for SD card compatibility.
Apr 27, 2009 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Olympus DM-10,locked in a "Read Only" mode
The recorder should be formatted only by using the internal FORMAT function found in the recorder’s Menu. Formatting using the computer may corrupt system files needed to run the recorder, so computer formatting is not recommended.
Apr 10, 2009 | Olympus DM-10 Digital Voice Recorder
Memory is full
You can only use a 2GB SD card. It is in the manual. I'm not sure on dvd.
Oct 24, 2008 | Mitsuba DV9002 Flash Media Camcorder
Accessing the cd
here's the link for the user manual; http://books.jvcservice.com/download/1071186832/LYT1533-001D.pdf Check page 2 - There is no CD recording device. A DVD burner drive is sold as a separate unit(page 47), the main camera unit has an internal hard disk drive, and the option of recording to an SD card. check page 15 for details of the SD card option. If what you want to do is access the internal hard drive, be aware that this would void the warranty, and is not recommended unless there is a fault with the unit. If this is the case, please post back with details. Hope this helps :)
Jul 08, 2007 | JVC Everio GZ-MG27 Camcorder
Thomson Lyra PDP2335 (256 MB) MP3 Player Logo
53 people viewed this question
Top Thomson Audio Players & Recorders Experts
Damen Wong
Damen Wong
shaun taylor
 Grubhead
Grubhead
Are you a Thomson Audio Player and Recorder Expert? Answer questions, earn points and help others
