I need a passkey code for registering my logitech cordless vantage hs passkey ps3.
SOURCE: I need help with a cordless remote to work with my
i believe that you controller takes batteries and works along with a receiver that looks similar to a flash drive. hope this helps :)
SOURCE: My Logitech Cordless Vantage Headset won't pair
I had the same issue, apperently the manual is wrong about the steps. To enter pairing mode the turn the headset off. Then start holding the middle button again till the headset turns on (green light + tone, after 5s), but keep on pressing it till it starts to flash alternating red and green (after another 5s). The PS3 should be able to pick it up withing seconds. My **** manual specifically said that the headset should be off. Which is not true.
SOURCE: i need the pass key for the vantage headset i lost manual
The default keypass is 0000
I am not sure whether you are able to change this, but if for some reason the default code doesn't work for you try turning the headset on and press the reset button with the tip of a pen for a few seconds.
SOURCE: how do you connect a logitech cordless precision
Here the user manual all the process in details thanks andhave a nice day - J -. http://logitech-en-emea.custhelp.com/cgi-bin/logitech_en_emea.cfg/php/enduser/fattach_get.php?p_sid=2HFWiQ1k&p_li=&p_accessibility=&p_redirect=&p_tbl=9&p_id=6514&p_created=1176798878&p_olh=0
