Question about Hyundai ImageQuest L70N 17" LCD Monitor
Hyundai imagequest B90D orange standby
Hi my Hyundai imagequest B90D stays black with orange light however after trying another spare monitor on same pc there is no problem.Tried contacting hyundai for repair terrible service been waiting 4 weeks and still no news after numerous emails.Will never buy another hyundai again.Any advise would be welcomed.
  • stewiebee123 Nov 13, 2008
    Hi thanks for quick reply however thought there may be a quick fix,the monitor as 7 months of the 3 year warranty left however getting it in for repair is proving a nightmare.Contacted UK RepairTech Ltd as advised by hyundai but taking forever now been four weeks likely be after christmas at this rate.The lesson must be dont buy hyundai warranty service is rubbish.
    MANY THANKS
  • 558 Answers
Hyundai will not repair this however a electronic service center aka tv repair may. I can do it as most likely is it several capacitors that have blown. Hyundai is also a little picky to open they are assembled very well actually compared to other monitors (they are difficult to open up) let me know what you would liek to do.
Posted on Nov 13, 2008
  • Scott Hill
    Scott Hill Nov 13, 2008
    get a lawyer let them pay for it
    meanwhile a service center like for televisions will be able to do the work for you .
    L8r
When I turn on my monitor, it briefly displays the image, but then turn to black
This usually means the backlight has failed and it is not cost effective to repair. Some monitors with a faulty power supply will exhibit this fault too. If the power supply is external (a little DC "brick") Try and find a replacement with equal voltage and similar (preferrably more) current rating (e.g. 12VDC, 3 Amp). This can be a cheap fix - especially if you have a spare power supply lying around. Often many different monitors can use the same power supply, so if you have another dead one, or know someone with one, you can try that - the connector will even most likely be the same.
Mar 10, 2011 | Hyundai ImageQuest B90A 19" LCD Monitor
My hyundai imagequest l70n lcd monitor started to started to make a high pitched noise and the screen went black but the green light stayed on but now i plug it in and nothing happens no picture and no...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 12, 2010 | Hyundai ImageQuest L70N 17" LCD Monitor
Back light does not turn on
The problem can be caused by bad caps in the power supply, bad inverter circuits, bad lamps. You need to open it up and see if there are any bad caps with bulging top first, post back so we can guide you furhter, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Feb 21, 2010 | Hyundai ImageQuest L17T 17" LCD Monitor
My Monitor
Ok? first what you need to do is to hibernate your computer. You can do that by pressing the power button as long as you need for the computer to turn off. Then you turn your computer back on and press the power button ON THE MONITOR twice but you MUST do this really fast. Then what you need to do is to find a circuit breaker on the back of your computer. switch it to the off position then turn it back on. Then turn your computer on. This should fix your problem.
Dec 31, 2007 | Hyundai ImageQuest L70N 17" LCD Monitor
Blackness on monitor
Hi, A common problem to LCD displays. If you can somehow still see the desktop (...barely see the picture ...) then chances are that you have a backlight problem. This may either be the light itself which is a thin florescent lamp (CCF) or the inverter that powers it. Hope this be of some help/idea. Post back should you need additional information. Good luck and kind regards.
Aug 30, 2007 | Hyundai ImageQuest ImageQuest Q15S...
Standby mode
Check the video connection the video card. You can try another monitor to see if it does the same thing. The video card could be bad.
Jul 15, 2007 | Hyundai ImageQuest F770D 17 in.CRT...
Case removal
Usually a 'Snap together' operation Be craeful now - dont break a tab and be aware of high volts
May 21, 2007 | Hyundai ImageQuest B90A 19" LCD Monitor
Hyundai ImageQuest L70N 17" LCD Monitor Logo
451 people viewed this question
Top Hyundai Computers & Internet Experts
Tom Stevenson
Level 1 Expert
Randy Schumann
Randy Schumann
Are you a Hyundai Computer and Internet Expert? Answer questions, earn points and help others
