Question about Panasonic TH-42PWD7 42 in. EDTV-Ready Plasma Television
I have a Panasonic TH-42PWD7 flat screen it's hooked up to a receiver and a cable box from time warner. It's not mine. I'm staying at my friends house. I have sound coming through the cable/sat channel on the receiver/tuner, but the TV says no signal. I played with the signal inputs now so many times I don't know what the heck they're supposed to be set on. But if I have sound of cable, I feel like the TV should be getting a signal.
    Champion:
  • 225 Answers
There is sometimes a way to turn of the TV speakers, but it usually cannot be set that way by accident. Plan on audio board damage. Perhaps you fed the TV too loud an audio signal, then overloaded the amp board. I would consider them gone.
Posted on Nov 14, 2008
I can't get a signal because this tv don't have cable antenna terminal the tv has rgb terminal. I don't know what to do?
RGB is for a computer screen display signal and has nothing to do with TV display of channels. You must have a Component hook up, it is a yellow cable, a red and a white one. Yellow is video signal, the red and white are sound.
Sep 12, 2016 | Panasonic TH-42PWD7UY 42 in. EDTV-Ready...
Panasonic plasma TV TH-42PWD7 blacks out..
These blinks (flashes) are fault indication. By the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside the TV. Count the blinks occur at one time switch ON, carefully. Do it once again, and make sure about the number of blinks. If the flashes are continious, non-stop, the main system control IC should be suspected. If you wish to get more details, check the site linked here. It has blinking codes detail to many brand TVs. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 20, 2014 | Panasonic TH-42PWD7 42 in. EDTV-Ready...
Hdmi cable no sound
HDMI cable going from my time warner HD box to my new 50" panasonic viera (TH-50PZ800U) no sound, amazing video. the HDMI is a belkin btw if it's even needed to be known.
Aug 17, 2012 | Philips 52PFL5603D/27 52 in. LCD TV
How i do tv chanel tunig
Hello Ansarielectr, The Panasonic TH-42PWD7 is a professional grade progressive wide screen plasma display. It's not your normal HDTV. You probably already know this. This display requires a component /composite video terminal Board that mounts to slots 1 & 2, or slots 2 & 3. The item number for this component is TY-42TM6Y and can be purchased through the Panasonic support website here for about $270. Once you have this component, you can connect the TH-42PWD7 to a digital HDTV cable box to receive signals. Just make sure you're on the right input signal. Hope this helps.
Dec 28, 2010 | Panasonic TH-42PWD7 42 in. EDTV-Ready...
3 PANASONIC TVS HOOKED UP TO CABLE SYSTEM AND ARE ON 37" PANASONIC TH-37PX50U WORKS FINE BUT THE OTHER 2 TVS DO NOT WORK. THE CABLE SYSTEM HAS BEEN CHECKED TWICE AND WE ARE TOLD IT IS OK BY TIME WARNER...
unhook 1 tv at a time leaving 2 tvs each time hooked up. try every combanation Possable to see if it's a tv problem or if when you have all 3 tvs hooked it makes the signal weak. this can happen cable guys say no but it can been there done that. if 2 works and 1 dont in every combanation the problem is in the cable system. most cable guys check the signal outside. with the splitter block unhooked. this gives a false reading.
Oct 31, 2009 | Panasonic TH-37PX50U 37 in. HD-Ready...
Audio drop outs when using HDMI connection on new Viera
The way I solved it was to go into advanced settings and change the audio input connected to the hdmi port to component. I had to run an audio cable from the cable box into the TV but since I did this we haven't had the problem.
Jul 13, 2009 | Panasonic Viera TH-50PZ80U Plasma TV
Volume Problems: Panasonic TH-42PZ700U
please could you send me tips of what the problem of my plasma keeping stuck pixiel panorama LCD Tv model 42LC68T
Mar 29, 2009 | Panasonic TH-42PZ700U 42 in. Plasma...
I just bought the sc-pt660.Is there any way for me to hook my regular tv(not a flat screen or hdtv)or my time warner cable box to this to get sound from movies on tv.I dont see any audio in ports.thanks
You can use the PANASONIC AUX IN ports for your TV or CABLE BOX audio, unless you run the DIGITAL CABLE into the PANASONIC, this may be available on the CABLE BOX or your TV, my suggestion is if you use the Cable box to view TV then use the CABLE BOX AUDIO OUTPUTS, you would be better with the CABLE BOX digital output INTO YOUR panasonic, but if it is already being used take the AUDIO out analog connection from your cable box into your Panasonic AUX INPUTS, then set the Panasonic to AUX IN mode.
Feb 28, 2009 | Panasonic SC-PT660 Theater System
Screen blanks out int when on local channels
I had the same problem (a flashing HDMI 1 text box in the upper left hand corner of the screen every +/- 10 seconds) and rebooting the cable box seemed to help. I'd previously tried disconnecting and reconnecting the cables, but wasn't successful. I assume my problem originates with Time Warner Cable.
Jan 29, 2008 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Panasonic TH-42PWD7 42 in. EDTV-Ready Plasma Television Logo
477 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
