Question about Sony STR-DE197 Receiver
Sony str de197 fm sterio receiver
When the receiver is on I get interference lines on tv. These come and go but ate constant until i shut uoff receiver. Cable box is next to receiver. I plugged in other plug-in, changed splitter, and A-B switch. DVD player of or on makes no difference. Also moved receiver 4 feet away, no luck. Speakers use monster cable and are 10 foot away from receiver.
4 Suggested Answers
SOURCE: sony str-dg510
Why dvd sound does not play on sony str-dg510?
Posted on Feb 02, 2008
  • 10594 Answers
SOURCE: sony str-dg820. having a problem getting video on tv
Hook up Composite / Component Monitor Out wire from receiver to TV video input because receiver will not change analog input into HDMI
You need to connect receiver and TV through analog video terminals as above.
Actually you are expecting that receiver will convert DVD player and Xbox analog video input into digital HDMI signal for TV and This is incorrect.
Posted on Jan 04, 2009
  • 8546 Answers
SOURCE: Subwoofer hum from STR-DH800
That points pretty much to a bad shield on the cable. Have you tried another one? Another thing to try is to rotate the AC power cord on the sub (if it has one). Sorry, too lazy to look it up.
Posted on Dec 29, 2009
  • 5807 Answers
SOURCE: Sony STR-DE197 AM-FM Receiver. Has
Inside the Receiver there are electronic components mounted on the aluminum
heatsink ( Audio Output Power Transistors )
it may looks like these :
MN2488 ( Q753 )
and usually paired with MP1620 ( Q754 )
You may have to check on those two pairs of power transistors
and replace in pairs.
( which means if any of the two is bad , have them both replaced )
Check also the audio signal on the right channel input , if it
is on the same level of those of the left channel.
These components are available at:
Posted on Feb 22, 2011
0 characters
1 Points
I have a constant "crackling" noise in the left channel. I've replaced all 4 power transistors. The crackling is still there. Any clues?
Look for an open resistor in that channel. could be the large emitter resistor, or one of the low-ohm flame-proof resistors.
Jan 30, 2013 | Sony STR-DE197 Receiver
Bad fm reception
This is probably due to the area your FM antenna is placed. If your house/office is surrounded by buildings, the signal will weaken and fade before it reaches the antenna. Also, if it is surrounded by many walls(i.e. deep inside an office complex), you will have bad reception.
Nov 02, 2012 | Sony STR-DE197 Receiver
Hello, I need help with my sony str-de197 receiver. Then I hit power on button, there is a click sound inside the box, but nothing happens, there is nothing on display too. I have checked 2 fuse's, it's...
It sounds like the switch might be OK mechanically but not electrically. Have a look to see if you can check the connections on the switch. Perhaps there is a broken or loose or bad solder joint.
Oct 28, 2009 | Sony STR-DE197 Receiver
Protect appears with power on
This has happened on my receiver but it goes away if I switch it off and turn it back on again.
Oct 15, 2009 | Sony STR-DE197 Receiver
My Sony STR-DG600 Receiver constantly goes into Protect Mode when using FM or XM.
Check to see if the antenna is firmly connected and not making contact with the receiver chassis or other inputs/outputs.
May 09, 2009 | Sony STR-DG600 Receiver
How do i hook up my tv, speakers, and receiver together. i bought it with out an instruction book. marie
Usually, you look for the "audio out" on your TV and connect it to the "audio in" on your receiver and, then, connect your speakers to the speaker connectors on your receiver. I have the same receiver but I don't have my instruction book in front of me so I will watch to see if your problem has been solved and, if not, try again with my manual in front of me.
Feb 23, 2009 | Sony STR-DE197 Receiver
Sony receiver does not change components
Check to be sure that none of the buttons are stuck on. With the unit off, press each of the buttons. You should be able to feel the button engage. If they all feel like they are working, the internal switch itself may be shorted in the closed position.
Update this with what you find.
Aug 18, 2008 | Sony STR-DE197 Receiver
Sound Problems
are u runing dvd player to tv 1st audio and video and eco meens tv is on with sterio same time erther one or other run the the dvd audio to dvd in on sterio and video cables to tv only dont use souind on tv just sterios if u want tv sound tooo use tvs rca outs back into sterio on a ch tv in ok
Jan 24, 2008 | Sony STR-DG800 Receiver
Sony STR-DE197 Receiver Logo
32 people viewed this question
Top Sony Audio & Video Receivers Experts
Pieter Vleeshouwers
Are you a Sony Audio and Video Receiver Expert? Answer questions, earn points and help others
