Question about Technics Audio Players & Recorders
Technics se-hd70 hifi, showing fault F61 - Technics Audio Players & Recorders
  • 4234 Answers
SOURCE: My Technics DV-170 shows F61
That is a protection indication. This means that the output amplifier section has a problem that was detected and a shutdown occurred to prevent further damage. I don't have a listing for your model, so I can't provide you with too many details, but look for a large black IC attached to a heatsink. That should be the output amp pac. If there is not one, there should be 4 3-legged parts (transistors) and one or more of those may have failed. I have also seen cases where a voltage regulator that supplies the driver circuits has had bad connections thereby shutting down the driver circuit.
Keep us posted.
Dan
Posted on Jun 25, 2008
  • 909 Answers
SOURCE: Hello My son has given me a Technics audio stack
Each unit will have it's own manual, so quote each number, unless it's a package.
www.technics.com/support
try this site if not found lose the /support.
Posted on Aug 24, 2009
  • 336 Answers
SOURCE: stereo system technics sc-dv150 showing fault f61 how do i
f61 is a bad voltage code. I will probably need an output ic or a voltage ic.
Posted on Oct 16, 2009
dunnbiker
  • 8546 Answers
SOURCE: Technics amp hd81 shows fault
IS it the amp fan failing? It could be something simpler and cheap.
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it '*****'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
WE don't fix things, nor do we provide parts. We provide advice and answers and usually simple direction for where to look for answers, which are usually available somewhere on the Internet.
You can find the Service Manual (not necessarily for free) by web searching "Technics HD81 Service Manual". It will identify the fan part number. Then web search for THAT.
Only YOU know where you are so we can't point you to a repair tech. labor charges will vary. Once again, web search.
Posted on Aug 07, 2011
gopakumarg43
  • 75417 Answers
SOURCE: f61 technics hifi fault
What is the problem you faces with this device? Provide more details please.
Posted on Jun 06, 2012
Technics 1080 pre amp volume control is not functioning correctly
Technics SE CA1080 Service Manual
there is a chip called an operational amplifier under a heat sink on the pcb,that fails when it get top volumed for two long theres regulators with heatsinks.
it is listed as,
Technics SE -CA1080 amplifier F61 fault,
May 13, 2015 | Technics Audio Players & Recorders
What is the speaker output per channel for technic se-350?
seems to be 22 watts rms, 35 watts peak at a 4 ohm load. with 8 ohm speakers, the power would be reduced 50%, but the distortion levels would also be drastically reduces
Jan 02, 2015 | Audio Players & Recorders
Technics f61
Look for bad solder connections on the amp IC's and voltage regulators...common problem on these.
Dec 08, 2013 | Audio Players & Recorders
F61 technics hifi fault
Jun 06, 2012 | Technics Audio Players & Recorders
It doesn't want to work anymore!! There appears to be no power to the Disc Player, Cassette Deck or the Sound Processor? The Amplifier screen displays F61 Hope you can be of assistance Thank you
With my crystal ball I can see its a Technics 4 part Hifi micro system you have although the image is just too fuzzy for me to tell which model.!
Joking apart...Your power amp module has a blown channel. These are specific Technics modules and some for the 3/4/5 channel units are quite expensive UK £40-80 just for the module + fitting costs
No DIY fix I'm afraid
Sep 04, 2010 | Audio Players & Recorders
Stereo system technics sc-dv150 showing fault f61 how do i
Oct 15, 2009 | Audio Players & Recorders
Hello My son has given me a Technics audio stack system, and each unit has its own number SL HD70, ST HD70, SE HD65 and RS HD70, which numbers do I quote when asking for a manual, and where can I get a...
Aug 24, 2009 | Audio Players & Recorders
Technics dvd stereo sound processor sh-dv290
The F61 is essentially a "protect mode" mesage. A problem was detected and the unit shuts down. This translates into either the amp pac being defective ($approx $95 for part) or a defective regulator circuit (less $$). In either case, the repair is not the simplest to do. Check around for a Panasonic authorized service center and call to get an estimate. This is a relatively common fault, so you should be able to get a ballpark repair cost.
Dan
Jan 29, 2009 | Technics Audio Players & Recorders
F61 Error
take off your fan on the back and clean it this fixed mine
Sep 05, 2008 | Audio Players & Recorders
572 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
