Question about Digimate DGL26 Television
Lines while watching TV
While the TV is on there are line on it....I have had the TV for a yr not sure what to do I thought i was the cable wire but i tried it in another room and the problem is still there
    Champion:
  • 225 Answers
Lines = bad circuitry. Could be a microchip. Could be a bad power supply to the microchip. Only a tech could look and tell.
Posted on Nov 14, 2008
My LCD TV has a vertical line on the right side of the screen. What causes that?
Search Results
    how to fix horizontal or vertical lines on lcd tv - YouTube
    ? 4:52
    https://www.youtube.com/watch?v=k2QpYJp6MU8
    Apr 12, 2014 - Uploaded by cr4zyw3ld3r
    how to fix horizontal or vertical lines on lcd tv ... Bad T-Con/Mainboard(causes vertical/horizontal lines or half of thescreen is black)
    How to fix / repair vertical lines on half of LCD tv screen ...
    ? 5:23
    https://www.youtube.com/watch?v=8P_i-JIsrYA
    Jan 27, 2012 - Uploaded by chipotletv
    It shows how I fixed the vertical lines on the right half of a Samsung LCD screen tv. Music on video "Crazy ...
    how to fix led tv vertical lines on screen 55 ... - YouTube
    ? 9:47
    https://www.youtube.com/watch?v=zE0eqB4Ppjw
    Nov 11, 2012 - Uploaded by LUFERQUINT
    HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ... YOU MAY HAVE, GIVE IT A TRY BUT DO IT ON YOUR OWN RISK!
Jan 26, 2016 | Televison & Video
JVC 36" color sterio tv lines on top of screen
does the problem occur while watching dvds. it is possible that it is an issue with your tv but i would try switching off of cable to a game console or dvd before i said for sure it was the tv. you also might try using another port on your tv such as hdmi, s video, rca or componet ports . if any of those ports work i would replace my cable from the cable outlet.
Feb 17, 2012 | Computers & Internet
LG LED 42LE5300. We just bought this TV last week. When we first installed it, we noticed uniform horizontal tiny lines on the picture. We tried to change the cable box, use high res. HDMI, even tried...
Does any OTHER TV show the same problems when connected to that very same cable connector? It could be a bad connector, or a bad crimp on the connector! Did you try cleaning the center wire on the (disconnected) cable connector? I'm talking about the WIRE cable, not the TV connection!
Apr 29, 2017 | Televison & Video
Just connected my 4 yr old Jwin DVD player to a new Samsung HDTV. I am using "red, white yellow" connecting cables for the "audio; video in/out" as my connection. S-Video and Coaxial...
Those RCA jacks you are using might be the problem. Lowest Quality only means your TV is ment to handle 720 to 1080 lines- the RCA cables you are using can only handle up to 500 lines. The likely culprit is the RCA cables are low quality or bent or worn. Get new RCA cables and try again. Just be sure the plugs go all the way into the connectors and the wires are not crushed or chewed on by a pet.
Jun 02, 2017 | Jwin JD-VD147 DVD Player
My tv jumps with red lines while watching. JVC
It sounds like the begining of as convergence problem or cold solder on convergence board - have a tech have alook
Sep 14, 2009 | JVC AV-48WP30 48" Rear Projection...
Sony Bravia KVL-V40A10 - pixelated lines top and bottom of screen
Are these lines visible regardless of what device (DVD player, cable box) you are watching?  If so, then yes, it appears the LCD panel is failing.  If you only see the lines watching one device, it could be the cable/wire or the device itself.  Now it can also be the related input jacks too so connect the device to another input to be sure.
Mar 24, 2009 | Sony BRAVIA KLV-S40A10 40 in. HD-Ready LCD...
My 3 yr old tv has developed lines in the picture.
remove set back find large transformer with red wire attatched to pix tube find control labeled G2 reduce slightly wit set on with no sgnal on avideo inpt
Mar 11, 2009 | Samsung TX-R3079 Television
Hdmi cord causing purple and green lines
It may be a ground loop caused by cable televisoin and the Ps3, as PS3 uses a 3 prong plug. Try unplugging the ps3 power cord and see if the lines go away. If they do, it is a ground problem...usually with cable tv. If this is the case, try a good quality power bar with cable suppression jacks on it. It will help eliminate the ground loop in most caese.
Dec 28, 2007 | Sony Playstation 3 (PS3) Console
Digimate DGL26 Television Logo
81 people viewed this question
Top Digimate Televison & Video Experts
Jaime Hernandez
Computer Repairing
Computer Repairing
ray gallant
Are you a Digimate Televison and Video Expert? Answer questions, earn points and help others
