Question about Microsoft Windows XP Home Edition
Wont restart my compuetr
I keep pressing f10 for system restore it starts to activate then the screen stops suddenly says please wait and does nothing else ,also if you try to load windows xp the screen says enabling sleep mode and turns off
  • 1 more comment
  • tommclean62 Nov 14, 2008
    desktop
  • Rahul Panicker May 11, 2010
    I Hope you have a HP or a Compaq system .
    f10 is not system restore it takes the computer to the factory settings.
    Queries -
    1. What message do you get when you start the computer normaly.
    2. Which version of windows do you have.
    3 Do you have a windows os cd
  • detrosuk May 11, 2010
    is this on a laptop or dektop? also do you need to perform the system restore or are you in a position to start afresh?
  • 903 Answers
If your computer has restore capabilites then you need to enter the bios and make sure that D2D recovery is enabled. Do this by pressing F2 on boot.
Then you need to press Alt and F10 not just F10 to enter the recovery console. But press it once the manufacturers screen appears such as tiny, gateway, Hp etc.....
If this does not work for you then make sure that CDrom is set as first priority in the bios boot options if you are attempting to Repair windows with the disk.
I hope this helps
Posted on Nov 14, 2008
How do I factory restore my HP Pavilion dv4-2112TU with the recovery menu, safely.
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer)
Here are a few things you can do or try
Restart the computer. If you are already in Windows, you can do this from the Windows Start menu, go to Turn off computer and click Restart. As the computer restarts, watch for a progress bar at the bottom of the screen. press F8 about once every second. Immediately press F8 before the progress bar reaches the right side of the screen. From the Windows Start-up menu, highlight Safe Mode and press Enter. Wait for your desktop to appear, and then make the necessary repairs (for example, uninstall programs or devices). When the repairs are done, restart the computer, and allow it to boot normally.
Alternate:
From the Windows Start menu, click Run. In the Open field, type MSCONFIG and click Ok. On the BOOT.INI tab, check /SAFEBOOT.
Click Restart when prompted.
or
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
click start all programs accessories scroll to system tools from there you should see a system restore click next a sytem date should open up select the date you want to restore your computer to or if you want a full factory restore or
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer) or
helps don't forget to vote
Feb 28, 2011 | HP 419320-001 - HP Pavilion dv4000 Series...
I need to reset my WD800UE Scorpio 80 gb hard drive. how do i do it?
Alternate:
From the Windows Start menu, click Run. In the Open field, type MSCONFIG and click Ok. On the BOOT.INI tab, check /SAFEBOOT. Click Restart when prompted. Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer) or During the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart click start all programs accessories scroll to system tools from there you should see a system restore click next a sytem date should open up select the date you want to restore your computer to or if you want a full factory restore or Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer) or During the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
Hope this helps don
Feb 27, 2011 | Computers & Internet
When i start the laptop, i want to go in to the setup. however when i press F2, it ask you to insert password.
Alternate:
Hope this helps don
Feb 26, 2011 | Computers & Internet
I tried to factory restore my laptop and a message saying it cant install windows to my computer...what does that mean and how do I fix it?
Alternate:
or
Hope this helps don
Feb 25, 2011 | Acer Computers & Internet
It has a blue screen doesnot do anything
Alternate:
or
Hope this helps don't forget to vote
Feb 23, 2011 | Computers & Internet
I need to restore my factory settings and reboot my samsung n150 notebook how do i do it please
Alternate:
or
How do i get back to factory setings keep geting
Alternate:
or
Feb 21, 2011 | Gateway Computers & Internet
My HP mini 2010 needs to do a system recovery or restore. But it says i will lose all add programs and files. The back up file option in the recovery manager does let me select it, as i tried to do it...
Alternate:
or
Feb 19, 2011 | Computers & Internet
SATELLITE U305-S7448. Vista is badly corrupted and I have no factory restore disk. How can I obtain a factory restore disk? Boot up restore option doesn't work. There appears to be no restore...
Alternate:
or
Feb 15, 2011 | Toshiba Computers & Internet
My daughter used my wife's laptop and somehow acquired this extremely persistent malware that tries to get you to buy some antivirus proxp software for $60... I bought the PC on Amazon and I don't have a...
Alternate:
or
Feb 14, 2011 | Computers & Internet
Microsoft Windows XP Home Edition Logo
130 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
