Question about Lexmark P450 InkJet Photo Printer
Lexmark P450 System worked great for 4 days. I go to use it and there is no power to the unit. No power/lights show on the system. Pressed Power Button: No Power Unpluged / Repluged power cord from wall: No Power Unpluged / Repluged cord behind unit: No Power Unpluged / Repluged Power adapter behind unit: No Power
5 Suggested Answers
  • 19 Answers
SOURCE: Computer cannot communicate with printer
either port or driver problem. you may have to make adjustments in BIOS under peripheral devices. default is auto, change to assign manually and assign a port for com 1, com 2, printer.
reboot
right click MY COMPUTER, PROPERTIES, HARDWARE, DEVICE MANAGER; scroll down to com 1 and com 2 ports (above printer port) make sure no yellow explanation marks which indicate a port conflict. NO PRINTER WILL PRINT.
go to mfr website and download driver for your printer
click MY COMPUTER, PROPERTIES, HARDWARE, DEVICE MGR;
scroll down to printer port; right click; PROPERTIES, click on change driver; browse over to where you download drivers; keep going down the tree until you get to DRIVERS (select the folder with your operating system) click on it to OPEN into dialogue box (in change driver wizard which is open) and hit enter; THE WIZARD WILL INSTALL THE CORRECT DRIVER FOR YOUR PRINTER.
HAPPY PRINTING.
Posted on Apr 26, 2009
  • 323 Answers
SOURCE: No power on my Lexmark X8350
That's the same printer I have.
First, make sure the blue "copy" button is lit. Printing is done there.
Then, go to the circle with the checkmark in it and hit the menu, and arrow down to copy papy size and make sure it says "letter".
Click start on your computer, then click control panel, then printers, and make sure Lexmark 8300 series is the default printer and has a green checkmark in a circle.
If all these things are right, you should be able to print a test page and the computer should work fine.
If any one of them are wrong they must be corrected. If you need help on any one of those please write back.
Sirwriter
Posted on May 14, 2009
techno_svcs
  • 11 Answers
SOURCE: Cartridge Error
you can contact Lexmark tech support direct, 1-800-539-6275
International Headquarters and
United States Headquarters
Lexmark International, Inc.
740 New Circle Road NW
Lexington, KY 40550
For Lexmark technical support call:
(800) 539-6275 Monday - Friday 9am - 9pm
Saturday Noon - 6pm
Posted on Sep 12, 2009
  • 15 Answers
SOURCE: Power button not working on Lexmark X2530 multifunction printer
OK, if you can work a volt meter it will help. We want to double check the output of your power supply (P/S) based on the specs written on it , or in the manual. If the P/S is known good, when the printer is turned on, do you hear anything? listen for the faintest fan. If you hear a fan, printer is getting power. if you hear nothing and see nothing, check for a fuse by the P/S plug in somewhere. If you don't see one outside, there is one on a board that needs replaced inside the printer. Check the fuses for continuity. Ill bet its as simple as a bad P/S, lexmark is cheap plastic ****, but still lasts longer than THAT!
Posted on Oct 14, 2009
Apc xs1500 beeps 4 times
Check if the unit has a breaker on the back and reset it. The unit doesn't seem to be getting power.
Dec 03, 2012 | APC 1500VA BX1500 8 Outlet UPS UPS System
Will not recognize jpegs on cd
Try to insert a different know working cd to determine it's not a disc problem. Try to unplug and re-plug the printer into the power source to reset it.
Jun 15, 2011 | Lexmark P450 InkJet Photo Printer
E system 1212 Laptop won't switch on. Power
Laptops are so integrated that usually a system failure that involves power issues such as in your case where you cant get it turn on with anything on the screen mean the mainboard (motherboard) is damaged. This usually leads to buying a new laptop or paying for the board to be replaced which usually costs as much as the laptop.
May 12, 2011 | Computers & Internet
I have just bought two of these units for my son's band and cannot get them to work in master slave mode with one footswitch. Any help would be appreciated. Please remember I am a total novice so an idiots...
DO NOT RUN THEM in parallel or the power will explode internal circuits.
Have you cleaned the imputs and outputs?
Does it show a power light?
Answer these Qs with As and I will help you
Feb 25, 2011 | Chauvet 4bar 4 Bar Wash Dj Led Lighting...
PS3 Console powers on, then off immediately
this is what's known as the yellow light of death. check with sony to see if your unit is still under warranty at this site: https://service1.us.playstation.com/rma.htm?_flowExecutionKey=_c42AAD4C5-D9D7-3A33-625E-9DA8C64771EB_k52930EA4-D8DC-F2F8-7A3D-01F2E5C1A8BA
if the unit is no longer under warranty, we'd be glad to fix this for you. all of our repairs come with a 90 day warranty that covers the whole console not just what we fix. we also offer extended warranties for up to 4 years at an additional cost.
you can contact us at: 214-222-5788 or support@wiredextreme.com
www.wiredextreme.com
Jan 06, 2010 | Sony Playstation 3 (PS3) Console
Error code 1203
it is catridge error kindly replace the catridges.
Nov 24, 2009 | Lexmark P450 InkJet Photo Printer
Cartridge Error
Lexington, KY 40550
Saturday Noon - 6pm
Sep 12, 2009 | Lexmark P450 InkJet Photo Printer
Power outage last night - alarm sounded. Turned off computer - pressed the button to silence alarm. Five hours later, battery sounded a different alarm every 20 minutes that could not be stopped. Gr-r-r-r!...
hi..OK 1st step open the unit and find the memory from the board remove the memory then make clean the all pin connectors using a paper eraser.if u have video card remove too then same make a clean..good luck and have a nice day...Thanks
Jun 14, 2009 | Tripp Lite Lite OmniSmart 700 PNP UPS...
Blinking Green Light on Mitsubishi DLP 52525
the dlp will most likely need a qualified mits repair center to take over for you. repairing that set is pretty involved. and the parts you would need are not available to the public.
on your 48" CRT projection check the DM module for 4 vented 1000mf 16v capacitors. replacement should get you tv working great
Feb 20, 2008 | Mitsubishi WS-48513 48" Rear Projection...
Lexmark P450 InkJet Photo Printer Logo
26 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
