Question about Car Audio & Video
Wiring I have to Kicker 12'' L5 DVC 2ohm subs and am trying to wire each sub to 2 Mono block amps, How do I do it?
    Problem Solver:
  • 6 Answers
You have 2 subs and 2 amps right?In that case make sure that the amps are capable of stable 1ohm load and also you'll need a lot of power and 4 gauge power cable for each amp with fuse of course.
Now....take one sub and connect the (-) with the (-) and the (+) with the (+).Now you have one (+) and one(-) to connect to the amp.Do the same with the other sub and you're ready to rock!!
Posted on Nov 14, 2008
I have 2 18" kicker
First you need the OHM rating of the subs. Most of the time its on the box or the magnet on the back of the subs (normaly 2ohm 4ohm or 8ohm) And that of the amp. Most amps are 4 ohm output if its a 2channel and 2ohm output if its a mono. You NEED to know these cuz wiring it wrong can blow channels in your amp or cause it to cut "in and out"
Jan 17, 2011 | Kicker Car Audio & Video
I want to know the best subwoofer wiring diagram for three kicker cvr 10 inch subs, 2 of them are dvc 4 ohm and 1 is dvc 2 ohm, the amp that i am using is jl audio 500.1 1.5-4ohms stable. can anyone help...
if the amp has a 2 outputs then i would wire the two 4ohms together, and the 2ohm by itself. and if its a 4 channel output then wire them all sepretly, if its a 1 channel output then wire the two 4ohms together and leave the 2ohm sub out
Nov 29, 2009 | Kicker CVR10 Car Subwoofer
How do i bridge 2-4ohm dvc's to a mono block
If you have a DVC 4ohm speaker, and you are using both voice coils, the amp is seeing a 2ohm load.
If you bridge the amp, you CAN run both subs as long as the amp is Two Ohms Stable.
Wire each subs voice coils in parallel.(Positive to positve, neg to neg.) (2ohms) each.
Then wire the two subs in series.(Neg from amp to neg of sub one, pos of sub one to neg of sub two. then pos of sub two to pos of amp.
If it sounds too hard, leave it as you are already running the amp at two ohms.
Sep 13, 2009 | Car Audio & Video
Wiring options
Hello chino2g,
For 3 DVC 4 ohm subs wired to a 2 ohm stable amp, your best option would be to wire all of the sub voice coils in series (individual 8 ohm loads) and then parallel the three subs for a final load of 2.67 ohms. There's really no other configuration. Here's the wiring diagram:
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp?submitted=true&woofer_qty=3&woofer_imp=4
Hope this helps.
Sep 07, 2009 | Hifonics HFi HFI12D4 Car Subwoofer
DONT KNOW HOW TO RUN 2 OHMS
Hello storres18,
If you have the Kicker model number 06CVX122, with dual 2ohm voice coils, they can be connected to a mono amp at 2ohms. First jumper the voice coils in series, the dotted positive (+) to the undotted negative (-) (or vice versa). Each sub is now 4ohms. Then wire both of the remaining positives and negatives together on the amp terminals (in parallel). The amp sees a 2ohm load. Here's the diagram:
If you have the Kicker model number 06CVX124 with dual 4ohm voice coils, they cannot be wired to present a 2ohm load. They can only be wired as a 1ohm load (too low for the amp) or as a 4ohm load (at reduced power). Here is the diagram of the 4ohm wiring:
Hope this helps.
May 10, 2009 | Visonik V900XD Car Audio Amplifier
How to wire up my kicker 12inch solobaric l5 2ohm to my zx500 2ohm mono amp. should it be ran in parallel or series? what is the best suggestion
Well first of all all solobarics are dual voice coil so you have 2 2ohm voice coils so if you wire them in parallel the sub will be pulling a 1ohm load wich would in time blow out your amp. So you want to wire both voice coils in series to produce a 4ohm load.
Oct 25, 2008 | Kicker Car Audio & Video
Wiring Diagram
i HAVE 2 12 KICKERS L7 RUNNING ON A PERFORMANCE TECHNIQUE AMP 2000 WATS THE ampl its a mono //and i want to know how to wire the speakers
Jul 26, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Best results
huge shared common space slot loaded box (size depends on sub 10", 12" 15" you need to clarify that please) the amp specs on earthquakes site say the phd5000 is rated at a max output of 5k watts at 1 ohm 3k watts at 2 ohm so, with 3 dvc 2 ohm subs you only have 3 options of which only 2 will be a usable solution:
1. 3- 2ohm dvc series at sub parralel at amp = about 1.33 ohms at the amplifier this is the best option to get the most power to the subs as each sub will produce a 4 ohm load then wire each one to the amp the amp sees 3 4 ohm parralel loads which = 1.33 ohm so based on the amp specs you would be close to 1200 watts per sub.
2. 3- 2ohm dvc wired in series at sub and all 3 subs series wired together very difficult to wireand will give you a 12 ohm load which is next to no power at all (not a viable solution)
3. 2- 2ohm dvc parralel wired to each other and then at amp the amp sees a 1 ohm load and makes 5k watts max but you can only (REREAD THAT LINE! ONLY USE 2 SUBS IN THIS WAY) WHICH GIVES THE MOST POWER BUT ONLY USES 2 SUBS
Jul 09, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
2 ohm dvc and monoblock sub amp
Yes. When you run two-two ohm subs to a monoblock amp its on the same channel meaning there ran parallel, and that makes it one ohm and most mono-blocks won't read one ohm. Are you popping fuses in the amp?
Apr 02, 2008 | Audio Players & Recorders
Car Audio & Video Logo
138 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
