Question about RIM BlackBerry Pearl 8100
Blackberry pearl wont go past the white screen with the hour glas
Well my brother gave me his blackberry pearl and i went to stick my sim card in it and when i did and turned it on it went to a white screen with a hour glass on it and it wont go past it and i hav tried takin da battery out and it still dont work and i let the battery stay out for two weeks and when i tried it again it still didnt go past the white screen so wut do i do now???????
  • 13 Answers
The only thing that you can do with this issue is try wiping the software clean and reinstalling fresh software. You would need the blackberry desktop manager first installed on your home computer. If you dont have the cd the program is more then likely available on your mobile providers website. Once the program is downloaded and installed follow these directions
To perform this procedure, follow the steps below:
  1. Remove the battery from the BlackBerry device.
  2. Double-click Application Loader in BlackBerry Desktop Manager while the BlackBerry device is not connected to the computer.
  3. Click Next on the Welcome to the Application Loader Wizard screen.
  4. When the Communication Port Selection screen appears, connect the BlackBerry device.
  5. When the USB-PIN option appears, click Next. The Device Application Selection screen should appear.
  6. Re-insert the battery and allow the process to complete.
Posted on Nov 19, 2008
Unlock blackbebrry pearl 8100
Hi, You can unlock a Blackberry Pearl 8100 safer and easier using unlock code. You can get the unlock code for a Blackberry Pearl 8100 from www.superunlockcodes.com/blackberry-pearl-8100/rs12wp9/ at affordable cost.
UNLOCKING STEPS FOR BLACKBERRY PEARL 8100
1 - Switch ON your Blackberry Pearl 8100 with your current network/service provider's SIM card,
2 - Go to Options Menu => Advanced Options,
3 - In the SIM Card menu, hold down the Shift (right of the zero, cap) press meppd, (NOTE: You may not see any text appear on the screen while typing meppd)
4 - You'll see the unlocking level screen there you hold the ALT key (left side below @) type mepp2, (NOTE: You may not see any text appear on the screen while typing mepp2)
5 - Enter the unlock code.
Oct 14, 2012 | RIM BlackBerry Pearl 8100
How to Unlock Blackberry Pearl 8120?
Instructions for unlocking Blackberry Pearl 8120
1. Ensure a SIM Card is inserted
2. Go to 'Manage Connections'
3. Click on 'Turn All Connections Off'
4. Go to 'Options'
5. Click on 'Advanced Options'
6. Click on 'SIM Card'
7. Type 'MEPPD' (letters will not appear on-screen but a menu will pop up.)
8. Type 'MEPP2' (*Note- for Telus, use MEPP4. You will be prompted to enter MEP code)
9. Enter the unlock code (CONFIRM you get "Code Accepted" message)
10. Reboot device
11. Go to 'Manage Connections'
12. Click on 'Restore Connections'
13. Device is now unlocked
http://unlockgenie.com/Unlock-Blackberry-Pearl%208120
Jan 28, 2011 | RIM OEM Blackberry Pearl 8120 8130 Flexi...
The phone says invalid sim card. This is the second blackberry pearl lip 8220. It is a piece of junk. Usually the screen goes white and then a little square clock appears in the middle of the screen....
Your Blackberry probably just needs a firmware restore. Here's a guide on how to restore the blackberry firmware, the website is at : Restore Blackberry to factory settings. Download the Blackberry Desktop manager and run the application loader. If it asks you for a password, you can enter it 10x wrong and that will wipe the blackberry as well.
Jul 07, 2010 | RIM BlackBerry Pearl Flip 8220 Cellular...
White screen with the hour glass wont go away
try to remove your sim card and the memory card out of your unit and try to open it again
If that work then have it run for 5 minutes then turn off again put your sim card not your memory card, then turn it On again
inform us what happen
Nov 05, 2009 | RIM BlackBerry Curve 8310 Smartphone
Wont turn on
www.crackberry.com will help, just search in the forums for "recover a dead blackberry"
Jul 30, 2009 | RIM BlackBerry Pearl 8100
Blackberry pearl wont except sim card
How To Enter the Unlock Codes on a BlackBerry Cell Phone
Model : All BlackBerry Models (except T-mobile)
1 - Using the menu go to Settings Menu -> SIM card press select.
2 - While holding the SHIFT key, type MEPD or (MEPPD for Vodafone Handsets)
3 - You should now see the five locking categories listed.
4 - While holding the SHIFT KEY, type MEP2 or (MEPP2 for Vodafone handsets)
5 - Release the shift key.
6 - You are now prompted to enter the Network MEP code (it will also state how many attempts left)
7 - Enter the code
8 - Enter Return/Enter
9 - The device should then be unlocked
Model : T-mobile BlackBerry Models
1 - On the Home screen, click the Tools icon. The Options screen appears.
2 - In the tools screen, select the Settings icon.
3 - Scroll to SIM Card and select it. You should see the phone number and the SIM ID number.
4 - Type ‘mepd’ to display the first five levels of SIM locking.
T-Mobile uses network locking so the Network should display Active. All other states should display Disabled
Please note: For the Blackberry 7100t you will hit the “P” twice when entering the ‘mepd’ and ‘mep2′ for steps 4 & 5.
5 - Type ‘mep2′ to display the dialog box asking for the unlock code (Press the Alt + 2 key to get the number 2)
6 - Input the Network Unlock code
7 - Press ENTER and reboot handheld.
Model : BlackBerry Pearl 8100 (Alternative instructions if above instructions do not work)
Can be done without a sim card inserted
To Unlock:
1 - While on the home screen, click the “blackberry key” on keyboard, then select “options”.
2 - Choose “Advanced Options”.
3 - Select “Sim Card”
4 - There is no area to type these letters, you just type them as instructed. No need to hit keys twice to get a letter either. Type m e p p d to display the first five levels of SIM locking. Most companies use network locking so the Network should display Active. All other states should display Disabled ( you will not see text appear on screen
while typing )
5 - Type m e p p 2 to display the dialog box asking for the unlock code
(Press the Alt + 2 key to get the number 2) ( you will not see text
appear on screen while typing )
6 - Input the SIM Unlock code
7 - Press in the trackball in once
Your phone is unlocked
May 05, 2009 | RIM BlackBerry Pearl 8100
Screen turned white
Remove the back cover, Remove the battery, if the phone is GSM take the little card out of the back of phone by sliding the metal cover in proper direction. Should be arrows. Put the Sim card back in battery back in then turn phone on. If this doesn't work let me know. Main thing is reseating the sim card. (this assuming you a service provider that requires a sim card. )
Jan 01, 2009 | RIM BlackBerry Pearl 8100
Free unlock of blackberry pearl 8100
I have a problem to unlook mi blackBerry 8100 My IMEI is: 359675.01.476906.7
and my currier is Orange Dominicana, I need the Unlook code please.
Thank, for all..
Aug 13, 2008 | RIM BlackBerry Pearl 8100
It's a clear and fully detailed guide on how to unlock a BlackBerry 8100:
1. Insert any sim card
2. Turn off all of the wireless connections
3. Go to Options
4. Select Advanced Options
5. Select SIM Card
6. Hit menu select show keyboard (if your BlackBerry have touchscreen)
7. Type MEPD ( you will not be able to see what you are typing )
8. Type MEP2 ( you will not be able to see what you are typing )
9. Now the phone will prompt you to enter network mep code
10. if you not already have the code, then i suggest BlackBerryMEP.COM to get it from .
11. Enter the code ( you should see "code accepted" )
12. Restart your BlackBerry .
All done.
SOURCE : BLACKBERRYMEP.COM
Aug 02, 2008 | RIM BlackBerry Pearl 8100
WHITE SCREEN
Using blackberry desktop manager, backup information on 8100 and restore software.
May 01, 2008 | RIM BlackBerry Pearl 8100
RIM BlackBerry  Pearl  8100 Logo
199 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
David
Martin Murray
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
