Question about Sony Playstation 3 (PS3) Console
No writing on power up
When i turn on my ps3 the sony entertainment thing comes up then after that all you see is the backround no writing or anything so yo cant do anything ethier HELP
  • Anonymous Nov 14, 2008
    My playstation 3 turns on but the only thing that it shows is my background and restarting doesnt help
  • Anonymous Nov 15, 2008
    have the same problem and as no writing comes up cannot update... help
  • 67 Answers
Update to firmware 2.5 if you can , if your already on v2.5 firmware go to the recover menu and select restore ps3 system (search youtube ) or you can remove the hdd and put it in a 2.5" powered hdd enclosure and try to format by your pc or just take out your ps3 hard drive and then turn it on.
Posted on Nov 14, 2008
  • Tech_PC Nov 14, 2008
    ps: to remove hard drive is in the ps3 manual both ones (online &ps3 manual you get with ps3) , by formatting you loose your saved data ,videos,demos and music , you might want to get a better 2.5" hard drive at your choice
Won't boot up
it maybe a hardware failure, or it can be anything really... you might try to reset configuration by holding the power button for more than 4 seconds... it will reset your display settings and so on...
you blueray maybe stuck aswell , hold it for 10 seconds it will force a "disc out"
the last you can do is , that is ofcourse you dont have a warranty , open it up (see youtube video"ps3 bluereay disassembe" how to open it)
Jul 25, 2009 | Sony Playstation 3 (PS3) Console
My ps3 doesnt do anything!!
sounds like the motherboard may have gone out which is extremely common in the ps3
Jul 07, 2009 | Sony Playstation 3 (PS3) Console
All i get is a backround no words, no connection for controllers
are you connected with the HDMI cable? DId you switch TVs recently?
You might have the resolution under settings set wrong. so the screen is really tiny. If your remote for the tv has a zoom option, zoom up until you can see the settings to change the output
Jun 25, 2009 | Sony Playstation 3 (PS3) Console
Ps3 Not Working
Try a hard reset as follows
1. Power Off the PS3 via the power switch in back and power back on w/switch.
2. Hold Power Button on the Front until you hear 3 beeps.
3. Then go through the initial setup and then run a full Format via System > Format
Apr 08, 2009 | Sony Playstation 3 (PS3) Console
Power up trouble
Okay i will need you to turn off you system off from the main power located on the back. Then you will need to turn it back on after that you will need to hold the touch senstive turn on located on the front of the ps3 hold it. You will hear a beep that just tells you that it is turning on. Still be holding the turn on button untill you hear another beap after that you can let go. This will reset you picture setting and will not delete anything on your hard disk. If this dosent work call sony at 1 800 345 7669
Mar 19, 2009 | Sony Playstation 3 (PS3) Console
When i turn on my ps3 it does nothing else but go to the backroud
More than likely your hard drive was corrupted. The easiest way to fix it is to format the hard drive. There are LOTs of different ways to do this but the easiest way is to just hook the hard drive to a computer via a usb cable and then formating it through disc manager.
Here's a quick guide:
http://support.microsoft.com/kb/309000
It doesn't matter what file system your choose, just format it, and then pop it back into the PS3. It will recognise the hard drive as a new drive and then will reformat it again so that the PS3 can read it.
That's it! Problem solved.
The drives are SATA so if you don't have a usb cable you could always throw the drive into a laptop as long as it takes a SATA drive and use an XP or Vista CD and follow the same generall game plan: format the drive
OR you could swap the drive into someone else's PS3, it will do the same exact thing. It will recognize it as a new drive and will format it, then just pop it back into your old PS3 and boom. SUCCESS!!!
That's probably the easiest way now that I think about it.
Feb 19, 2009 | Sony Playstation 3 (PS3) Console
My ps3 won't show anything
hold the reset button to restore your settings do this various times untill you get a screen that has many options read the options and pick the option that says rebuild the hard disk drive. once it gets to 100% sat your settings. then your ps3 shouold be back to normal. the bad thing is that you will lose everything you saved on the ps3 =[
Dec 25, 2008 | Sony Playstation 3 (PS3) Console
Playstation freezign at main screen
The "NO VIDEO/PIXELATED VIDEO/FROZEN VIDEO" problem is all too common on the PS3. It results from overheating of the RSX and/or CELL processor. let it cool and resume and pray
Nov 12, 2008 | Sony Playstation 3 (PS3) Console
Wheres my main menu
Mine did the exact same thing here is how i fixed it. Access recovery menu.
1. turn off ps3
2. hold the power button down; the system will turn on and turn off once again.
3. once the system has been shut down, re-press your finger until you hear 2 conscutive beeps (2 quick beeps)
4. when you hear the 2 beeps take your finger off the power button
5. you will be prompted to plug in your controller via usb and then hit the ps button
6. the recovery menu will pop up
Now i tried the Restart System and it didnt do anything. I was not sure which one to select, so I then clicked Restore PS3 System. I lost everything, but I got it working again!!
Nov 01, 2008 | Sony Playstation 3 (PS3) Console
Ps3 wont work
see if you unit overheating
Aug 28, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
