Question about LaCie Big Disk (300872) 400 GB Hard Drive
Hard drive won't turn on
I've got a big disk that just stopped working suddenly. the green light on the power supply blinks green and the blue light won't come on when pressed. i've tried a different power supply and also tried connecting it to a different computer. it's out of warranty and la cie says it sounds like a bad internal power board. any suggestions where i can get it fixed or if i can fix it myself by moving the drive to another housing?
    Problem Solver:
  • 12 Answers
You could remove the drive if you can get the enclosure open and either install it in a new enclosure or as an additional HD inside your Pc. Good Luck.
Posted on Apr 24, 2007
Drive stopped responding -- problem with power supply or drive?
click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
if this fails to fix the problem
check usb leads for secure dust free seating
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
hope this helps
Jul 05, 2012 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Green light blinks three times but T.V won't power on
Power supply probably fried. You will have to take the TV apart to test.
Jun 23, 2012 | Televison & Video
Describe your WD-62725 62 in. Rear Projection HDTV-Ready Television Problem Green light is blinking the TV won't turn on. We've unplugged it and tried to push the reset button and the green light...
If the led light flashes green continuously, the fault came from the DM power supply. The faulty parts there are the electrolytic capacitors. Let me know if your handy with electronics and I will assist you to fix it yourself.
Jdvillanueva
Sep 16, 2011 | Mitsubishi WD-62725 62" Rear Projection...
Tv turns on for a few seconds then shuts off and the blue power light blinks.
Mine never turned on but the blue power light would blink.I disconnected the upper y buffer and got light on the bottom half of screen and the blinking stopped.I have the upper board on order and I think this will fix my problem.There is a blink code somewhere,just count how many blinks.Start pulling connectors from power supply and when it quits blinking you've found the one,could also be the power supply with bad cap.
Jul 14, 2011 | Hitachi Ultravision P50S601 50 in. Plasma...
Suddenly my hp pavilion a1217n tower won't turn on...the green light is blinking rapidly...
are you referring to the light on the back? if so the power supply has most likely failed, mother board can also cause this issue.
Jul 08, 2011 | HP Pavilion a1217n Desktop PC
Television suddenly turns off.
Try to get a firmware update. THis happened to me and I got a firmware update from Mitsubishi and now all ok. Call Mitsubishi
Nov 12, 2008 | Mitsubishi WD-52725 52". Rear Projection...
No Picture - Lamp Indicator Blinking
This may be the main power supply, or the lamp supply. This is providing that the new lamp is okay.
The service tech will swap out the modules to service the set.
Jerry G.
May 15, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
LaCie 250GB: Power (blue) light flickers when pushed, nothing happens
Sound very much like ypur disk is fried. Slim to zero chance of recovery.
Aug 26, 2017 | LaCie Big Disk (LAC300966U) 1024 GB Hard...
System will not power up
Here is a Compaq document will walk you thorough a fairly lengthy procedure that should solve your problem. Here is the link: http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph06788&lc=en&cc=us&dlc=en&product=431080&query=presario%20sr1220&dest_page=product#N561 Let us know how this turns out or if you need any additional assistance.
Jan 02, 2007 | HP Compaq Presario SR1220NX (PJ517AAR) PC...
LaCie Big Disk (300872) 400 GB Hard Drive Logo
251 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Marvin
Marvin
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
