Question about Sangean ATS 818 AM/FM/SW Radio
Power Button Snafu
The 818 has been the most faithful (and receptive) SW I have had so far, but of late, I cannot power up. When pressing the red power button, I always get a FLASHING "E" on the screen. At first this was only with the AC cord attached. When I disconnected that, and used fresh batteries, it would power up for awhile, but then, I had the same problem, AC or DC, and now I have a useless 818. Is this from a faulty power switch? Or possibly something else? Thanks! Dan
It would now make a good boat anchor!!!
Posted on Aug 29, 2007
I think the E means a dead battery. You could have intermittent solder connection on your DC input jack. This could effect battery operation as well. Check for bad connections and resolder also look for broken traces at these connections. Good luck.
Posted on Dec 01, 2006
Sangean DAB radio DPR99 Plus power switch problem
If you think it it the contact bouncing, fit a 1nF capacitor across it to stop the bounce effect.
Sep 17, 2017 | Sangean ATS 818 AM/FM/SW Radio
How to solve my 818 mobile phone will not switch on although direct with cable charged
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Oct 14, 2012 | Dopod 818 Pro Smartphone
My dopod 818 pro gets hanged on start up at htc innovation logo....please help
do a hard reset, beware all data will be lost and you need to calibrate screen again.
press two soft keys above call and end button press power button and insert stylus in reset hole,
phone will display some thing press green send button to restore or format.
you are done
Dec 22, 2010 | Dopod 818 Pro Smartphone
Canon MX320 Printer getting code error 5200 Please Help !!!
Please reset the printer
1. Turn off your printer
2. Press and hold the STOP/RESET button
3. Press and hold Power ON button
4. While holding the Power ON button, release the STOP/RESET button
5. While holding still the Power ON button, press twice the STOP/RESET button
6. Release the Power ON button
7. Wait until it display an "idle" message. It will take about a minute.
8. When "idle" appear, open the top cover to expose the cartridges.
9. Lift up the cover for cartridge holder and take out both the black and color cartridges
10. Return the cover of cartridge holder and turn off the printer
11. Return the top cover and turn on the printer again
12. After the printer initialize, return the cartridges.
1. Press and Hold the STOP/RESET button and wait until it self restart.
2. Release the STOP/RESET button the the printer is restarting.
3. Wait for a few seconds
Oct 07, 2010 | Canon PIXMA MX320 Color USB InkJet Printer
We have a Grundig S350DL radio that was my father's. There is no manual. FM works great. Can't get AM. Radio turns off on its own!! Any suggestions?
The problem you are having may be due to some configuration settings (such as a timer). Not dtecting the AM signal, may be due to interference from power lines. To improve AM reception (if there is something to improve) one should rotate the radio to orient the internal ferrite antenna. Using the radio close to a window can improve reception.
To enable you to diagnose the problems that may be due to some configuration setting I give you the link to the radio's manual.
Hope it helps.
Nov 08, 2009 | Grundig S350 AM/FM/SW Radio
WX cc Sangean radio cuts out
The ATS-818 needs a transformer. The transformer converts AC power to the DC used by the radio, so no. You need the transformer.
Jan 20, 2008 | Sangean ATS 818 AM/FM/SW Radio
ATS 818 Inoperative
Unplug AC adapter from radio. Remove ALL batteries. Wait 15 min. Reinstall batteries
Jan 17, 2008 | Sangean ATS 818 AM/FM/SW Radio
UNCOMPLETED MDA UPDATE
this is a sw boot up screen. this is what the screen will look like with no sw on the device, so you guessed it....the download was unsuccessful and corrupted the firmware.....if you tried to reinstall the sw again, and it does not work, you might need a new phone....contact t-mobile to do that.....OR, you can try to do a master reset by pressing the sw keys.
to do that, turn off the phone, and press and hold the soft keys (buttons located beneath the touch screen that have the lines on them on top of the green call button and the red end call button).....while holding these down, press the power button for 3 seconds and release the power button.....all this time you are holding those soft keys down....the phone SHOULD turn on and go to a black screen with white writing.....at this time you can relase the two buttons......press the green button and reset. if this does not work.....my friend, you need another one......good luck!
Dec 16, 2007 | T-Mobile MDA
Error message
OK guys quite a simple one....
with the printer on press & hold both the small red button ( far right ) and the green, colour copy button. Whilst still holding press the power button wait till the unit powers off. Press the power button again, shortly after the unit powers on, the lights flash, let go of the two buttons your holding. The screen shoul dnow say "Init EEPROM" if it doesn't repeat procedure till it does. Now press the green colour copy button once, screen should now say "Push power sw" Press and hold the power button, the unit will power off and on again, now release the power button and your printer should be working again. Now you should change your waste pads......
Dec 05, 2007 | Epson Stylus CX6600 All-In-One InkJet...
Sangean ATS 818 AM/FM/SW Radio Logo
197 people viewed this question
Top Sangean Audio Players & Recorders Experts
Pete Vernall
Level 1 Expert
Gyula Lacz
Are you a Sangean Audio Player and Recorder Expert? Answer questions, earn points and help others
