HP Pavillion dv6500 Notebook. Power light coming on when connected up to charger but no charge going in.
  • 2 more comments
  • stevefeher Nov 14, 2008
    fogot to mention pc doesn't work when connected up to charger. no power going through at all but power light going on and battery has no charge left.
    This is additional to info posted yesterday.
  • Peter Feb 21, 2009
    power is reconized but want charge battery
    if i remove battery no power at all will not start laptop
    when battery is in in powers on but dont charge even charger is reconized to be plugged in
    have somebody an idea what that could be
    i called HP they said they dont know the Problem
    thank
    Peter
  • Anonymous Feb 26, 2009
    Hi i have the exact same problem did you ever find out a solution?if you did i would be grateful if you would pass it on to me?guestjobe@hotmail.com
  • Anonymous Mar 16, 2009
    I am having the same problem and can't understand. Called HP. They wanted 49.99 just to give me Technical Support. i told the lady that I wasn't interested as I had already been to many websites including this one, no one had a solution other than sending to HP. So, I asked her where I needed to take it to get it fixed, she then informed me that if I sent it to HP it would cost 298.00 just for them to look at it, since the one year warranty expired less than 3 months ago. At that point I told her that for $300 dollars + whatever repair costs would be (remember the 300 was just to look at it) it wouldn't be worth it because I could buy a brand new one for that. This sweet little lady then told me she would switch me to Purchase Dept. This was when I lost it and with many expletives explained that I would never under any circumstances buy another HP anything ever. I then hung up on the clueless idiot and am resigned to either A) buy a bunch of parts (power supply/motherboard) probably a waste of money or buy a new laptop. No wonder the extended warranties for these things are $400+. They must expect them to break immediately after the original runs out. This is ridiculous. Congrats HP you've lost several thousand customers over a default that is a known issue with HP and you'd sell a lemon product with no honor. Oh and the supposed BIOS update that is what supposedly causes this issue is not true. I just ran BIOS update within the last two weeks after I had to do a reinstall of Windows and my BIOS was the most current version.
I just fixed my friends dv6500
it had same probs as mentioned above
the probs i found : shorted schottky diode marked LG = smd10k45
                           shorted n-ch mosfet      marked 702 = 2N7002
                           defect smd cap
All these are placed just below the battery connector on mobo
see page 128 of service manual
replaced these smd's and laptop worked again
the damage was caused by overheating of the smd's
could be you have the replace other smd's surrounding these mentioned above
depends on how hot it was
hope this helps
Greetz
RzAn8
Posted on Mar 31, 2009
I have the same problem
but this i don´t understand " defect smd cap"
can u give more details ?
thanks
Posted on Apr 28, 2010
  • patalhetas Apr 28, 2010
    or wher I buy this ?
    thanks
    Scholar:
  • 62 Answers
If the PC works while the AC power is attached but the battery does not seem to be holding a charge, the battery is probably bad. Unfortunately they do go bad after a while. Before spending any money, make sure the contacts on the battery are clean and there is no physical damage/misalignment that is preventing proper contact from being made between the battery, PC and charging hardware.
Posted on Nov 13, 2008
Plugged in, not charging hp pavillion dv-7
power lights.. is that coming on the charger??? if so
remove the battery and put it back
then try... if not working\\contact HP
Mar 16, 2011 | HP Pavilion dv7-1468nr Notebook
The charging indicator light no longer comes on when the laptop is plugged in. Just replaced the battery. Also tried a different power cord.
Possibly a failed or damaged charging port (does it feel loose)? After that, charger may not be chucking out the voltage (19.5 volts)? Test with multimeter set to DV volts, with one probe on the inside of the plug ant the other on the outside.
Does the charger LED light blink when connected (sign that power is not making a circuit)
If the above fail to work, then the problem is with the connector on the mobo, this may just be a Charger port needing replacing (wired or soldered version), or the charging circuit of the motherboard gone
Feb 10, 2011 | HP Pavillion DV6227 Notebook
My hp pavillion dv1000 wont turn on it is plugged in but the charging light doesnt show up and when i push the power button nothing happens
Problem with your charger, try this :
1. Check whether the charger plug is properly inserted in the Power port/jack of your Laptop!
2. Check the power cord (any cuts OR torn-out)!
3. If above steps don't work, replace your charger.
Jan 02, 2010 | HP Pavilion dv1000 Notebook
Hp pavillion dv6000 no charge or power
I would say you have destroyed the battery charger. You can get someone with a digital mulitmeter to easily check if its charging or not.
Dec 03, 2009 | HP Pavilion dv6000z Notebook
No power from cord to computer
Hi...
If your laptop is under warranty go back to the manufacturer. If not go to hp center and buy a power cord of your charger which is totally fix to the charging hole.
Good luck
Regards
PCmania
Sep 25, 2009 | HP Pavilion dv9000z Notebook
Philips X50 charging problems
1st remove Battery after few min insert battery and connect charger Then power on laptop.If not on check Power Mosfet or Power ic.
Jun 27, 2009 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
Failure to start
Will the laptop start if the battery is removed and just the charger plugged in? I would remove the battery and charger for a few minutes and try it with just the charger plugged in. Unfortunately it sounds like a hardware fault. Let me know how that goes. The other thing to try is removing the ram and then putting it back in. this will solve alot of problems like this.
Jun 16, 2009 | HP Pavilion DV6500T Notebook
Pavillion wont work with battery
First, I recommend you to try removing and reinserting the Battery when the Notebook is turned on and powered with the Power Adapter.
I recomend you to first clean the Battery Connectors by removing the Battery and use a Earbud to clean the Metal Connectors which connect to the Battery to remove any dust which is peventing from the Battery to supply the required power to the Notebook.
You can find some related topics related to troubleshooting issues related to Batteries in HP Notebooks from the links below :
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&docname=c00485351&dlc=en&lc=en&jumpid=reg_R1002_USEN
Additionally, you can download and install HP Battery Health Check SP3229.exe and check the status of the Battery by following the instructions.
Hope this helps...
Aug 27, 2008 | HP Pavilion dv4000 Notebook
HP Pavillion dv6500 won't charge
Compare voltage and current (amps) from the original to the new. If the new one is different (voltage is lower, or current substantially lower), then it might not be an adequate replacement. If these are near identical, and you have the correct sized tip, there shouldn't be a problem with the new unit. Obviously, you could get an exact replacement supply $$. Also check online for replacements.
Jul 05, 2008 | Computers & Internet
Hp dv6500 Notebook
u can go hp support site select download then product (hp pavillion dv 65000)choose your o/s i.e win xp and download the audio driver or go to this link http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=3380543&lang=en&cc=us&prodTypeId=321957&prodSeriesId=3369402&taskId=135 select win xp then go to audio driver and download
May 17, 2008 | Computers & Internet
Computers & Internet Logo
1,066 people viewed this question
David Payne
David Payne
