Question about Brother IntelliFAX 560 Plain Paper Fax
Fax replacement parts
I accidently threw my phone away that goes to my brother's fax machine. How can I get that replacement part?
  • Brother Master
  • 5,568 Answers
The jacks generally used for handsets on fax machines are a smaller (fewer contact positions) version of the one that are used for the wall-mounted outlets.
Unless the Brother handset jack looks totally different than the one in which the fax machine is currently plugged at the wall, then the handset jack should look pretty much the same but smaller.
A friend or relative may have a retired corded phone that they haven't tossed out yet so check with them before poking around to look for a replacement as described below.
If you are in the US, check the dollar stores and chain drugstores for corded telephones. Coming from China, they shouldn't cost more than $10 US and may have the exact same connector attaching the handset to the base of the phone. Check them if possible before hitting the cash-register since it is becoming more common to have the handsets on these cheap phones permanently wired to the base which, of course, makes them useless for your needs. Most stores though will let you return the item for a refund.
Checking a couple of stores, you may even find it possible to match the color of the fax machine with your substitute handset.
Posted on Nov 13, 2008
Faxes won''t go threw. Poor Line Condition
There is nothing the fax can do about poor telephone lines...You need to call your phone service provider
Nov 01, 2009 | Brother IntelliFax-2820 Laser Fax
I need to replace the ADF Document Support piece on my Brother MFC-8220 fax machine. Do you know where I can purchase one?
I finally located a phone numbe for the Brother-USA Sales Dept. (888-615-9119). The part was $4 plus shipping and handling ($10 total). It took a bit of doing for them to identify the part and determine the part number. I had to fax them a machine parts diagram from the MFC-8220 manual. Go figure.
Oct 01, 2009 | Brother MFC-8220 Fax
Fax machine doesn't work
You can get the manual here: http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_240C_EN_249.PDF
Mar 13, 2009 | Brother Multi-Function Center MFC-240C...
Phone line goes to fax, then ans mach...now caller ID won't work.
Set the reception mode to Fax with answer machine TAD. Make sure its set for fax with answer machine.
May 29, 2008 | Brother IntelliFax-2820 Laser Fax
Brother Intellifax 1270E plain paper fax
It could be either. take the machine to anothewr line see if the
error goes away.If it does not call brother customer service. There is an adjustment for input sensitivity of so brother fax machines. It may be in your operators manual
May 27, 2008 | Brother IntelliFAX 1270E Plain Paper Fax
Cannot get printed faxes
the phone line needs filtering off ,because your fax machine is an analoque device
Mar 26, 2008 | Brother MFC-7820N Laser Printer
Brother fax 930 machine
I would try sending to another source. If the document goes threw the machine and you get a confirmation report saying it was sent, then it was sent. The person on the other end may be having trouble with their machine as well.
Aug 03, 2007 | Panasonic KX-FP85 Plain Paper Thermal...
Brother mfc-8300 phone connection problem
Make sure the line from the wall is plugged into the port marked"line" and not "phone" If this does not solve it then it sounds like there is a loose solder joint on the connector inside the machine.
Jun 19, 2007 | Brother IntelliFax-2820 Laser Fax
Brother IntelliFAX 560 Plain Paper Fax Logo
125 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
