Question about Mk Diamond 154861 MK-100 7'' x .060'' x 5/8'' Diamond Blade
Tile over a cracked cement floor
I know cracks in a basement cement floor can and probably will work up into tile applied over them. Can I use sheets of cement board and not attach them to the old floor, like a floating floor? Bond the edges together then set tile on top. This would allow the cracks to widen in the old slab and not affect the finished tile floor, possibly?
  • 22 Answers
You can get a crack membrane to put over the cracks. First use a primer on the floor, this is a primer just for this application, then put membrane on top of primer. these products can be found at home depot or lowes or any tile store.Also do not use cheep thinset. the better thinset is more flexible and will absorb any movement. The cement board would not work as they will move or flex and cause the grout to crack and tile to loosen
tom
Posted on Dec 13, 2008
  • Lauren Serpa Feb 06, 2016
    The membrane can be costly if your floor has several cracks. Another way to solve your problem is to use mastic and contractors paper. !. make sure you cut the paper to twice the width of the tile size that you will new laying. 2. Spread a thin coat of mastic over crack and make sure it is the width of your paper. Spread the crack from one end to the other. 3. Lay your paper down over the crack and use a flat towel to flatten paper over mastic and crack. this will insure that you get a good bond with no bubbles. 4. allow to dry before installing the tile over the area.
How do I fix a hairline crack in a cracked ceramic floor tile?
you cannot, only way is to replace crack tile. any "hairline restorer" "hairline paint" are simple cons and do not work! crack meant that these two bits move differently and need to be replaced with single unit, matter will go only worse.
Oct 18, 2013 | Daltile Ceramic Floor Tile: : Salerno 12...
"How do I fix a tile shower floor that has cracks on edges"
If you are interested to find the information about this topic you must have a look at this website you will find all the answers of your question here.
Rubber Tiles
Sep 27, 2013 | BITS Rotozip Floor Tile Cutting Xbit Xbft1
Where does the rubber membrane go when tiling a bathroom floor
tiles on wooden floors will always move and crack the grout/tiling cement
therefore the rubber membrane goes down first with out nails and then everything is laid on top
that way when the wooden floor moves , there is a water proof membrane to prevent the water from rotting the wood over time
Jun 14, 2017 | Home
How do I fix a cracked ceramic tile
I would try breaking the tile up with hammer instead of prying from side, as you maybe chip or crack adjoining tiles. This method should work fine, you may loosen surrounding tiles but just re-mortar any tiles that may become loose. Wear eye protection. Good luck
May 19, 2012 | Home
Hi I moved in to a recently renovated home one year ago. The kitchen had new ceramic tiles installed, with sanded grouted filled in the 5/8 inch joints. I sealed the grout after moving in as I was told...
I have a similar problem. My builder used dimensional lumber for the joists. I asked him if thet would be sufficiently stiff for tile floors, and he said yes. Then after the cracks started, I asked him why the cracks, but he said he didn't know why. It's not necessarily the subfloor but the combination of joists, subfloor, and concrete backer boards under the tile. If you can access the joists under the floor, perhaps you can reinforce them with additional joists or stiffeners before regrouting.
As for me, I have done neither so far. Wife has not complained, so I spend my spare time helping people on FixYa. Like you, I fear regrouting will just lead to recracking, and I no longer have access to the joists. :o(
By the way, your question was sorted as a Harley Davidson question. You weren't riding you bike in the kitchen, were you?
Sep 10, 2010 | 2003 Harley Davidson XL 883 R Sportster
I have crack in my shower floor concrete, would like to fix it before laying tiles and hope it won't be visible after i am done with tiles. I had tiles before wich I am removing now and will instal new...
There is a tile backer, kinda of like fiberglass mesh, I have also seen a waffle looking plastic, that will go down over the crack in the floor and will not effect the tile one bit. You just tile over everything, no mastic, no set under this stuff, no fasteners, just tile over it like a normal floor, and the best part is, no crack! Hope this helps.
Jun 29, 2010 | Plumbing
Wrong floor tile adhesive used. Contractor used timber floor adhesive instead of concrete. Some tiles cracking and adhesive not drying?
it depends on what kind of tiles they were. If they were soft tile, then they may crack anyway if the floor is not level, also if he made the floor uneven by using the adhesive they can crack. Many soft tiles are peel and stick and no adhesive is needed. If they were hard stone tiles then he should have been using grout to stick them down and grout the cracks in between as well. It sounds like you need to have someone else come in and re-access the problem as I can't see the whole situation, but it sounds like the tiles may need to come back up. You can either get the same guy to come back and fix his mistake or get some one else to fix it then go after him to messing it up. If you want to choose another person I recommend looking at www.superpages.com.
May 26, 2010 | Saws
Walk-in shower floor problem
They probably use wrong adhesive that is not hard yet and have tenedency under pressure to squeze out between grout lines. Yes they need to address the problem immediately.
Jan 14, 2010 | Home
Leaking basement foundation
It sounds like the ground has settled around the area where the leak is, hence the traveling water. The right way to fix the problem would be to remove the porch, dig up around the basement wall, apply a sealant to the outside of the wall, install weeping tile and re-grade the soil to drain away from the house. Your best bet to begin with may be to try to re-grade the soil so it is sloping away from the house, however this is only a temporary patch, if temperatures get below freezing there is a possibility that moisture in any crack in the wall could cause further cracking and leaks.
May 25, 2009 | Hand Tools
Mk Diamond 154861 MK-100 7'' x .060'' x 5/8'' Diamond Blade Logo
978 people viewed this question
Top Mk Diamond Saws Experts
JonSnell Electronic
JonSnell Electronic
Regalo Tiles
Are you a Mk Diamond Saw Expert? Answer questions, earn points and help others
