GE Cordless Phone
Problem for GE Cordless Phone
Display on handset does not display any info!
By sylviajinky on Nov 13, 2008
I have a GE Model 28128 Series 6.0 Cell Fusion telephone.
One of the handsets, #2 does not display any number's or any info on the display panel, but will allow you to make calls. However, since the number cannot be seen, or any info should we receive a call, can create problems. What could be wrong with the display on the handset?
Solution #1
posted on Nov 13, 2008
Somewhat Helpful)
martinmarty
Rank: Master
Rating: 93%, 11 votes
The display could be bad or the didplay driver could be bad or it could be a simple wiring problem if you're lucky. Try pressing around the edges of the display to see if anything appears (press firmly but not so hard as to break anything). If you are mechanically inclined, open up the handset and connect the battery so the handset works. Normally the display is connected to the phone circuit board by a ribbon cable and frequently there is a tiny "edge card connector". If present, make sure the connector is plugged in completely. Watching the display, try pressing on the ribbon cable where it attaches to the display and to the circuit board. If anything appears, keep trying to isolate the problem.
I recently had this same problem with a Sony handset but I was not able to find anything as I just described and I ended up replacing the handset with a new one of the same model. Good places to look for a replacement are eBay and Amazon.
Was this helpful?
Yes
No
Popular Solutions for GE Cordless Phone
Questions and Unsolved Problems for GE Cordless Phone
Do you recommend GE Cordless Phone?
Answer
Answer
need to download free manual
Answer
Both my handsets say Line in Use even though nobody is on the phone, no fax is coming through and no... (More)
Answer
power went out , now phone flashes CL, need to reset date and time , but lost manual
Answer
CL flashing after loss of power. How do I reset clock
Answer
won't dial our no dial tone. model # 27930ge3-p 2.4 ghz able to put phone # in memory but will not... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Phone Experts
Top Telephone Repairmen
in , OH
(800) 513-9962
Component level repair and complete refurbishing...
BARCLAYENTERPRISESINC
(316) 262-7171
Cctv,Cable Tv Wiring & Outlets,Computer Wiring...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
