HP 1022 Laserjet Feed Problem?
Brand new out of the box. Loaded driver, plugged it in and everything worked fine. Later on, I tried to print a web page and got the spooler error. Uninstalled the driver and printer and reloaded software.
Now when I try to print, the printer starts to run, but the shaft that the paper pickup thing, (The rubber cam shaped like a D), doesn't turn at all.
I took the toner cartridge out, and manually moved the cam, just a little and it clicked. Put it all back together, hit print, and the paper tray lifted, the cam grabbed the paper and it made it about 3/4 of the way out of the printer and just stopped.
Anyone want to take a crack at figuring the fix for this. I would certainly appreciate the help.
  • shadowghst7 Nov 14, 2008
    Printer did what you said it would, but when I tried to print, the printer started to run but the paper tray never lifted up anfd the paper feeder bar never turned. I can see that the rollers where the paper come out are turning, but that's all I see. Thanks
    Scholar:
  • 121 Answers
Try to cold reset you printer
Power off the printer.
* Power on the printer while pressing both the Go and Cancel buttons.
* Keep the buttons pressed. The lights will begin to flash in sequence.
* Release the buttons when all three lights begin to flash in union.
Printer is now reset
Try to send a test print now
Keep me posted!
Cheers!
Posted on Nov 13, 2008
  • Asish Sharma
    Asish Sharma Nov 14, 2008
    You have mentioned that
    "plugged it in and everything worked fine"
    So that means initially u could print???verify!!!!
    Check your printer properties..and view preferences.....
    is it set to correct paper size.....
    Verify that its not set to manual feed
    Turn off spooler service.... set to print directly to printer
    When you put paper adjust the side clip of the tray to your paper size
    please do the following
    keep posting
Usb light link
HP LaserJet 1022 is a "host-based" printer so it must be connected to a PC. Load the driver on PC first and connect the USB cable when software tells you to do so.
Will not work on a Linksys print server.
LaserJet 1022N & LaserJet 1022NW have "special" HP print servers that can support HP host based printers.
Nov 27, 2013 | Linksys Wireless-G WPS54GU2 Print Server
HP laser Jet 1022 only prints one page at a time
Jan 2013 Installed this new printer driver and all my HP 1022 problems disappeared; now printing perfectly back as usual!
HP Printer Drivers v.2.13 for OS X
Click on the link above or copy and paste the following address into your Web browser to view the article:<http://support.apple.com/kb/DL907?viewlocale=en_US>
Mar 05, 2012 | HP LaserJet 1022 Printer
My HP LaserJet 1022 is not responding even after I click print. It happens just now. Yesterday morning was fine. Keeps the document in pending and when I try to cancel or click print it says the print...
This seems to be a problem on these printers. I have five of them on my network and I had to use a generic driver to make them stop shutting off the print spooler on my print server. I use the LaserJet III driver which is a good HP generic driver. I found it to be best to uninstall all of the 1022 software and install the printer using the above driver that is part of the windows operation system therefore there is no need to download one.
Apr 10, 2010 | HP LaserJet 1022 Printer
I loaded Win 7. I need my printer to work badly. I have to print checks. I have a Laserjet 1022 Is there a driver or bata driver I can use.
Go to the HP website (www.hp.com) > click download drivers and firmware or support > type in HP laserjet 1022 > click the search arrows > click on you printer model > choose the operating system. If Windows 7 drivers aren't available yet the Windows Vista drivers should work just as well for the time being.
Oct 26, 2009 | HP LaserJet 1022 Printer
HP LJ 1005 installation end with driver conflict
That's wrong, The HPLJ1005 doesn't support windows vista.
Altough, the link cene765 is pointing to is for the HPLJ1005P which has vista drivers though these are two completely different printers. Searching the web for custom drivers now, will post solution if finding any.
HP LaserJet 1022 Printing Blank Pages
Aug 08, 2008 | HP LaserJet 1022 Printer
Printing problems - i can only print manual feed...
the manual tray is the is the one above the tray,
1-either your tray is set incorrectly must be set to Letter/Plain
priority is tray 2 not tray 1
tray one is the by-pass / manual
since this printer does not have a screen on it everything is setup through the PC.
print a configuration page and you will see all the settings
Aug 05, 2008 | HP LaserJet 1022 Printer
No lights. Have power
If it is out of the box then take it back to the store for and exchange the likely thing is that the memory has fallen out and not allowing the machine to boot up correctly. But I suggest take it back for a exchange.
Thanks J
Jan 11, 2008 | HP LaserJet 1022 Printer
Problem with printing with HP 1022 laser printer
Hi, Laserjet 1022 printe supports printing through the Laserjet 6L drivers and its tested, please select the same USB port for the Laserjet 1022 printer which is selected for the Laserjet 6L printer and then try printing. Ragards, MukeshS
Aug 18, 2006 | HP LaserJet 1020 Printer
407 people viewed this question
k24674
jasbo
jasbo
