Question about IBM Wheelwriter 30 Typewriter
No print on paper
When typing on paper , wheel turns ,spaces correctly, but no print
hammer does not fire . i'm told the sinal to fire is there but solonid doent not activate to fire hammer. Typist said last thing it seemed to slow and get weaker on print --then just quit printing .everything else seems to work.... Any ideas?
  • IBM Master
  • 3,594 Answers
Geno is right about the print solenoid pad however they are available and can be installed if you have a little mechanical aptitude. We sell them for 15.00 including shipping. 216-241-0027
Posted on Nov 16, 2008
  • 183 Answers
There is a pad on the solenoid, where it contacts the printhammer. this pad gets old and just falls apart. this will need to be taken to a repair shop to have the pad or solenoid replaced, or there is an adjustment screw that can be used to take up the slack caused by the missing pad. the printhead must be taken out of the machine to make this adjustment.
Posted on Nov 15, 2008
Bought new Brother ML300 will not type anything on the paper, please help!
I would check all the basic stuff first. Is the print wheel locked into position? Is the platen all the way forward? (lever right side) Is the ribbon installed correctly and not cocked up on one side? Do you hear the hammer striking the paper? If you hear the hammer striking the paper, it is a ribbon problem. If you don't hear it, it is a hammer / print wheel problem.
Jun 24, 2014 | Brother ML-300 Typewriter
My Brother ML100 is not printing what I type
Hammer sticking and typing incorrect letters (and or skipping letters): 1) make sure daisy wheel installed correctly. 2) hold down CODE key & Q (RESET) to reset wheel...if still not corrected 3) WD40 the hammer at the base & joints where moving parts are, keep typing until oil seeps in (this last one fixed it for me)
Typing light and inconsistant-top part of letter okay but bottom too light or not there: to left of hammer (at base) are 2 screws, I losened them and adjusted hammer to different forward and backward spots..finally found the ideal location where full letter printed and had the correct force it needed to print correctly.
Feb 21, 2013 | Brother ML-100 Typewriter
Many brother type writers have two cam assemblies under ribbon holder. One operates the print hammer and the other operates the correction ribbon lift. sometimes they gets stuck or lock themselves up. turning on and off a few times will take care of it, but sometimes it needs to be worked on by a tech. If you look when you type a character, most likely the print hammer is not firing or it is striking the correction ribbon instead of the black ribbon.
Let us know if you want to know something more else please accept the suggestion.
Thanks for contacting
Apr 08, 2010 | Brother EM-530 Typewriter
Types funny symbols instead of the number I
The typewriter will print the incorrect letter, or the face of the hammer if it does not spin properly to the correct position. 1. Turn the machine offf for 15 seconds and turn ON, or Depress MODE RESET(the Q key). This will rehome the Daisywheel.I If it prints correctly for awhile then looses its' position, check for ribbon or correction tape interference with Daisywheel movement. If it does not print correctly as soon as you start typing, remove the Daisywheel and inspect the spokes to see if any are bent. Reinstall the Daisywheel and power ON. If the Daisywheel has a bent spoke or two, you can try to straighten them, howvever the cause of bent spokes is a concern. While typing, carefully watch the print hammer movement. It should always return to the same position and not move towards the paper until a letter is pressed. If it does not come to rest properly, the hammer is not in proper timing and may enter the Daisywheel while it is spinning to the character, thus causing damage to the Daisywheel or causing it to lose homing. .The hammer cams would require adjustment ore replacement. If bent spokes is a persistent problem, make sure to get the hammer problem repaired before buying a new daisywhel.
Dec 29, 2009 | Brother SX-4000 Typewriter
Wheelwriter 3 Selector Assembly
The selection motor bearings just right of the print solenoid get dry a little WD40 on the front and rear bearings usually takes care or this.
Dec 14, 2009 | Lexmark Wheelwriter 3 Typewriter
Have switch it on put paper in and new ink but its not typing on the paper
Check the ribbon first. Remove it and check that the ribbon is feeding properly (letters should be spaced evenly on the ribbon). Ensure the hammer is stiking the paper and that the correction(lift-off ) tape is not in front of the hammer.
Nov 03, 2009 | Office Equipment & Supplies
My typewriter doesn't type..won't display letters, but keys work.
alot of the brother t/w's have 2 cam assemblies under ribbon holder. 1 operates the print hammer and 1 operates the correction ribbon lift. sometimes these will hang or lockup. sometimes turning on and off a few times will take care of it, but sometimes it needs to be worked on by a t/w tech. if you look when you type a character, most likely the print hammer is not firing or it is striking the correction ribbon instead of the black ribbon.
Feb 27, 2009 | Brother Office Equipment & Supplies
the markes you see is the print hammer hitting the ribbon & paper. remove the ribbon & print wheel. look close at the print wheel when out of the machine if there are any spaces betwen the spokes a letter has broken off and you need a new print wheel, If just bent slowly strten them out. reinstall wheel & ribbon try it.
Jan 21, 2009 | Smith Corona Wordsmith 200 Typewriter
I can not figure out why it won't type
Could be the print hammer selenoid is stuck if the print hammer does not fire at all. It shoild fire whether there is no ribbon or print-wheel installed. Look around for any loose cables but failing that your only option is to go to a repair shop.
Sep 16, 2007 | Brother GX-6750 Typewriter
IBM Wheelwriter 30 Typewriter Logo
176 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
