Question about Hitachi 57TWX20B 57" Rear Projection Television
Convergence board- Repair/ replace?? who has done this?
I've got issues with the color convergence, and can't correct with magicfocus, or manually with grid. Pretty sure it's a convergence problem. Anyone ever replace the convergence board? Is it like a computer that can snap in a new one? or is it part of another assembly? I'm trying to decide if I can fix this myself. Thanks -Mark
    President:
  • 3,130 Answers
Mark, there are no real user replaceable parts inside this projection set. All the parts are soldered into place, so if you have solid state repair experience, you may be able to do this repair yourself. there are no snap in parts here. i would say to you, play it safe and call in a tech to assist you in this repair, as there is no quick fix, or any parts you can replace, not without tearing into the main chassis assembly. Good Luck Please do not forget to rate this thread.
Posted on Dec 10, 2006
  • 53 Answers
Replace convergence ic's probably stk392-150 and check all resistors normal values 1.5 ohm-2.2 ohm-2.0 ohm-3.9 ohm check out of circuit- tolerance has to be dead on.
My Mitsubishi 1080HD model WS-55315 colors are not correct. The blue is good and the green seems to be, everything else seems to be a shade of light brown or tan. I thought maybe the red tube was bad but...
The tv have a problems known as a convergence pictures problems,it is dead.Tv have any colors lines like R,G,B mis alignments,also tv have any colors shaded shadows pictures or a 3D pictures look alike?Yes,than the tv have a convergence board problems and it is dead to causes all of these problems.The tv convergence board must have to repair like replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence pictures problems.The tvs shops repair a DLP tv convergence board will cost u like $300-$350 for parts an labors.
Sep 12, 2011 | Mitsubishi WS-55315 55" Rear Projection...
Screen looks 3D Colors don't line up One or more colors can't be adjusted when using the convergence menu. Screen is bowed or warped.
The convergence Ics have blown and need replacement. The pico fuses on the D board and G board will also need to be checked and replaced with the ICs. The Sony Type 1 convergence repair kit from www.tvrepairworld.com is the correct kit for your model which includes the components and the CD with repair instructions.
Jun 17, 2011 | Sony KP-46WT510 46" Rear Projection HDTV
Colors converge will not adjust. What can be done?
Xpertis,
When the convergence will not adjust after you know you have set them correctly using your TV's convergence adjustment, your convergence board went bad. You can either repair it yourself with kits sold online (links below) but unless you know how to solder very well, opt for a repair guy. Your model will cost between $350 and $450 if you hire someone.
http://www.tvrepairkits.com/xcart/product.php?productid=20095&cat=0&page=1
http://servicemanuals.vstore.ca/product_info.php/pName/hitachi-dp-14g-43uwx10b61uwx10b-convergence-repair-kit/cName/convergence-repair-kits
http://servicemanuals.vstore.ca/product_info.php/pName/hitachi-dp15-convergence-upgrade-kit/cName/convergence-repair-kits
If you like to tinker but not dwell into the soldering world, try finding the same model for free or dirt cheap on a web site like www.craigslist.org that still works but like where a kid jumped into the screen!, and swap out the board.
Good Luck!
-Chris
Sep 07, 2010 | Hitachi 57F500 57" Rear Projection...
Convergence issue Blue not convering correctly, but the other colors do. The blue is warped at the top and bottom of the screen. Is this problem something that can be fixed?
Yes,the covergence ICs and precision resistors can be replaced to rebuild the area. A reputable shop may charge around $300 . If you are technical person,I can guide you further to do yourself!
Jun 04, 2010 | Toshiba 53HX71 53" Rear Projection...
Red color convergence issue; Red lines are curved
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Nov 24, 2009 | Televison & Video
Getting lines to line up
Hi, if the green isn't straight to begin with you will need to go into the convergence sub menu and align it there code is 062597 status then follow the instructions to adjust the green first, then red , then blue multipoint and save it.
pressing menu to switch arrows to move/adjust status to back up , make sure to scroll down to save multipoint before exiting, power off when done.
If any color will not move or is more than 1 inch out of adjustment you may need to check the resistors to that convergence color .
hope this helps
Eric
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Aug 23, 2009 | Philips 55PP9401 55" Rear Projection...
Picture is all distorted ,colors dont match up need 3d glasses to watch
HI, this is basic convergence failure. the convergence board controls the RGB stream and , if its malfunctioning or, the convergence chip set is damaged, it will distort the entire display and the colors will not be regulated correctly as you are experiencing at this time.
simply replacing the convergence board in this unit will fix your issue.
May 18, 2009 | RCA Televison & Video
Red color convergence on Toshiba 57H81
Often convergence issues do not require the entire board to be replaced. You can resolve it by replacing the convergence ICs. The part in question is STK392-110. You will need two of them and they cost around 10$ each. But replacing them is a pretty complicated procedure and I would not suggest it to someone without prior experience. A service manual should get you started in the right direction if you are planning to do this yourself.
https://www.completeservicemanuals.com/toshiba/crt-projection-television/57h81-service-manual/prod_1128.html
PS
: Disconnect from the power supply before you start the repair. Also read the legend, the hv circuits are denoted by a special symbol, so you will know what you shouldn't touch.
You may also need to replace the nearby resistors that may have popped the IC in the first place. Read the service manual for further details.
Good luck,
Sai.
Apr 01, 2009 | Toshiba 57H81 57" Rear Projection...
Hutachi 43inch rear projection 5 yrs old
Hitachi Convergence
Check out the Convergence Gallery. If you see the colored outlines or color shading as in the Gallery, you have a convergence problem.
The repair for a Hitachi requires the replacement of the defective IC or ICs and any damaged or smoked resistors. Some models don't have a separate convergence board and the board is not usually available for the ones that do have a separate convergence board. Usually there is little alignment required after the repair. If you play with all the adjustments before the fix, hours may be spent re-aligning.
If you change the original ICs with substitute "new and improved" parts that are talked about in the blogs, you will probably create problems. Use the original ICs and resistors.
Don't monkey with it.
This is a delicate and difficult repair. If not done by someone with some electronic repair experience, the TV will likely end up as junk or cost considerably more for a tech to fix the damage done.
If you live in Calgary, call me. If elsewhere, find a competent tech.
easyab
Jul 30, 2008 | Samsung HCN4226W 42" Rear Projection...
Convergence problem???
I am a TV tech and have had experience with this type of problem on many sets...So Far the only trouble is the 2 output ic's stk392-110 which should be replaced with the upgrade stk392-180..All three Color Amps are within these ic's for both horizontal and vertical convergence. Sometimes a resistor or two will burn out as well because of the short in these ic's. Be sure to be extrremely careful unsoldering and soldering and use good heat sink compound and fasten securely to the heatsink metal. Manual convergence calibration may be necessary after the ic's are replaced. First try Touch Focus after the ic's have been Properly replaced. This repair should be done by competent personnel and takes about 3 hours because of dis-assembly and re-assembly time. I am writing this because i have seen on this site mis-leading info. i come to these sites myself to verify part numbers and to see if there have been additional complications such as complete shut-down.
Sep 13, 2006 | Toshiba 53H71 53 in. Rear Projection...
Hitachi 57TWX20B 57" Rear Projection Television Logo
272 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
