Question about Whirlpool ED5FHEXMQ Side by Side Refrigerator
Refrigerator does not get as cold as I would like
Canned and bottled drinks get cool but never cold. The same is true for other liquids such as milk and tea. Have the controls turned up to the maximum setting but the drinls aren't any colder than they were at 3 or 4.
    Scholar:
  • 66 Answers
First check the condensor fan and condensor for dust and make sure they are clean. If these areas are not clear the system will not operate correctly. You should be able to place your hand down low on the front of the frig and feel warm air coming out of the grate there. The presence of a flow of air meens that the condensor fan is working. Depending on how forceful the air flow is, would depend on how much dirt and dust the condensor has collected. The temp controls should be set to midway first. There is a dilicate balance for these settings. Over adjusting can cause problems. Then after several hours check the frig. If not cold enough. Adjust only the fresh food adjustment colder a little bit at a time. Repeating this untill your fresh food side is cold enough. If you over adjust the fresh food side too much then food in the fresh food side will begian to freez. If you set the freezer side too high you may be causing too much frost build up on the evaporator and lowering the air flow to the fresh food side and causing it to be warmer than it should be. This would be a check to see if you can balance the frig temp. If you can`t get it to balance and there are no restriction of air flow in either the evaporator or condensor, then we may have to look farther into problems with the compressor. You may need to check for some ice buildup around the air inlet in the fresh food side from the freezer side. Try this and let me know how it is.
Posted on Nov 14, 2008
Not keeping ice cream cold enough in freezer & milk and drinks in refrigerator are not cold enough
You need to change the settings on the thermostat. Its a dial setting inside or digital setting on the door. Lower the temperature until you are satisfied.
Feb 29, 2016 | Refrigerators
Kitchen selectives rechargeable wine chiller bc-10r 8 minute chill
For the KITCHEN SELECTIVES WINE CHILLER...A box on ebay says: Put bottle inside, add ice to neck of bottle, add water, plug in and set timer for 10-20 minutes. It chills from 77* to 55*or 33* (can't read numbers clearly) in 10 minutes. Can also be used on other drinks and canned drinks. Can be used as an ice bucket as well to keep the opened bottle chilled.
I just bought one at Goodwill for $4 today and was looking for the instructions as well. Hope this helps! 8d55b92a-9870-497d-a9c6-7cda8d40c58a.jpg 11a83201-002b-4f0c-b811-810f4cf0046e.jpg
Dec 16, 2011 | Refrigerators
Refrigerator side not cooling, freezer seems fine.
Clear the air vent fan passage, maybe it is obstructed with so many food stuff and bottle of drinks. Pullout unnecessary things in the refrigerator and check the door gasket. It must be tightly seal so that cold air is not going outside. Neatly re-arrange the things inside and clean also the shelf including air vent. Be sure temperature setting is correct.
It's been nice to help you.
Jul 04, 2011 | Maytag MSD2756G Side by Side Refrigerator
Freezer works great but the refrigerator don't work. any ideal
Remove any things that will hindrance or block to the flow of cold air inside the refrigerator. Often the fan is block with food stuff or bottles, cans of drinks. Rearrange it correctly and also clean the fins of fans. Pullout unnecessary things and clean the inside. Put some allowances to the things inside. Overloading of food stuff really make it hard for the refrigerator to cold it. It takes longer for a overload food stuff to eliminate heat outside and cool then cold it.
It's a pleasure to help you.
Jul 03, 2011 | Dometic RM2852 Refrigerator
The refridgerator is not cold enough...it's turned to a high setting and still milk is spoiling...now what?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 27, 2010 | Kenmore 64254 / 64252 / 64259 Top Freezer...
The freezer is working OK but the fridge is barely cold so that milk goes off quickly. Thank you.
heatman101
Nov 27, 2010 | Zanussi ZI921 / 8FF Bottom Freezer...
Frezzer on top cold milk area will not get cold just cool cleaned evapator coils.still not cold = lot of water overflow in drain pan empty often ,modle #et20gmxfn01
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Aug 30, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
We have a GDM-26 commerical coke machine. Only
If any of your drinks are freezing you need to adjust your temp setting. The suggested setting is 5. changing the temp setting basically tells the refrigerator to stop cooling when the temp hits a low degree, and to start cooling when it hits a high degree. This keeps your drinks not to hot, not too cold, but just right. If this doesn't work I would change the cold control altogether, it might've went bad. If you have a few minutes, locate the condensor fan (bottom) and make sure it is periodically turning on and off like it should.
Jun 08, 2009 | True GDM-12 Refrigerator Commercial
Whirlpool ED5FHEXMQ Side by Side Refrigerator Logo
165 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
