Question about Select Jazzy Used Electric Wheelchair
My Jazzy wheelchair will not charge or run
I have new batteries, a new charger and still will not charge. The charger light is charging but does not get the green light to say that its charged. All wires appear to be connected right. I dont know if the problem is the batteries or a connection problem. The joystick controller does not work, maybe a connection problem. Can anyone tell me what the problem might be? what should I do? where should I start ?
  • Anonymous Apr 11, 2009
    Same problem But my batteries are good. just let the chair sit for about a month but the acully charger its self is the problim i think. the red light comes on indicatiing there is power to the box but the yello light that comes on normaily isn't comming on and its suppost to turn to green when the chair is charged. the fan in the charger is also not running
  • 103 Answers
First have the batteries tested to be sure that they are good. Just because they are "new" doesn't mean they are good. Then with the batteries disconnected plug the charger in and turn the chair on. This will tell you if the charger is good.
If both of these are good then you have an electrical problem. You need to call a local tech.
Posted on Mar 09, 2009
3 Suggested Answers
  • 692 Answers
SOURCE: My Jazzy select six sometimes charges
After charging overnite get a digital voltmeter set it to 200 volts dc and plug the leads into the 2 outter holes in the charger port located under the front of the joystick. If the charger works properly you should read 26-27 volts on the meter. If you are reading 24 volts or less then have the charger checked it should be putting out 27-30 volts or so. I would also have the tech check the batteries under load and check the wiring harness from the joystick to your controller. Hope this helps
Posted on Nov 03, 2010
wcdoc1953
  • 280 Answers
SOURCE: When I charge my Jazzy select 6 over night the off
I am assuming that the PWC runs and the batteries behave like there is a full charge. The performance of the Jazzy is good. If you have a volt meter you can check the voltage at the charging port but this is too difficult for the average user.
There is a battery display indicator (BDI) on the joystick that indicates battery charge through a series of LED lights. More lights, larger charge and higher voltage on the batteries. There are two reasons why the LEDs are not lit assuming the first two sentences are true:
1. The LEDs or the circuitry running them is burnt out.
2. The LED module has come unplugged from the circuitry.
The solution for both problems is the same. Open up the joystick case( if it is out of warranty )and inspect the LEDs and wiring. The easiest and most expensive way to solve the problem is to replace the joystick assembly. If you do nothing there is a good chance that you will get stuck somewhere because you do not know the charge state of the batteries. If it is under warranty your problems are solved. Call a qualified dealer in your area and have the problem component replaced.
Hope this helps.
Posted on Nov 04, 2010
I am new at this i plug in c harger and only powre light comes on, is it charging or is the chatge light supposed to come on?and how long does it need to charge a jazzy select?
If your charger has a red and a green led on it when the green led lights the battery is charged. If you use it a lot during the day it may take 8 to 10 hrs or more to fully charge the batteries
Jan 11, 2014 | Pride Jazzy Select 6 Indoor Power...
Battery charger light doesnt work showing that the batteries are being charged.
okay first of all check that the batteries can be seen from the charger socket, otherwords get a electronic meter and insert the probes in the two outside holes , do you get a reading on DC ?
Nov 29, 2012 | Pride Mobility Jazzy Select Wheelchair -...
My battery charger for my Jazzy 600 does not light up or get warm when I plug it in. The chair has not been used for months.
I tried to charge my jazzy. The charge light (red) remained on for several hours. Finally I moved the wire slightly the charge light turned green than faded to red. What is my problem? Your solution would be greatly appreciated.
Jun 04, 2012 | Pride Jazzy Select 6 Indoor Power...
Replaced batteries in Jazzy 600 but they will not charge up.
doug then you could have received a bad battery or you have a charger problem or a charger circuit problem. If the chair comes on then the wiring is ok. when you plug the charger in do you have a green light and a yellow light on the charger? (when fully charged the light goes from yellow to green indicating full charge) If when you plug the charger in and you have a red and green light then there is a problem with the charging citcuit. I would contact your provider where you got the chair to have them check it out for you Hope this helps
Feb 19, 2011 | Pride New Jazzy 600 Power Wheelchair by...
When charging my jazzy, do I unplug any plugs that controls my jazzy, or leave all plugged in? the reaon ask, green light will not come on the charger, which is onboard charger, unless I unplug controller...
No JJR all the plugs need to remain plugged in. On the Pride chairs the light on the charger will only come on green when the batteries are fully charged. When you unplug the controller the charger thinks the batteries are fully charged and the light comes on. Now the problem is the batteries. If they are old or you have a bad battery then the charger never senses a full charge so no green light. Hope this helps
Aug 26, 2010 | Pride Jazzy Select 6 Indoor Power...
Jazzy Select 6 Indoor Power Wheelchair: how to charge...
The Jazzy Select 6 requires an off-board charger. Plug the charger into a grounded outlet; preferably one that doesn't have other large loads on the circuit like refrigerator, freezer, microwave, etc. The male 3-prong XLR connector coming off the other end of the charger plugs into a female XLR connector which is on the joystick control's bottom-rear. Charge it overnight after each days use, and at least once each month overnight. You should get 2-4 hours of use from the chair at top speed with a 200 pound driver, depending on terrain and climate. If it isn't holding a charge, you will probably need two new U-1 type gel sealed batteries that run about $120.00 or so each. Make sure you test the old batteries first at a knowledgeable battery shop. These are deep cycle batteries and require a special testing. If the batteries are good, then your charger isn't charging. Search EBay or other online sites for a wheelchair charger in the 4-6 amp range. They can be found for about $45.00 or so. Pride will charge you a lot more.
May 18, 2010 | Pride Jazzy Select 6 Indoor Power...
Select Jazzy Used Electric Wheelchair Logo
2,203 people viewed this question
Top Select Health & Beauty Experts
wcdoc1953
wcdoc1953
Scooter Doctor
Scooter Doctor
Colin Taylor
Are you a Select Health and Beauty Expert? Answer questions, earn points and help others
