Question about Canon Office Equipment & Supplies
My PIXMA ip1600 is telling me that my waste ink absorber is almost full. What do I do about this?
    Scholar:
  • 121 Answers
Canons generally have four screws that hold the entire printer mechanism on the plastic base. Some models do have a power supply module that slides out of the rear of the case, remove this first. Remove the four screws holding the printer mechanism onto the lower case. Some models may have more screws, but be careful not to remove any other screws! It just lifts off.
Take the waste ink pads out and lay them down on some newspapers by the sink. Set the waste ink pads in the sink. Pour some of the cleaning mixture into them to dissolve the ink, then gently run hot water through to rinse it out. It will never look clean, don't try, just get it so there is little ink left in the wash water. It is a rather fragile felt-like substance so if you try too hard, you can end up destroying it.
Squeeze out as much water as you can. Do -not- twist it like a towel!
If you have a hair dryer try using that to dry it...Leave it in sun for a while
Reinstall the ink pads and reassemble your printer.
Once you've got the pad cleaned and the printer back together, you'll need to reset the counter or it won't print.
1. Turn off the printer. And disconnect the printer cable.
2. Press and hold the POWER button, turn on the printer.
3. The indicator (L.E.D.) should be green.
4. Press and release the RESUME button , the indicator (L.E.D.) should
be orange.
5. Press and release the RESUME button again, the indicator (L.E.D.)
should be green.
6. Release both buttons.
your printer is in a ready state now
Do a test print.....
keep me posted
please dont forget to rate the solution
Cheers!
Posted on Nov 13, 2008
  • exhale sys Sep 19, 2011
    the solution is good, but only until you take out the power cord from the socket.
    after that, when you restart the printer, the same error state appears...
IB4G2008
  • 3587 Answers
SOURCE: ink waste absorber
sure...it's under the back cover, with a small thin cover to remove it..
Posted on Mar 10, 2008
SOURCE: Error 5800: waste ink
Clean or replace the absorber and reset the printer counter to clear the message.
Posted on Apr 30, 2008
SOURCE: Waste Ink Absorber is full In Canon Pixma IP3300
please give me resetting soft for canon Pixma iP 3300 printer.
Posted on Oct 06, 2008
SOURCE: waste ink absorber full
my printer is very broken in this so absorber full,it make reset manual,can helm me
Posted on Feb 22, 2009
  • 272 Answers
SOURCE: ink absorber full warning
Yes, first unplug the power chord and then the usb chord. When you are done doing that, take the printer to an area where you have a little working space. Put it down on some newspaper. Open the lid. (Normally, when you open the lid with printer on, the cartridges will slide over to the left of the machine, this is important to remember for part of the cleaning). Now, with printer lid up in the air, look down inside the printer. you will see some plastic running horizontal with the printer ribbon, (the area I am referring to is right under where the ink cartriges slide back and forth)on the floor of the printer. If you take your finger and feel inside, you will find a very thin, narrow piece of foam in between the plastic strips. You can gently remove this foam and clean it with denatured alcohol and let it completely dry before replacing. You can also go in and clean the plastic area with a Qtip, because there will be a residue of ink all over this area. Also, right under where the ink cartridges park when opening the lid when plugged in is another small piece of rubber pad that should be cleaned too. Once you have done this, and this is important.. before, and during the replugging of the usb plug and the power chord, YOU MUST keep the "on key" pressed in. This is going to help reset your printer once it's plugged in. So keep your on button pressed down and plug both chords in. ONCE that's done, let go of the power button. It will go on and run through some of it's noise. The yellow light might come on again, that's okay, just turn off your printer, wait a few seconds and turn it back on. It should work fine. We did this because we had read about holding in the button for resetting. If you clean the ink pads in the future you must do that because it actually is resetting something in your printer. Mine works just fine. I will add that I went through a lot of ink cartridges to get to this point but it is pretty easy to clean if you just take your time, be patient and carefully remove the foam not to damage it. Good luck
Posted on Jun 01, 2009
Canon mp140 ink absorber full
you need to reset the pad absorber counter read on here
good luck!
Jul 11, 2011 | Canon PIXMA MP150 All-In-One InkJet...
Canon Pixma Ip1700 will not print, because the Ink absorber is full.
Hi there
Please under-stand at some time you will need to clean out the waste inkpads that are inside your printer or it going to be a big mess of inks coming out.
Some times the IP tools will fix it Canon Pixma iP1200, iP1600, iP2200 Resetter
1. Download software for Canon iP1200, iP1600, 2200 Printers.DOWNLOAD Service Tool Software for Canon Pixma Printer iP1200, iP1600, iP2200
2. Unzip downloaded file by WinZip, 7Zip, Izarc, etc
3. Run GeneralTool.exe
4. Select the connected USB port number from USB PORT
5. Click LOCK RELEASE, and select the applicable model name in SET DESTINATION
6. In CLEAR WASTE INK COUNTER, select MAIN or PLATEN. The selected waste ink counter will be reset. MAIN resets the main waste ink counter, PLATEN resets the platen waste ink counter.
If both the main and platen waste ink absorbers are replaced, reset both the main and platen waste ink counters
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 15, 2010 | Canon PIXMA iP1700 InkJet Photo Printer
Waste ink absorber is full
Hi there
Mar 14, 2010 | Canon PIXMA iP1600 Printer
Canon pixma 1200 waste ink absorber
u must change now cartiradge good luck enjoy vote for my comment
Aug 06, 2009 | Canon PIXMA iP1600 Printer
The Waste Ink absorber is almost full, where is the waste ink absorber???? How do you clean it?? I have a Canon iP1600 USB 002
Not sure on a Canon, but you can buy a replacement pad. I would buy a Waste Ink Container which sits outside the printer. When it's full you pour down the sink. The waste ink is not usable. You can check the link below is there's one for your printer. While there check if they have a CISS for your printer, it will save you Tons of money.
http://www.inkproducts.com/ink-store/
Aug 04, 2009 | Canon PIXMA iP1600 Printer
Waste ink absorber?
Hi. As you have not mentioned the make and model of the printer, I am giving here the procedure to reset waste ink counter applicable to most printers. Hope it helps.
If both the main and platen waste ink absorbers are replaced, reset both the main and platen waste ink counters.
If you have a different printer model, then please tell me and I will research that for you. Thanks.
Jul 29, 2009 | Canon PIXMA iP1600 Printer
Ink waste absorber
Waste absorber is full. Where is the waste ink absorber and how do I empty it?
Apr 08, 2009 | Canon PIXMA iP1600 Printer
Where is the waste ink absorber on the pixma ip2200
Hi. I have researched on it and found that the procedure below resets the waste ink absorber most of the times and that too automatically. Hope it helps.
  6. In CLEAR WASTE INK COUNTER, select MAIN or PLATEN. The selectedwaste ink counter will be reset. MAIN resets the main waste inkcounter, PLATEN resets the platen waste ink counter.
Mar 14, 2009 | Canon PIXMA iP2200 InkJet Photo Printer
Canon printer Pixma IP1600
Hi - Try the following procedure:
1. Remove INK cartridges
2. Unplug AC power
3. Hold power button and plug AC power while holding the power button in.
4. Press resume 4 times
The waste ink counter should now be reset.
Please update the question & let us know if the information given was useful to you - Good Luck!
Jul 11, 2008 | Canon PIXMA iP1600 Printer
100 people viewed this question
old marine
old marine
