Question about cyberxlink (CXLEBRW) Wireless Router
CyberXLink CXL-EBR-W router - can't open ports 5631/5632 for pcAnywhere
I am trying to setup CyberXLink CXL-EBR-W 4PRT (with printer server) router to work with pcAnywhere 12.0 as HOST. (port forwarding, open ports 5631/5632). But ports 5631/5632 show "stealth" when I try to scan with port scanning program (eg. pcflank.com) despite my host is in waiting status at the time of test. PS. They show "stealth" even when I disable router firewall. How can I open ports 5631/5632 , as these are needed to be opened when working with pcAnywhere? Thanks.
  • 5 more comments
  • dave green Nov 17, 2006
    Hi Duder,
    Appreciate your help!
    Below are may answers:
    If the router has it make sure "Block WAN Request" is disabled or you won't get anywhere.
    A: no such option
    Also I don't know if the print server has anything to do with your problem. Have you tried mapping those ports directly to the host in the router?
    A: Is this the same as the next item ("call forwarding"), or smth else?
    TCP PCanywhere port 5631 Inbound 192.168.1.[host IP] port 5631
    UDP PCanywhere port 5632 Inbound 192.168.1.[host IP] port 5632
    A: I did this (I believe this is what I call "port forwarding")
    I'm also assuming that you're using a static IP on the host. You don't want to use a dynamic IP.
    A: I am using static IP at my host laptop (wireless)
    PS. Besides:
    1. I am running WINXP PRO, and added those ports to Windows Firewall (advanced setting)
    2. I disable both firewalls - Windows and Router - still "port scan" says "stealthed" on those ports :(
    3. Before every try I reset router and Verizon DSL modem.
    I even called Verizon to see if they have any restrictions on these ports, but they said NO.
    4. I am using pcAnywhere 12.0
  • Anonymous Mar 12, 2014
    ricoh 1027 -failed to copy .it keeps jamming the copier
    opel ascona 1.3 pushrod motor torque settings for cylinder head
    I need instructions on how to boot my HP Compaq dc7700 Ultra-Slim Desktop from the Boot Menu, I need to restart the computer using a HP Restore Plu DVD for Windows Vistarom a DVD from the Boot Menu
    where to download for free manual of lancer model 92 lift back
    I have myob 6 and want to run it on mac mountain lion. Is this possible?
    when I spin drum by hand it feels a bit lumpy
  • 47 Answers
Hi dave, I'm not familiar with that router at all and I didn't find any doc's online for it so I'm running blind here but... If the router has it make sure "Block WAN Request" is disabled or you won't get anywhere. Also I don't know if the print server has anything to do with your problem. Have you tried mapping those ports directly to the host in the router? TCP PCanywhere port 5631 Inbound 192.168.1.[host IP] port 5631 UDP PCanywhere port 5632 Inbound 192.168.1.[host IP] port 5632 I'm also assuming that you're using a static IP on the host. You don't want to use a dynamic IP. Hope this helps. Let me know how you make out, Duder
Posted on Nov 17, 2006
  • The Dude
    The Dude Nov 17, 2006
    I didn't think I needed to ask but your not running a software firewall on the host right?
  • The Dude
    The Dude Nov 25, 2006
    Sorry man I forgot this was still open.
    I was trying to find a manual for your router online, you don't have a link to one do you?
    I emailed the Co. the, as far as I can tell, made the router to request one but got no reply.
    Have you tried running the connection without the router?
I am trying to download PCAnywhere 12.0 to windows 7 and it tells me they are not compatible
That is correct Symantec list supported operating systems and Windows 7 is not compatible..
System RequirementsWindows 2000 Professional/Server/Advanced Server
Windows XP Home/Professional (32-bit and 64-bit)
Windows 2003 Server Standard/Enterprise (32-bit and 64-bit)
Windows Vista Ultimate/Business/Enterprise/Home Premium/Home Basic (32-bit and 64-bit)
Windows 2008 Server
Internet Explorer 6.0 or later
Regards
Nov 10, 2009 | Symantec pcAnywhere 12.0 Host & Remote...
Trying to open ports
You will need to setup Ports 5631 and 5632 to forward to the IP of the computer with PC anywhere installed on it. You need to go into the Virtual Server section to setup the port forwarding.
Apr 22, 2009 | Computers & Internet
Broadband
purchase and install a broadband router. connect both computers to the router. make sure to follow the particular routers setup instructions fully
Mar 22, 2009 | D-Link 4-Port Ethernet Broadband Router...
Slow internet connection to my x-box. Problem
Try to open the ports of the XBox to the EBR-2310 router.
Ports of the XBox: TCP 80, 3074 and 53
UDP 88, 3074 and 53
You'll needing to access the configuration page of the router (192.168.0.1) and open the ports under port forwarding.
Mar 09, 2009 | D-Link 4-Port Ethernet Broadband Router...
How to set 5631 tcp and 5632 udp
You need to access the router via a web browser. Standard addresses are 192.168.0.1 or 192.168.1.1.
If neither work, you need to go to start>run> type in "cmd" then OK. Once you get command prompt up, type in ipconfig (Then enter). The Default gateway is the address to your routers configuration page.
Once you get in go to/find virtual servers and and the ports in there. for the ip set it to your computers local ip, you can find it in run>cmd >ipconfig thing i told you earlier. It would be under IP Address
Feb 27, 2009 | Belkin (F5D5231-4) Router
Can I piggyback a wireless router onto a hard-wired router?
Yes, you can connect the DI-624 to your exitsing EBR-2310, you just need to connect the a cable from port 4 of the EBR-2310 to the internet/wan port of the DI-624, then after that you can already use now the wireless to your laptop and also the wired router to your desktops.
But I may suggest you to just replace the EBR-2310 with the DI-624 so you will only be using 1 router that can cater your laptop and also your desktop, Just connect the cable from your modem that is conencted now to your EBR-2310 to the internet/wan port of the DI-624 then run the setup CD that should be it.
Hope that helps...........
Aug 30, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
Found the check box - for Block WAN
I believe your initial problem was for PCAnywhere rgiht? just make sure ports 5631 (Data Port or TCP) and 5632(Status port or UDP) is properly opened/forwarded on your router's config page plus make sure that you instruct the router to forward those ports to the computer that you have PCAnywhere plus I have read some articles that newer versions of PCAnywhere 10.+ 11.+ will not work with older version 5.+
Now if it still doesn't work try setting up DMZ for you host computer(Note: enabling DMZ will open a wide range of ports, well common ports that is).
Jul 02, 2008 | Linksys Wireless-G WRT54G Router
Trouble with PCAnywhere locking the port
Ok ensure that nothing has changed.. Check the Firewall setting, at BOTH ends, to ensure that the "Port" is Passed thru.. also check to make sure the address's used by PCanywhere are the same at both ends. Perhaps the port ya been using has become "Blocked" somehow? OR some setting have been changed.. carefully check it all out. GL
Nov 03, 2006 | Adtran Total Access 616 Router
Open Questions:
See all cyberxlink (CXLEBRW) Wireless Router Questions
cyberxlink (CXLEBRW) Wireless Router Logo
349 people viewed this question
Top cyberxlink Computers & Internet Experts
David Payne
David Payne
Are you a cyberxlink Computer and Internet Expert? Answer questions, earn points and help others
