Question about Minolta magicolor 2200 DP Laser Printer
I own a 2002 Magicolor Desk Laser printer and I know it is capable of heat transfers but I am not sure how it works...It never came with a manual??? I know this process requires special paper, but what program do you create the artwork from and which location is the paper loaded?
  • Minolta Master
  • 6,168 Answers
4 Suggested Answers
Niraj Limbu
  • 183 Answers
SOURCE: where is the drum reset fuse located on the Minolta 2530 DL print
you can find all details with picture shot on following website:
ftp://ftp.minolta-qms.com/pub/cts/out_going/manuals/2530dl/user_e.pdf
please post back if any changes and vote all answers.
good luck
Posted on Feb 07, 2009
SOURCE: magicolor 2400w gives paper jam error at transfer
Bought this printer used at a thrift store and it had two problems.
The first was that it wouldn't grab the paper. Once I cleaned the shoe that grabs the paper from the tray, it no longer had that problem.
http://www.elperfecto.com/Konica_Minolta_2430DL_magicolor_Media_Jam.html
The second problem was that the printed image was very faint, most of the toner remained on the transfer drum and the print failed with a paper jam at transfer roller. I solved this by removing the OPC drum and soaking a qtip with glass cleaner then cleaning the two contacts on the inside right that touch the drum fuse. After that I also cleaned the bias wire and the 4 springy wires on the left of the printer.
Bias wire issue
http://onyxweb.mykonicaminolta.com/newKB/KBDocument.aspx?id=TABP0900851EN00&ptid=
Posted on Aug 11, 2010
SOURCE: Konica Minolta Magicolor 2300 DL - Fatal Error Code 0EH ????
I had the same problem one time, they told me to pull out all of the toner cartriges, power off, power on, power off, replace all cartridges and the problem went away.
Who knows why. If this doesn't work....
Call Konica Minolta tech support.
http://ewpm.eu/konika-minolta-2300-w-fehlercode-0eh-17h
Posted on Jun 02, 2013
My printer says "Belt Error" how can I fix this?
The printer detected incorrect
image position on the image
transfer belt.
Check the cyan and black
toner cartridges and replace
them if they have run out. Page 171 of Konica Minolta Magicolor 1650en Laser Printer Manual...
Nov 16, 2014 | Konica Minolta A034012 Magicolor 1650en...
Service call:14H on Konica Minolta magicolor
Transfer separation Roller open the machine where the transfer belt is see a sponge looking roller on the other side ensure it is properly installed or replace it.
Jun 04, 2014 | Konica Minolta magicolor 2400 Laser...
Konica Minolta Magicolor5440DL Error Code
error 0094h = 2nd image transfer pressure/retraction failure
basically it means that either a sensor or cable is not fitted supposedly and reseating could possibly solve the issue.
you can research the error code in the following service manual:
http://printer.konicaminolta.com/drivers/other/Manuals/5400/smfs_54.pdf
Mar 09, 2010 | Konica Minolta magicolor 5440 DL Laser...
Fatal Error Code 16H
Hi, pretty sure its the transfer belt not able to turn, remove it and make sure there is nothing blocking it, maybe a paper jam
Aug 05, 2008 | Konica Minolta Magicolor 2530 DL Laser...
Minolta magicolor 2200 DP Laser Printer Logo
59 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
