Question about Craftsman 4 Cycle Blower/Vac
Craftsman 2cyl leaf blower wii not start
I have cleaned the spark plug,put fresh fuel in it,the other problem i am having is when i pull the pull string its hard to pull its like its fighting me.dave cotton
  • bberead Nov 18, 2008
    hi cotton david ,im bberead allen.i have same problem and im in need of assistance.i was blowing leaves and all of a sudden the engine was loosing power and before it died completely out i turn off by pushing choke lever and ever sense i cant pull the string its like its froze stuck
  • 163 Answers
It sounds like vapor lock, trying giving it a couple pulls with the spark plug taken out
Posted on Nov 29, 2008
Craftsman Leaf Blower will only rev up about 1/2 power at full throttle. Any suggestions?
If this is a two cycle engine there are adjustment screws that set the fuel mixture when the throttle is depressed.
Dec 02, 2016 | Craftsman Garden
My craftsman 25cc leaf blower wont start
pull the plug, plug into wire, touch head of plug to metal on engine. hold by rubber boot while touching pull starter, see if you get a spark across the plug gap, its small but you can see it. if no spark check switch. if plenty of spark clean fuel system and check primer
Nov 04, 2014 | Garden
I can not get my craftsman leaf blower to start. I put a new spark plug and fresh gas. Won't start.
Not to sure without seeing or hearing it being pulled over. Compression? Very likely needs some carb work/kit.
Apr 04, 2013 | Garden
I can't get my Poulon leaf blower to start
So far everything looks good. You're getting fuel, and you're getting spark. Only problem, is you've gotten too much fuel in it, and need to get rid of some before you can proceed. Take that spark plug out, and pull the starting rope hard several times. This will force the largest amounts of fuel out. Now's the part where you'll have to trust me. Use a match or a lighter to "flash" the cylinder. Make sure you don't have excess fuel spilled over the blower, but hold that match or lighter right up to the spark plug hole, and it'll "puff" at you. Please don't look into the hole while you're doing this. Flash the cylinder, and then pull the rope again, and flash it again. Next, make sure the spark plug is dry then put it back in. Set your choke to full choke, and pull until it hits once. Then put the choke on half, and it should start within 3 pulls.
Mar 25, 2010 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Cant get my 25cc craftsman blower to start...
try checking to see if spark plug firing ,, if it is not firing the magneto is bad,, just follow the plug wire and you find it,, here is a way to check the fire,, take spark plug out take a pair of rubber or plastic coated pliers and hold to some metal while someone pull it if you dont see spark then this is your problem,, hope this help you
Sep 01, 2009 | Garden
Wont start
Start with emptying the gas tank totally. Refill with fresh gas/oil mix. Todays gasoline ain't that great.
Also after putting in fresh gas and priming if it doesn't fire at all pull the spark plug and if it is dry, pour a about a tbsp. of mix gas in the plug hole. put the spark plug back in and see if it will fire.
Phil
Dec 07, 2008 | Garden
Craftman 205 mpg 2 cycle gas blower 40:1 raito will not start.
Similar experience with the same blower. I cleaned the carb checked for spark but I still can't get it to start
Nov 13, 2008 | Craftsman 4 Cycle Blower/Vac
Craftsman 4 Cycle Blower/Vac Logo
374 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
