Question about Miele Washing Machines
Overfills with water
Seems to be a problem with inlet valve. On start up the drum fills with water and overflows
  • 833 Answers
Possible but unlikely. If you unplug the machine does the water flow? If not, the problem is the water level switch. Generally, this is a diaphragm switch connected via a tube to the bottom of the tub. It usually is about 2 or three inches in diameter, has a water tube and a few wires connected. Go on a site with a blowup diagram and locate the switch. Disconnect the wires...after noting where they go and with the power off. Insulate them. Does this stop the water flow? Buy the switch.
Posted on Nov 13, 2008
Kenmore 44832 hot water won't stop.
If your washer is overfilling, check these:
Water-inlet valve
Water-level switch
Water-inlet valve Adefect in the water-inlet valve may mean that it's no longer able toshut off completely when the electricity has been turned off to it. Ifthis occurs, the valve may leak and drip water into the clothes tub. Intime, the water may accumulate substantially. If this happens, you needto replace the valve.
Water-level switch Adefect--or an obstruction--in the water-level switch may mean that itcan't tell the water to shut off. So the machine overflows. This switchsenses the water level in the clothes tub. It's usually a diaphragmdevice with a small, clear tube attached between the switch and thebottom of the washer's outer tub. As the water level in the tubincreases, the pressure on the air in the tube increases. When thepressure reaches a certain level, it activates the switch, shuts offthe water, and signals the timer to begin the agitate cycle. You caneither clear any obstruction in the tube or replace the water-levelswitch.
Aug 03, 2008 | Kenmore 44832 Front Load Washer
I am getting an FH Error Code. The water fills fine but I think it is overfilling because the water level reaches about half way up the door and triggers the FH error. I start the drain and spin cycle...
Washer fills with water and overflows:
The water pressure level switch is a pressure activated switch that is used to determine the correct water level in the tub. This part is normally located behind the control panel and will have a hose or air dome tube that connects it to the tub. On washers that use an electronic control, this switch may be located at the sump area below the tub. As the water fills in the tub it will compress the air in the tube and push against a diaphragm inside the switch. The switch will control the water inlet valve and turn the valve off at the correct water level. If the tube has a leak, not enough pressure may be created to activate the switch and the washer may overfill. If the switch is defective it may also cause the machine to overfill. To determine if the switch is bad, you should first eliminate the air dome hose as a problem. Look for signs of cracks or worn areas on the hose. Remove the hose and submerge in water. Seal one end and blow air into the other end and look for bubbles. Check for an obstruction in the hose as well. If the air dome hose appears to be ok, then the water level switch may be defective.
You can test it with a meter and with a manual test? ( first locate it in the panel, it has a plastic clear tube hose going into it, remove that tube from its connection, now put another small tube or hose into the slot where it was and have the machine set to wash cycle with water in it. Blow into the other end of the tube.
If the machine starts to wash. the pressure switch is more than likely good
( No wash- then THE DIAPHRAGM IS BAD AND SWITCH HAS TO BE REPLACED).
The other item to check would be your water inlet valve. Check it for continuity with a multi meter it should show Ohms or a closed circuit. To test it when water is overflowing unplug the unit and see if it still overflows or continues to fill. If it stops when unplugged. Then it is not a water inlet problem but an electrical signal problem going to ur water inlet valve. Possibly from the panel or board.
Mar 31, 2015 | Washing Machines
Maytag oversize capacity plus washer wont stop filling with water even when I turn it off and un plug it
Ah thats usually a sign of a bad water inlet valve not to costly and not to difficult to repair somes a bad water pressure switch will also cause an overfill however when power is off that will stop the overflow so we know its ur inlet valve
Mar 29, 2015 | Maytag Washing Machines
Washer overflows
Feb 13, 2014 | Frigidaire FGZ831A Top Load Stacked Washer...
Frigidaire washer mod#fws223rfs0 overfills
Feb 09, 2014 | Frigidaire Washing Machines
Over filling
Hi
Thanks for using FixYa. Overfilling in your washer occurs mainly due to two things: water inlet valve going bad and/or the water level switch. If the water inlet valve has gone bad it won’t be able to shut off even when the electricity has been turned off. If the issue is with the water level switch then it won’t tell the water to shut off and the machine will overflow as this switch is to sense the water level in the clothes tub. However, with that being said it seems that you’ll need to replace the water inlet valve. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 06, 2010 | Kenmore 24032\24036 Top Load Washer
Wont stop filling up. It will overflow with water
Hi
Thanks
Rylee
Aug 22, 2010 | Frigidaire Gallery GLWS1339EC Top Load...
Kenmore 70 series , overfill water dose not stop at set fill levels
It's overfilling If your washer is overfilling, check these: Water-inlet valve Water-level switch Water-inlet valve A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve. Water-level switch A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.
Jan 16, 2010 | Washing Machines
Machine over filling even when set on min. simpson enduro 701
When the machine is overfilling , it means that there is a problem with the inlet valve (valve not closing) or with the water level switch, that should turn off the valve when water reaches level.
See the suggestion from It's overfilling at repairclinic:
Water-inlet valve
Water-level switch
Oct 06, 2008 | Washing Machines
Washing Machines Logo
228 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
